Old 07-02-2008, 12:24 PM   #76
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: No Regrets - The Rebuild post
Who/where did you order your wheels from?
Jeff @ sportruck.com. here's one more with a little sunshine on it before I had to pull it back in the shop. I'm leaving today for an all week end concert, so I won't be able to work on her till next week.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-02-2008, 12:26 PM   #77
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Sweet!!!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-02-2008, 01:46 PM   #78
tvblazer78
Low & Fast!
tvblazer78's Avatar
I Like it man, keep it coming....
tvblazer78 is offline   Reply With Quote
Old 07-03-2008, 08:31 AM   #79
FlatBrokeRacing
FlatBrokeRacing's Avatar
Very cool rebuild....
FlatBrokeRacing is offline   Reply With Quote
Old 07-03-2008, 01:52 PM   #80
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
it looks great.. i like the new wheels..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-03-2008, 09:09 PM   #81
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sick !!!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-05-2008, 05:34 PM   #82
bagged01extcab
how did they go about widening the hood?
Trey Oney
bagged01extcab is offline   Reply With Quote
Old 07-05-2008, 06:50 PM   #83
bagged74
its just $$$$$
bagged74's Avatar
looks freakin sweet!!!!!!!
bagged74 is offline   Reply With Quote
Old 07-14-2008, 12:38 AM   #84
smashingchuck
Well, I would like to say it was cut and had an 1/8" of metal to each side, but we figured that would be more damage than good.
He used some type of fiberglass with metal reinforcement. I have no idea of the actual name of it is. Even upon very close inspection there is not a hint of it underneath the hood.
78 Build Thread
4Runner Build
Old 07-14-2008, 07:19 PM   #85
bagged01extcab
Thanks! I didn't figure that you would cut and weld on it, but was curious as I have the same prob
Trey Oney
Old 07-14-2008, 07:48 PM   #86
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very cool..... just read the whole thread..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-14-2008, 10:03 PM   #87
1984 swb chevy
1984 swb chevy's Avatar
That has to be one of the best looking chopped truck that I have seen. Most people who chop them never bag them so they dont look low enough. Very nice choice of wheels.
1984 swb chevy is offline   Reply With Quote
Old 07-29-2008, 01:33 PM   #88
smashingchuck
Just got the sand blasting on the frame complete. I have a few modifications to make (mainly moving the shocks outbaord the notch so I can fit the exhaust though between the notch and the axle) and I'll be ready for paint.
78 Build Thread
4Runner Build
Old 07-29-2008, 01:40 PM   #89
smashingchuck
well I can't get the picture to upload I'll try it again later.
78 Build Thread
4Runner Build
Old 07-29-2008, 02:12 PM   #90
VerticalSmile
VerticalSmile's Avatar
Originally Posted by smashingchuck View Post
got the wheels on for a test fit...
I love this pic, your son looks to be really admiring your truck.
GREAT JOB!!!!
VerticalSmile is offline   Reply With Quote
Old 07-29-2008, 11:59 PM   #91
smashingchuck
It wasn't intended that way, I'm sure he was just day dreaming
I'll try the picture of the bare frame one more time...
78 Build Thread
4Runner Build
Old 08-01-2008, 12:28 AM   #92
smashingchuck
And here is how I solved the problem of the transmission cross member bolts hanging below the frame. First I welded tabs to the original crossmember and used two 3/8 bolts though the side of the frame. Then, I countersunk the original holes and used the proper bolts so they were flush with the bottom of the frame. Then I bolted in the other two pieces for rigidity. I still have to sand blast one of the upper pieces, but it is strong as hell and doesn't drag the bolts on the ground now.
78 Build Thread
4Runner Build
Old 08-01-2008, 09:55 AM   #93
bagged74
its just $$$$$
bagged74's Avatar
lookin good. keep up the good work!
Old 08-01-2008, 10:37 AM   #94
LMDGUY
LMDGUY's Avatar
very cool build! keep the updates coming..
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 08-03-2008, 10:21 PM   #95
smashingchuck
I just can't leave well enough alone I guess. I started inspecting the rear crossmember of the frame, an noticed a few pin holes in it. Soooo... it's gone now, and I nice one is back in it's place made from 3/16 wall tubing. It will work better anyway since the exhaust will be coming straight out the back. I also got some other stuff done, which I will discuss in the next post.
78 Build Thread
4Runner Build
Old 08-03-2008, 10:28 PM   #96
smashingchuck
The other order of business today was the crossmember in front of the axle, which I will admit was an abomination of nobodies fault but my own. I overlooked it rushed it, and just plain kinda messed it up the first time around, and it was time to make it right. Before I even started to remove it, I welded temporary crossmembers top and bottom on each side of it. Then I drilled out a bunch of rivets, And when I packed it up for the night was just starting to mock up the new pieces. When complete it will be a complete driveshaft hoop, and lots stronger than the factory original.
78 Build Thread
4Runner Build
Old 08-03-2008, 11:08 PM   #97
N2TRUX
Happy to be here
N2TRUX's Avatar
That hoop looks so much better. I saw the pics and thought "holy crap" what happened? Everything has been looking awesome until I saw that. Then I realized that was the old one, not the new and improved version.
It looks like your welding skills have really improved since your first build...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-03-2008, 11:49 PM   #98
smashingchuck
That was another thing about the notch that is was so ugly, and the welds were done from a weird angle with my arc welder. And I did it in a big hurry. I now have a big MIG welder as well and it makes it much easier, as much as I hate to admit it. Plus the frame is completely clean and there is nothing I have to work around.
all the other welds on it were not nearly as bad as the ones on that
78 Build Thread
4Runner Build
Old 08-17-2008, 08:42 PM   #99
randyjohn
randyjohn's Avatar
updates?
It's peanut butter jelly time.
'74 GMC 3/4 TON 2WD LB
randyjohn is offline   Reply With Quote
Old 08-17-2008, 09:34 PM   #100
smashingchuck
Originally Posted by randyjohn View Post
updates?
busy week end.... didn't touch either trucks, with the exception of picking up a new motor for the other truck I picked up.
here is the other truck-
http://67-72chevytrucks.com/vboard/s...d.php?t=302473
78 Build Thread
4Runner Build
