Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 08-12-2010, 09:00 AM   #76
ronh72c10
Re: Project Git-R-Done - 72 K25
Originally Posted by thirdstreettito View Post
Nice build! I love 6.2/6.5's. Its great you are doing a swap. Most people dont realize how great diesels really are, they cant get over the noise and smoke. You are doin great! If you have an 6.2/6.5 questions just ask. I know way to much about them. lol
You've probably opened yourself up to alot of pestering , I still haven't checked the runout on the harmonic balancer after it took the hit when the lifting chain broke, what would you expect the max runout would be? As well should I be concerned about the crank, or just assume the worst, drop $400 and replace the crank, obviously breaking the crank would be catastropic.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 08-12-2010, 11:00 AM   #77
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Ron
What exactly happened? The chain broke and it landed on the Balancer?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-12-2010, 12:34 PM   #78
ronh72c10
The front chain on my leveler broke, it didn't land fully on the harmonic balancer, but the harmonic balancer did hit the crossmember, as well as the oil pan, accessory bracket, and fuel pump. I figured I'd check the runout to see if something bent or cracked, but realistically I don't know what to expect to see or even if that will tell me anything useful about crank damage.
Ron
72 GMC 3/4ton 4x4
Old 08-16-2010, 10:21 PM   #79
thirdstreettito
Resident of Here
Definitely replace the harmonic balancer. Get a Fluidampr. Best of the best. Also, its up to you to replace the crankshaft. If you decide to let me know Ive got more info for you.
~Bradley~
Miss having a truck
Old 08-23-2010, 08:13 PM   #80
ronh72c10
I think the price of a new crank is cheaper than a new block, so I'll replace the crank as well. Any advice you have would be helpful, a good brand of crank to buy, I'll get new rod and crank bearings as well. A company you'd recommend dealing with too.
Thanks,
Ron
72 GMC 3/4ton 4x4
Old 10-11-2010, 10:30 PM   #81
ronh72c10
I haven't updated this thread for a while, I've been concentrating on the youtube updates of the buildup. Right now I'm trying to get the truck ready for paint before things get too cold to continue. Here's a couple of pics of the latest stage, I'm nearly finished bodywork on the cab and hood, today I hit them with another coat of high build primer. Tomorrow I'll work on the fenders, door and cowl. Hopefully this weekend I'll get some paint on it.
Ron
72 GMC 3/4ton 4x4
Old 10-11-2010, 10:32 PM   #82
ronh72c10
High build primer pics.
72 GMC 3/4ton 4x4
Old 10-11-2010, 11:43 PM   #83
jrdv
jrdv's Avatar
Great Build!
I am surprised on the lack of comments considering the amount of time you have put into posting pics, vids, and great details.
I will have to check in a little more often! I am wanting to try a little bodywork myself and you are doing an excellent job.
Keep it up.
John
jrdv is offline   Reply With Quote
Old 10-12-2010, 08:18 AM   #84
VA72C10
VA72C10
VA72C10's Avatar
Truck is looking great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-13-2010, 01:45 AM   #85
Chevymaniac
Your project is moving along, i need to kick mine into high gear and get some done. What did you have to do for body work? Any rust repair?
Chevymaniac is offline   Reply With Quote
Old 10-15-2010, 08:38 PM   #86
ronh72c10
Thanks, the cab was one I picked up that came here from California, even so it needed kicks, outer floor, inner and outer rockes as well as both cab corners. Not the best welding job as I did the cab a few years ago for another project, but decided to use it for this one.
Tomorrow I'm going to try to get some more high build on it and maybe get some paint on the inner surfaces, but I've got to fix my shop chimney since it fell apart when I touched it today.
Ron
72 GMC 3/4ton 4x4
Old 10-18-2010, 08:46 PM   #87
ronh72c10
I spent the weekend high build priming the cab and hood, sanding it with 400 grit and then epoxying them. Apart from sanding a few runs I think I'm done with them until it's time for paint.
Today I put the doors back on so it'll be easier to do some body work on them.
Ron
72 GMC 3/4ton 4x4
Old 10-18-2010, 08:59 PM   #88
VA72C10
VA72C10
VA72C10's Avatar
looks really good!!!
Old 10-19-2010, 02:30 PM   #89
madmopar
This guy has got to be stopped
madmopar's Avatar
I agree - great job... I wish I had some great, enlightening comment to kick in about diesels or the body work you're doing, but to be honest both are over my head... Don't tell anyone but I'm afraid of trying new things! - It looks like you're doing great work though! Sorry to hear about your engine's fall... Couldn't you have the crank crack tested , before you decide to replace it???
J P Evers
1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134
madmopar is offline   Reply With Quote
Old 10-19-2010, 09:11 PM   #90
ronh72c10
Actually I've decided not to replace the crank, I'm just going to replace the harmonic balancer. My dad pointed out that it fell into a sprung frame, didn't land directly onto the HB, the fuel pump took some of the drop as well as the accessory bracket so the damage is "probably" minimal. I'll take a chance with the crank, but replace the HB and fuel pump.
Ron
72 GMC 3/4ton 4x4
Old 07-27-2011, 08:44 AM   #91
ronh72c10
Well I am still working on this, in the latest video I started spraying some base and clear on the underside of the hood. I'm off next week so the paint WILL be done by end of next week, hopefully this weekend.
http://www.youtube.com/embed/ydQQiWdh-pE
Ron
72 GMC 3/4ton 4x4
Old 08-01-2011, 11:05 PM   #92
ronh72c10
Got some Base and clear on the cab interior and inside doors. Used Nason's Ful-Base and Select Clear.
Ron
72 GMC 3/4ton 4x4
Old 08-04-2011, 07:31 PM   #93
ronh72c10
Got some more work done, base and cleared the back sides of the fenders.
Ron
72 GMC 3/4ton 4x4
Old 08-04-2011, 09:11 PM   #94
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Nice job, Ron. I just realized I knew your videos from youtube. Great work. I'd been checking out your front axle rebuild. As far as the crank goes, I wouldn't even worry about it. Just replace the balancer. In order for the crank to be damaged, the snout would have to take a major/serious direct blow. It was somewhat "protected" by the balancer when it dropped. It may have been time to replace the balancer anyhow.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 08-05-2011, 12:52 PM   #95
ronh72c10
Good to hear, I'll call replacing the HB an insurance policy, shame though, it was brand new.
Ron
72 GMC 3/4ton 4x4
Old 08-06-2011, 03:02 PM   #96
ronh72c10
Three coats of base on the truck, clearing later today.
Ron
72 GMC 3/4ton 4x4
Old 08-06-2011, 05:45 PM   #97
ncgamedog
Nice build man! What color blue is that?
ncgamedog is offline   Reply With Quote
Old 08-06-2011, 08:35 PM   #98
ronh72c10
The color is Viper Blue, I believe the 2008 color, I have the paint code if you want it.
72 GMC 3/4ton 4x4
Old 08-06-2011, 08:38 PM   #99
ronh72c10
Here is the Clear!
72 GMC 3/4ton 4x4
Old 08-07-2011, 12:18 AM   #100
67chevy1series
67chevy1series's Avatar
wow looks super nice!!!
67chevy1series is offline   Reply With Quote
