#76 |
Resident of Here
Re: 73-87 prerunners.....found pics..
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#77 | |
#78 |
here are more...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 02-17-2011 at 02:00 PM. |
#79 |
Quick question, on the solid axel prerunner blazer,and older 4x4s, why are the springs underslung ? I'm working on a project and wanted some info on prerunner 4x4s,and noticed this. Any help? Thanks
#80 |
What Hump?
Possibly to lower the center of gravity, the picture above your comment shows why it's done to prevent roll over during tight cornering.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
#81 |
I have an 85 I'm building,built 350,turbo 350 ,203 case,cage bed. Has a 6'' lift ,but really like the prerunner look.Just woundering if I underslung my axles on the lift springs,would that work or be a waste.
#82 |
A lower center of gravity is good, even the hardcore 4x4 guys are going this route. Makes for better handling.
Another thought as well is that softer long travel leaf packs can be used and with the spring under mounting it helps keep the axle wrap under control.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#83 |
Can you do the same to the rear?I have 6'' springs on rear ,then undersling springs.I can't make out the pics of the prerunners on the page. Any ideas? Thanks
#84 |
A lot of the pictures I posted have trailing arm rear suspensions (think 67-72 Chevy/GMC trucks...)
They make "flip" kits for the rear for the lowered crowd, but if you added say 6" lift springs you may get a couple inches of lift. Of course this works best with long travel leaf springs (Deaver as example) and may require modifications to the bed/frame to get the most out of the travel. May also need to do a shackle flip (Off road design as example) to get a few more inches of lift out of the rear to match the front. Solid front axle with the axle flipped probably won't have much travel though, due to clearance issues with the engine/frame, etc...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 06-08-2011 at 06:24 PM. |
#85 |
2lo4me/ntlonuf/ntfstnf
62 GMC swb fleetside~ project: still undecided ![]() 84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME 65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress... 02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable... |
#86 |
Resident of Here
#87 |
Resident of Here
http://www.off-roadweb.com/features/...c10/index.html
![]() ![]() ![]() ![]() http://www.off-roadweb.com/features/...uck/index.html
#88 |
How would someone go about building one of these?
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
#89 |
Make sure your bank account can stand it,Other words DEEP Pockets. Jason
#90 |
That expensive huh?
#91 |
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
#92 |
#93 |
i have to say im not a fan of the newer front on the square chevy, but it looks like someone likes it
#94 |
![]() Join Date: Jun 2009
Time for a bump!
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#95 |
Here is my 79 High Sierra Jimmy with Rough Country Lift Kit 6" with 38x15.50R16 350v8 5.7
3rd Row Seat. 4 Speed Manual Trans, with NP203 Transfer case, 87 Suburban Face Lift, It sucks, I have to trade for a smaller truck because I wont get rid of my 73 GMC Super Custom 2500 3/4 Ton 4x4, Anyways back to the Jimmy she has lots of flex but a small anti-freeze leak. ![]() ![]()
RoughKuntry 73 GMC 25 HUNDRED :Sold 79 GMC High Sierra 4x4 (Ma-Duece) :Sold 99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling 88 Chevrolet Burban 2500 4x4 :Buying ![]() |
#96 |
#97 |
Square
this thread is 4 pages and 11 years spread out... crazy.
Squarebody Syndicate |
#98 |
What Hump?
Yeah but there is more than one thread, I think there is three.
Tom
#99 |
Well I just noticed that lol. But you really can't blame anyone when it states 73 - 87. I just don't see many 73 GMC or Chevy trucks out there. maybe because I am stuck fixing mine at my house.
#100 |
I was really just using this thread to document all the square body prerunners that I had found. When I find new one I come back and add to the thread.
