12-07-2008, 05:04 PM | #76 |
67-72 parts collector,…
Re: My DJM flip kit install pics
Let me see if I can find an installed pic.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-07-2008 at 05:12 PM. |
12-07-2008, 06:40 PM | #77 |
very cool thread!
thanks for the info can someone tell me why these kits re-locate the axle to the rear? is it so the drive shaft doesn't bind? seems like a small amount of movement. is it necessary? I don't really like the looks of the flip kits, i'm planning on doing my own flip and removing the factory leaf perches and mounting new ones on the bottom of the tubes. anyone gone this route? would i need to change pinion angle, or keep it stock? TIA
CHEVY ONLY |
12-07-2008, 07:09 PM | #78 |
I think it keeps you from having to shorten the driveshaft,... and also keeps the wheel centered in the wheel opening.
12-07-2008, 07:22 PM | #79 |
I copied this from the DJM websight. I didn't know this either until I read it on their site.
"If you could jack the rear end up to the point where it was level with the transmission the splines might completely disappear and the drive shaft would be forced into the transmission. This is not a good thing and why you need to move the axle back away from the transmission when you install a “flip kit”. " Full page here. http://www.djmsuspension.com/products/flip%20kit.html Last edited by Nolowrider; 12-07-2008 at 07:26 PM. |
12-07-2008, 08:26 PM | #80 |
cool, that is what i thought
thanks guys
CHEVY ONLY |
12-07-2008, 08:33 PM | #81 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Lucky you have good roads, you couldn't drive over here without a c-notch!!
12-07-2008, 09:31 PM | #82 |
I know what you mean, crawdad.
Probably going to be bringing my sons truck over to you guys to get it lifted. |
12-07-2008, 09:50 PM | #83 |
Give us a call, not busy at all this time of year!
12-08-2008, 10:37 AM | #84 |
These are pics of the shock mounts on the 12-bolt truck housing that was on the '77 I scraped.
truck 12-bolt passenger side driver side
- Greg |
12-08-2008, 11:25 AM | #85 |
454HO-Thank you so much for your time, I really appreciate your time going over to your storage and getting the pics.
Yep, my shock mounts are def different. Don't know why. I ordered a set of Nitro drop shocks last night, I may just have to go without the extenders and re-locate my top shock mount. Can't really do anything yet until I get my new rims (today hopefully). Once I get the c-notch, mini-tub cut I will be able to drop her back down on the ground and see where everything lines up. Thank you to all that replied. You all have been very helpful. Last edited by Nolowrider; 12-08-2008 at 11:26 AM. |
12-08-2008, 11:53 AM | #86 |
yeller
Why do youy need to re-locate the top shock mounts? I did not have to for my rear suspension drop. I have HD leafs, with overload removed, flip kit, 2" drop shackles, 12 bolt, Bell Tech drop shocks, AND Cal-Trac traction bars. Everything bolted in without a hitch.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 12-08-2008 at 11:53 AM. |
12-08-2008, 01:04 PM | #87 |
If I were you, I would just weld the DJM extenders over the existing mounts you have there and call it a day.
Also curious if you have another pic that shows the pumkin a little better. Looking at this pic... ... I'm not so sure that is a truck 12-bolt.
- Greg |
12-08-2008, 03:08 PM | #88 |
Thanks for the help 454HO. I appreciate your time. Here is a better pic of the rear.
] I had to take a break from drilling those c-notch holes, I am wore out. Two hours and I have 5 holes drilled. Last edited by Nolowrider; 03-15-2010 at 09:26 PM. |
12-08-2008, 03:20 PM | #89 |
Man go to Sears and buy the Titanium coated uni-bit (some call them step bits) get the small one that go's up to 1/2". I bought one to do the Dropmember on the back of my truck....32 half inch holes!!! I cant believe how great they work, they go through the frame like hot butter!! $24.00 bucks but way worth it.
12-08-2008, 04:38 PM | #90 | |
12-08-2008, 04:42 PM | #91 |
Okay, that is definately a truck 12-bolt. Not sure why it has those goofy shock mounts.
- Greg |
12-08-2008, 09:00 PM | #92 |
Well, I almost got the c-notch's installed, but ran into a problem with the passenger side shock. The c-notch plate will not allow the shock to bolt up clean. Not sure if re-locating the shocks will work correct this or not. Too tired to work anymore on it tonight. Still waiting on my rims from Centerline, been 6 weeks now and they still have not arrived. Can't do the mini-tub until they get here. I did get all that I wanted to do today completed.
01-23-2009, 01:32 AM | #93 |
im wondering if you rotated the extension down and drilled a hole in the actual axle mount if that would help? i noticed from 454HO's pics there's a nut and bolt on the side and the actual middle of the axle mount, where as your's doesn't have the hole in the middle and you have the shock bolt going through the cross holes.
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 |
01-23-2009, 02:22 AM | #94 |
I got a different axel from a pull-a-part place and everything bolts up fine now. Never did figure out why my axel was different. I gave up on it and just put a different one in. Still waiting on rims rom Centerline, I am also going to throw some 4:10's in there. Thanks for asking.
01-23-2009, 02:21 PM | #95 |
cool. well i'm thinking i need new gears too, those 22's i have on my truck are way harder to turn than the 15's i had on there before. can't spin them with the 3.42 gears i have in there now.
01-23-2009, 02:30 PM | #96 |
thanks for all the info guys!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
03-17-2009, 01:17 PM | #97 |
How is the ride? Do you bottom out ever? Do you ever put stuff in the bed and bottom out? I am debating about a 2.5/4 drop but I like this look better.
03-17-2009, 01:22 PM | #98 |
I've hauled 1300lbs of wood flooring in mine, never bottomed out the suspension. I did scrape my 3" exhaust pipes a couple times though....
- Greg |
06-08-2009, 10:52 PM | #99 |
Badass
nice truck..so you can do a flip kit with no cnotch? with stock hangers and shakles?
where did u buy this kit/?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
06-09-2009, 08:47 AM | #100 | |
From post #1
- Greg |
