06-23-2012, 06:49 PM | #76 |
Re: Headers to 2.5" Ramhorns
So I am finally getting around to looking into getting these. I don't love the alternator mount but don't really have the means/tools to remove it. Is there a set that will fit without the alternator mount? Like the 674-501? I'm guessing not or there would be more talk about them. Would there be any figment issues if I just left the alternator mount on them?
Posted via Mobile Device |
06-23-2012, 09:28 PM | #77 | |
It was really easy to cut with a angle grinder, and a cutoff wheel
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
06-23-2012, 10:56 PM | #78 |
born to lose
Not to brag but I picked up a used original set locally for 30 bucks! They're going on my truck ASAP since they didn't clear on my Nova. How do you guys like the dormans?
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
06-25-2012, 08:54 PM | #79 | |
06-26-2012, 01:04 PM | #80 | |
BTW, nice looking truck!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-26-2012 at 01:10 PM. |
06-26-2012, 11:24 PM | #81 |
Thanks Jaros! Time to really start investing in this thing. It's not running properly right now, so I'm working on that now and these manifolds are part of the process. The plan is to use my tax return next year to get some color on it as well. I have some tools but not a ton of power tools. I have a buddy that likely will have one. If it's that easy then time to make a trip to his place!
03-04-2013, 12:13 PM | #82 |
Another quick question on these, when they came in, there was a slip in there recommending not using a gasket to mount these to the block. I'm hesitant to go that route and wanted to see what others did/used for theirs.
03-05-2013, 07:52 AM | #83 |
I have never mounted exhaust manifolds without gaskets nor have I seen it done. Why go through the work only to find out that there are leaks. Stock exhaust manifolds had gaskets. Why would aftermarket manifolds, most likely cast overseas, not need them? If it were me, I'd use gaskets.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-05-2013, 06:02 PM | #84 | |
03-07-2013, 12:34 PM | #85 |
Junior Member
I am not running gaskets based off info from this board and I have no leaks. I ran gaskets on my 69 and had leaks.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
03-07-2013, 03:22 PM | #86 |
JMHO, not saying anyone is right or wrong, but this topic has been debated a long time.....probably since the internal combustion engine was invented
I think if your surfaces are true and flat, plus using oem locking plates, you could get away with a copper shield sealant. Anyway, thats what i plan to do, and you guys will the first to know if that system fails I think the gaskets fail because the bolts arent retoqued after several heat cool cycles, wrong bolts, and failure to use the mechanical locking plates
03-08-2013, 09:13 PM | #87 |
Has anyone bought the Wysco ones from Jegs? I'm thinking about ordering them this weekend.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
03-08-2013, 09:43 PM | #88 |
Na, mine were Dormanns
03-09-2013, 01:48 PM | #89 |
They look like the dormans with all the grinding work already done.
03-11-2013, 07:24 PM | #90 |
It looks like they are just a little more money, but you don't have to grind on them. I'm just checking here to make sure they aren't junk.
03-15-2013, 02:04 PM | #91 |
Are you guy just using the 2 1/2 header collector for these?
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
03-15-2013, 02:15 PM | #92 | |
Two styles available, one is bent sheetmetal, and the other is a piece of solid steel Also, ive heard of the donuts failing, so get the one with a metal sleeve
03-16-2013, 06:22 AM | #93 | |
08-21-2014, 03:01 PM | #94 | |
I got my manifolds & cut off the brackets. Got my downpipe. Trying to figure out how to mate the downpipe to the manifold. I bought the manifolds w/o the heat tube and they came w/ the donut gaskets... Do I use a Ball Joint style fitting and slip the 3-bolt flange behind it (donut inside the ball joint)? Or do I need something like this: |
08-21-2014, 08:45 PM | #95 | |
Kinda concerned about the inside of that part, as it looks like it is reduced on one section. Try looking the part up on a corvette site. Let me know if you have any further questions Hope this helps...
12-22-2014, 05:24 PM | #96 |
This is a great thread.
I have a question. I'm running old school heads with no mounting holes to run the alternator. Would the Dorman 674-504 work? Or will I need to run the alternator on the upper passenger side? Amazon.com: Dorman 674-504 Exhaust Manifold Kit:... Thanks |
12-22-2014, 08:18 PM | #97 |
I m guessing that there is a enongated squared off bracket ( the pivot bracket) on the bottom of the alt. If this is the case, then there is a threaded boss that is on the exhaust manifold
Take your alt. off and post up a pic. of the bottom mount.....
12-22-2014, 10:21 PM | #98 | |
Here is a pic. You think those manifolds will work? |
12-23-2014, 07:53 AM | #99 |
I m guessing that you would not use the adapter bracket that mounts around you header, and bolt your pivot bracket directly to the manifold, so, yeah it should work....
Don t forget to buy one for the passenger side, and you will have to cut that bracket off, since it will now be facing the firewall. Unless, you buy the proper manifold
12-23-2014, 09:39 AM | #100 |
If you don't want to use the heat riser spacer than you can use this .
CORVETTE EXHAUST PIPE FLANGE - 2 1/2" FLAT TYPE Part#:322106 Price:6.95 Pkg:EACH Year:1962-1974
