09-27-2008, 07:12 PM | #76 |
Re: Honest Abe's Shop Truck build
I'm diggin your shop-truck project.
Do you plan to leave the tool box on top of the rails like that? I like the idea of the box for hiding your req'd air stuff & for actual storage any truck needs but think it would look better flush w/the top of the bed sides. Again.... nice job.
09-27-2008, 07:25 PM | #77 |
yeah, its staying on top of the rails... at least for now. I personally like it this way.
here's one to ponder... The look of the truck is to look like there was no concern with how the truck looks... ie: beat up work truck. |
09-27-2008, 07:28 PM | #78 |
Texas Big Wig
I understand what the track bar is doing in this application & yes it keeps it from pivoting on all 6 hinge points, but like I said it will shift side to side what little bit the 2 front bushings will flex
Its not a big deal, I was just curious |
09-27-2008, 09:31 PM | #79 |
I get it & chuckled w/the mention of the pipe/ladder rack. I just never have liked the tool box on the rails thing. You like it, so that's what counts.
09-27-2008, 10:25 PM | #80 |
Phone's ringin Dude.
Holy crap, I've been gone awile and missed this one. Awesome build!
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
09-27-2008, 10:53 PM | #81 |
that track bar is probably not going to work, i tried that on my dually that i bagged with poly bushings, it even had a triangulated 4 link in it. i had to go to the
s.d. super pivot to get all the play out. it may work if you have enough room in the wells, my dually was tight in the fenders even after i narrowed the rear nine inches. good luck and love the design of the links. |
09-28-2008, 04:15 AM | #83 |
Well guys.... 4:26 I am checking in. It still sits on stands. Running into a few issues with the exhaust flange bolts. And the wiring is still slow but steady. Plumbing is just about complete and assembly is pretty much done. Only 1-2 more solid days and it should be rolling.
Thanks for all the positive comments from yall. It helps in the push to get it completed. The locator is solid. I about pushed the truck off the stands when I was checking it out. There is next to no movement side to side. The locator was designed on a buddy of mine's bubble top dragster. And its a rock solid set up. Again I wont know 100% until I get it out on the road and drive it. Also remember this is just a driver. It is not meant to be fast or handle like a sports car. It is ment to be tough and LOW. So I have no doubt in it at all. (texastrendz) there should be no reason to have a locator bar on a triangulated 4 link. They may have been working against each other. But I wouldnt know without seeing the setup.
1971 Chevy C10 LWB Shop Truck 1984 Chevy C30 Dually LWB Tow Pig 1985 Chevy K5 Blazer |
09-28-2008, 01:03 PM | #84 |
09-28-2008, 11:23 PM | #85 |
PROJECT 7DEUCE
Very cool cant wait to see it on the ground..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-30-2008, 04:09 PM | #86 |
Insert Title Here
looks good so far...nice job
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
10-01-2008, 09:44 AM | #88 |
10-01-2008, 09:59 AM | #89 | |
"Oh well, it's a driver."
Perfect - I especially like the manatee bumper sticker!
When you pull up at a light in that old thing, and then lay it out...the looks on people's faces should just be priceless.
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E Quote:
10-01-2008, 12:03 PM | #90 |
Haha yea I cant wait to have it on the road. Just gotta finish the hood, battery tray, and a little more cutting on the fender wells. and it'll be rollin. I am super stoked. Here is a few more...
10-01-2008, 01:01 PM | #92 |
am I the only one seeing red x's?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
10-01-2008, 02:17 PM | #93 |
First it got 3" belltech spindles. Then removed Ball joints. 3" Bag pockets into LCA's, and pie cut the uppers. It lays on the control arm buckets now. Just barely. But enough that the cross shaft u bolts dont lay.
10-01-2008, 05:03 PM | #94 |
Texas Big Wig
So why & how did you pie cut the uppers ??
And what did you use for ball joints Last edited by Spray-Bomb; 10-01-2008 at 05:09 PM. |
10-01-2008, 09:05 PM | #95 |
Cool truck, keep at it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
10-01-2008, 09:38 PM | #96 |
You are my new idol. That thing is awesome.
10-01-2008, 10:32 PM | #97 |
i second that.......
CHEVY ONLY |
10-01-2008, 10:47 PM | #98 |
We pie cut them to make up for the ball joints binding.
And Ryan is going to post a "How-To" on how to pic cut the uppers in the next day or two.
10-01-2008, 10:58 PM | #99 |
damn, put me on the spot.
but seriously. I saw a thread on here about "pie-cutting" and it was made WAY more difficult then it needs to be. It took me all of 1 hr to do both sides... and it was somewhat time consuming on the side were we stopped and took pictures for a how-to. |
10-01-2008, 11:34 PM | #100 |
1969 Short, Fleet, and Beat
I am really feeling this truck
