08-04-2008, 09:26 PM | #76 |
Re: Finally!!! 6.0 POWAH!!!!
thanks! one other thing what oil pan u using my motor is out of a trailblazer ss so i have to get a oil pan no matter what
08-04-2008, 10:05 PM | #77 |
I am using stock truck pan, hangs about inch below front xmember.
You can use that if you are not too low, or go with fbody pan.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
08-04-2008, 10:07 PM | #78 |
yolo, saw your truck in the magazine, sick, dude. nice job!
08-04-2008, 10:13 PM | #79 |
www.73-87chevytrucks.com
So they both fit? I couldn't quite understand your post..
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
08-04-2008, 11:41 PM | #80 |
what did that whole set run you? i would like to do a ls1 in my 86
lifes short fabricate as much as you can! |
08-05-2008, 07:18 AM | #81 |
thanks that was what i thought i just wanted someone that has done it to say it
08-05-2008, 05:26 PM | #82 |
Chris,
s&p sent me a new set of headers, they just kicked the collector out on drivers side. I left the original pass side on my truck, because it fits and why take it off? s&p headers are aprrox. $600 shipped.
08-05-2008, 05:33 PM | #83 |
AHHHHH, gotcha. I guess I missed all of that...
Can you post some pics of them installed?
08-05-2008, 06:50 PM | #84 |
Chris,
I brought my camera with me and left it in my work van, lol did not remember til I put up my tools and shut the shop door and left. I'll get some tomorrow, sorry. It runs! turned it over it stayed on for a few seconds, took a few tries but it has good oil pressure.
08-05-2008, 08:49 PM | #85 |
Awesome man nice truck!!! I love that engines my truck have a 5.3 but the 6.0 is a beast
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
08-06-2008, 05:33 PM | #86 |
well, for the 2nd time in a week, my post/pics have vanished...
Let's try this again:
08-06-2008, 05:59 PM | #87 |
NICE! Do you have a shot of the passenger side exit?
08-06-2008, 07:01 PM | #88 |
I'll get u one tomorrow.
08-06-2008, 07:59 PM | #89 |
PCMCOBRA what kind of shifter linkage did you have to use? Do you still have the shifter on the column also? I have a 96 LTI that i want to put a 4l60E behind i dont know if our stock shifter linkage will work. I have an 86 GMC shortbed. Any help would be greatly appreciated, thanks Michael
08-06-2008, 08:06 PM | #90 |
I have the lokar ACA-1800, it's pricey, if I did it again I would get the kuegels, a little less $
From other posts I have read here and on other forums, stock linkage will work with the 4l60e, it can be made to work with a 4l80e, but I don't have a welder and the lokar seems to be what I needed with the 4l80e. Yes, I have shifter on column...
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native Last edited by pcmcobra; 08-06-2008 at 08:07 PM. Reason: column note |
08-06-2008, 08:08 PM | #91 |
Talked to tuner guy today, he won't be able to make it out until at least Monday...
I've waited this long, what's a few more days?
08-06-2008, 08:46 PM | #92 |
I hate to be the bearer of bad news but I just dont think you are going to be happy with the whole setup . Me being a nice guy , I will take the setup off your hands and install a nice 350 /th350 setup for you . I think you will be much happier with less HP , no overdrive , carb vs injection , and way less WOW factor . Just kidding . That is an awesome install ! I imagine it will be hard to keep your foot out of it with that much power on tap .
Frank
Born and proudly residing in a Red State ! |
08-07-2008, 05:47 PM | #93 |
What's taking so long??????? You should have had this done and running months ago....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-08-2008, 09:38 AM | #94 |
And the ref takes a point away! Dang Rob that was cold. But yeah I agree, will all the free time he has had it should have been done weeks ago. After he gets the VATS deleted and has his 'puter setup for his tires and rearend he should be cruising to the BK in no time.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
08-08-2008, 10:10 AM | #95 |
Windy Corner of a Dirty Street
Off the exhaust subject here for a second…
Are you guys still running your dual fuel tank switch valve with the electric fuel pump? My 8.1L does not like returning fuel to the tank through the valve as it causes the fuel pressure to run around 100 psi….by pass the valve and the psi runs normal. I feel the return port through the valve is too small and too restrictive. Right now I have the truck running on just the RH tank which doesn’t get me very far down the highway. Nice headers by the way. Sure beats hacking a chunk out of the frame like a lot of people are doing.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
08-08-2008, 12:42 PM | #96 |
Larry,
I plan to run and aftermarket Pollack(sp?) switch valve that is rated for 90lbs or so until I convert the truck to the rear Blazer tank like my other projects. I can probably get you the PN if you want it. Are you using the factory Switch valve for the TBI?
08-08-2008, 12:56 PM | #97 |
I'm running single pass. side tank with walbro intank pump.
For the lack of driving long distances, 1 tank will work for me with no complaints.
08-08-2008, 03:00 PM | #98 |
Thanks Captkaos,
I already replaced my fuel tank switch valve with a new Pollak valve pn 14029228 as I thought maybe the spool valve in the old Pollak valve was not moving all the way causing the restriction on the return side. Also, from the info I found on Pollak’s website the highest pressure their valves are rated for is 65 psi. I am curious to know where you got the 90 psi figure and what the A/C Delco or GM part number is for that one. I have a document I pulled off the Pollak website in PDF format if you are interested in it. It has decent wiring diagram to it as well. At this point, pretty much decided to ditch the frame mounted fuel pump and convert the RH tank to a 1987 fuel tank, with a TBI sending unit along with a high pressure EP241 AC Delco in-tank fuel pump. Then use an electric low psi/high volume fuel pump to transfer fuel from the LH tank into the RH tank through the vent port on the sending unit. My truck is an outdoor expedition rig so I absolutely need two fuel tanks and I don’t have room behind the axle for a Blazer tank due to there being a winch mount back there. 14029228
08-11-2008, 03:43 PM | #99 |
Larry, I am going to the beach this Wednesday and the valve is at my brothers shop (90 miles away) I won't be able to get the PN until I get back.
I would be interested in the document, if you can send it to my webmaster at 73-87chevytrucks.com email, and put a reminder for me to get the PN. You got me questioning the rating now... BTW, I was checking around and found what the Bio guys are using... http://www.vegpower.com/order/prodpa...543&startrow=1 It is a HydraForce valve..
08-11-2008, 04:19 PM | #100 |
what is a 6.0l worth?
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban |
