Old 02-26-2009, 06:14 PM   #76
Redline
Redline's Avatar
Re: For Thoese Doing Disk Brakes. 60-66
I just bought a 1963 and it has disk brakes on the front, but no power..... Is there a lot involve in adding this??
thanks,
redline
Redline is offline   Reply With Quote
Old 03-09-2009, 09:15 PM   #77
mx215
how much $$$ for a disc conversion? i plan on running 2 1/2 drop spindles. thanks
mx215 is offline   Reply With Quote
Old 03-29-2009, 06:27 PM   #78
new64owner
Originally Posted by soba_03 View Post
Well now I'm going to keep the 6 lugs in the back. I will eventually probally buy a set of 5 lug axels. But often times a 5 lug rearend is swapped out. I don't have one to throw under mine so I'm going to use a disk brake conversion kit for this year. So I will be running 5 lug up front and 6 in the rear. The wheels are closed centers so no one will know.
there is a web site deicated to specialty brake parts that i found and make rotors just like the 73-87 5 lug rotors that are 6 lug
new64owner is offline   Reply With Quote
Old 03-30-2009, 07:02 AM   #79
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
This is true about the 6 lug rotors for the 73-87, BUT you must make sure you have the heavy duty brakes and spindles, the 73-87 existing rotors must be 1 1/4 thick ( the spindles/races are different size between the light and heavy duty.... I only could find 6 lug rotors for the heavy duty brakes.. CPP has them... Maybe they are out there but I couldn't find them....
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 03-30-2009, 11:21 AM   #80
aggie91
I'm just glad to be here!
aggie91's Avatar
There are complete kits with drop spindles available on the market from many sources for $500 and up. I think CPP's kit is about $599. I did mine with used spindles, new rotors/calipers/hoses/bearings/ball joints from a parts store for about half of what a kit cost at the time. Depends on what parts you can find or what work you are willing to do yourself.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-30-2009, 02:08 PM   #81
joe231
joe231's Avatar
Re: For Those Doing Disk Brakes. 60-66
why did this become un-stuck???
CHEVY ONLY
Old 03-30-2009, 11:54 PM   #82
new64owner
just did the whole conversion for 150 bucks. bought a rolling frame with 1 1/4 front spindles and 6 lug rotors with booster and a new master. all i have to do is have it aligned. craigs list.org is awesome
Old 03-31-2009, 01:59 PM   #83
aggie91
aggie91's Avatar
do you know the web site? I have not found it yet...
Karl
The LST Challenge:
Old 04-01-2009, 01:37 AM   #84
Captainfab
60-66 Nut
Try these guys
http://www.classicperform.com/
http://www.earlyclassic.com/home.aspx
Might be some others, but those two come to mind first. There's another option here.
http://www.67-72chevytrucks.com/vboa...ad.php?t=35042
Old 04-01-2009, 12:53 PM   #85
aggie91
aggie91's Avatar
Thanks Captainfab.
I new about those, but new64owner mentioned a web site dedicated to specialty brake parts. Just asking if he new the web address...
Karl
The LST Challenge:
Old 04-04-2009, 10:01 PM   #86
new64owner
Thanks Captainfab.
classic performance parts. they sell heavy duty spindles. or you can get a used set from a donor vehicle. as long as the rotors are 1 1/4 inches thick they will work with six lug. check your local boneyards or site like craigslist. org. i bought a chevy van frame with heavy duty brakes for 100. with booster, master and pro valve. all lines were in good condition. my a- arms are good just got newer ball joints. and fabricated the spacer bracket for power steering. today i bought a disc rear end out of a camaro that is a little narrower, but with the wider rear tires it fits nice. i have also dropped my fresh built 355 in it. i got quite a hot rod.
Old 04-07-2009, 07:12 PM   #87
joe231
joe231's Avatar
Top
CHEVY ONLY
Old 04-08-2009, 06:25 AM   #88
63sbssbbw
UCA63
63sbssbbw's Avatar
Interesting
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 06-24-2009, 11:52 PM   #89
Captainfab
60-66 Nut
Bump
Old 06-25-2009, 08:05 AM   #90
joe231
joe231's Avatar
is there a reason this became un-stuck?
could it be a sticky again.....?
CHEVY ONLY
Old 06-25-2009, 10:43 PM   #91
bubba327
HOW long until spring??
bubba327's Avatar
Please Stick it where I can find it again. HaHaHa My 6 lug rotors and calipers from CPP arrived last Friday An E-bay Special. Gotta love it!!! Hopefully I will get something done on the 64 this weekend. Using a 71 donor front crossmember and steering parts . Yes-- I know you do not have change the entire crossmember but I wanted to clean and sanitize and paint while I was under there.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 06-25-2009, 11:00 PM   #92
bubba327
bubba327's Avatar
Out With the Old!!!
Yes-- You can pull the crossmember out with the motor still in place. I did lift it slightly with a engine puller just in case. The 6 cylinder is resting on the motor mounts with just the top frame bolts.
Old 06-25-2009, 11:55 PM   #93
daverod
SSN 706
daverod's Avatar
Yes I was pretty sure a 71 would work but everyone was talking 73-87 I was getting worried. I knew Keven would'nt $hit me. There always someone out there proving it can be done. Nice job.
daverod is offline   Reply With Quote
Old 06-26-2009, 06:24 PM   #94
bubba327
bubba327's Avatar
Well Hi neighbor! the 71 parts fit nicely, but one bolt hole in the frame needs a little elongating to the rear by about 1/4" (the bottom front bolt -the hole in the side bracket is threaded already. The other holes all line up. I rationalized that if the entire crossmember and steering components are off a 71, then I can remember that in the future if I need replacement parts
Old 08-04-2009, 01:37 AM   #95
six5
six5's Avatar
I have a 66 C20. It seems the best way for me would to pick up a fully loaded 73-87 front cross member to achieve a 6 lug disc brake setup in the front.....?
-Dave
My 1965 build...http://67-72chevytrucks.com/vboard/s...d.php?t=331302
six5 is offline   Reply With Quote
Old 11-14-2009, 06:24 PM   #96
mtburg71
mtburg71's Avatar
bump
1964 GMC SWBFS
2005 Dodge Magnum RT
mtburg71 is offline   Reply With Quote
Old 11-14-2009, 07:28 PM   #97
Hilandr451
Hilandr451's Avatar
IMHO, yes. I'm fixin' to do that very thing on my buddy's 1966 C20 next Saturday. We're swapping the crossmember from an '83 C10.
Many pictures to follow..... but that's another thread - Right Johnny-boy?.
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 11-14-2009, 09:27 PM   #98
Chevy Fleetside
Chevy Fleetside's Avatar
Next Sunday... I can't do saturdays..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-28-2010, 04:16 PM   #99
mtburg71
mtburg71's Avatar
Ttt
1964 GMC SWBFS
Old 05-09-2010, 08:01 AM   #100
63sbssbbw
UCA63
63sbssbbw's Avatar
Trouble in paradise guys
The 63 gmc xm dropped out easy,but when I went to test fit the 75 xm to see which holes I needed to modify it only went in after using 2" ratchet straps(1 ahead and 1 behind) to suck the framerails together and still needed a BFH to get it to go in
Did a raft of measurements after the body was removed and came to the conclusion that it's not tweaked,bent or twisted.
So what gives????
I'm going to do some comparing today to see where the differences are.
This has me scratching my head after every thread I've read on this subject stated that
it was a pretty easy swap.
any ideas??
Thanks,Trent
member#7816
'61 GMC in progress
