Old 11-20-2008, 09:11 PM   #76
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Calling All 383ci Trucks
Originally Posted by WorkinLonghorn View Post
VDOG, I blew the original 350 ci engine in my '69 (full throttle with a load up the steepest hill in Los angeles,Baxter St,) and had a "rebuilt" 350 put in and opted for the "RV cam".(specs unknown). I am VERY happy with this 350 and it has loads of low-end torque. But for all other uses,including bed-loads of sand,dirt etc.,I like my 350 just fine.
Chances are im not going to tow or pull anything behind my truck. Once its finish, I dont plan on putting anything in the bed. I never drove a 383 either but I hear its a great motor. I just dont want to spend more money changing up things I just had done less than a year ago. My rebuilt 3;08 gears and rebuilt Th350. If you go back and look at all the previously posted comments, you will see most are saying 700R4 or 400 trans with 3:73's or 3:55's, I have neither.
VDOG is offline   Reply With Quote
Old 11-21-2008, 05:26 PM   #77
prg machine
prg machine's Avatar
Just do a simple basic 383 and smile!
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 11-22-2008, 01:46 PM   #78
VDOG
Grand PooBaa Member
VDOG's Avatar
I hear you bro! Just shut up and do it! LOL
Old 11-23-2008, 09:58 AM   #79
prg machine
I won't say "shut up"
why don't you just read my signature!
383 .040 over
Old 11-24-2008, 01:44 PM   #80
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks, thats great info on your sig.
Old 11-29-2008, 05:34 PM   #81
Pyrotechnic
Pyrotechnic's Avatar
True...till I posted. I run a 383 with a Turbo 350, 3.08 gears, and 28" tires. The gearing is not ideal for drag racing, but the motor has absolutely no issue moving the truck around. It's faster than it ever was with a 350.
For comparison, I had a stock 350 that had a lot of trouble with the 3.08 gears. It moved the truck OK, but gas mileage was awful because the the torque curve was never reached. I had to swap in an RV style cam, then it had no issue moving the truck.
What does this all means ? It means that with 3.08 gears more torque is better. A larger engine with more torque is better suited to pushing these gears than a smaller one.
If your aim is to leave your transmission and rear end alone, larger engine = better.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-29-2008, 05:46 PM   #82
ripdog28
ripdog28's Avatar
A 383 with 3.08 rear will do more with it then a 350. the TH 350 will work fine without any issues as long as you do not drag race with it on a regular basis. I will be using a TH 350 with my BBC. some work done to it but stock shaft which is considered the major difference over a TH400
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-29-2008, 08:29 PM   #83
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I agree with the 383.You can keep the price down by using a kit already balanced from Jegs,Summit or one of the other performance companies.The difference in power will be in the cam selection.More torque will allow you to keep the tarns and gear you hqave with a performance increase and probably no loss of milage except for what your right foot gives up.
To get a long lasting reliable engine requires the use of precision machine work careful measurement and meticulous assembly.Quality parts will further enhance the life of the engine.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
