04-06-2010, 07:06 AM | #76 |
Redefining LowBudget
Re: 1970 cst lwb project "Cheap Build"
on another note my oil pump is in I ned to get it painted and put on....still trying to save some $$ for the BS stuff when I do the swap..I think I need to put a windshield gasket in it first since if I get cought in the rain its going to leak all over my new carpet and insulation..NOT GOOD...
04-14-2010, 02:57 PM | #77 |
Im loving the new stance with the rear meats. Looks nasty. Then with that BBCaddy,
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-20-2010, 06:47 AM | #78 |
Eat My Rust
Oh, that is lovely.. |
04-20-2010, 05:18 PM | #79 |
Thanx I have since painted the tailgate and since I'm in Fla till tomorrow I'm kinda stuck but the roads are so nice down here its killing me.....I would love to have my truck here and show some of these bling bling trucks with 20 plus's some old school lessons!! wsith the left front about 6" in the air and the rear bumper dragging....Kids
SIZE MATTERS!!!!!!!!! |
04-20-2010, 05:20 PM | #80 |
04-23-2010, 11:50 PM | #81 |
side pice please
04-24-2010, 09:32 AM | #82 |
ok here goes.... sorry about the rubber on the rear fender guess I should have cleaned that off before the pic
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-24-2010, 11:04 AM | #83 |
VA72C10
Wonder how the rubber got there
Looking for a 67-72 swb or blazer project in or around VA. |
04-24-2010, 02:05 PM | #84 |
Hey, I thought you said you painted the tailgate? |
04-25-2010, 01:08 PM | #85 |
pretty amazing what you can do inside the bed with a roller and some sand blast sand
04-25-2010, 01:33 PM | #86 |
Are you going to show us?
04-25-2010, 03:45 PM | #87 |
DAm I'll go back and add the pic....
today was another good day first big swap meet and I did pretty well I bought high torque starter..$40 clutch fan $5 3 sizes of wire split loom $4 each Drive shaft with the Yoke I needed $10 A/C condensor ( in front of rad) $5
04-25-2010, 10:12 PM | #88 |
man that's a steal, good job!!!!
That little bit of paint makes a big difference. Your truck just looks like a fun truck. Last edited by highperf4x4; 04-25-2010 at 10:14 PM. |
05-06-2010, 07:39 PM | #89 |
well it def is fun and a DD I've been saving up for the install but since then I was given a set of drop spindels that are/where 5 lug...I found out that you can swap the 5 lug discs for the 92 2500 with under 7300lb..they are a direct bolt on bearings/seals everything...the problem is cash flow the disc swap will still require new ball joints and tie rod ends...about $300 in all which is a good chunk of what it will take to install this...Its complete the oil pan will be here tomorrow and it will get the silver paint and the trans pan is going to be black...
I was going for the Harley engine look what do you guys think
05-06-2010, 10:30 PM | #90 |
Holy cow.......................... it's gonna be a funner truck soon.
I didn't know that about the spindles/discs. Thx for the info. |
05-16-2010, 07:33 PM | #91 |
454 MAKES IT ROAR
Well that little lot was an inspiration Jeff...low $$$, I mean £££, is my middle name.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
05-16-2010, 09:03 PM | #92 |
Cant wait for the install and to see those big old tires fry.
05-26-2010, 06:24 PM | #93 |
Grandpa in the rustmobile...
cool build...now, explain some more about the early 90's front rotors?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-26-2010, 06:42 PM | #94 |
the rotor deal is pretty simple if you have a set of CPP/western spindles you can use a set of 1992 2500 ( under 7300 gvw ) rotors this will keep the 6 lug pattern...I have not tried to see if they fit on the stock 71/72 spindle or the newer 73/87 spindles but that could be checked pretty easy by a good parts guy
On a side note I can't wait anymore... staring at the Caddy is killing me I think next week maybe the time to start the install..Just need to get though the holiday weekend
05-28-2010, 02:18 PM | #95 |
Sawzall User
Location: The snow infested Prairies of Canada (aka: Winnipeg, Manitoba)
In your earlier posts, you had a camper in the back of the truck. Does that camper fit between the new wide wheel tubs?
I have a '67 GMC that I was planning on a similar setup for ride height and tire sizes, and just lucked out seeing a picture of yours in another topic. That's the exact stance I'm looking for. I also have a similar pop-up style camper that I want to use, so I'm wondering if I have much room to play on the wheel tubs. I have shorter coil springs and drop spindles already to install in mine, but I might consider installing air bags in the future because I want to use it a daily driver/work truck when I'm done. I'll likely just try to bring the original paint to shine instead of painting. Paint is too expensive.
'67 GMC 910 |
05-28-2010, 04:36 PM | #96 |
No that was a after thought...so I'm looking for an old pop up to drag along now....of course I'm going to bag/tub that too!!!
besides I don't think shorter springs will take a likeing to that much weight...all that being said I think if it was a camper for a Mini truck it may fit. I have 41 1/2" betwen the wheel wells hope that helps Last edited by Hottrucks; 05-28-2010 at 04:37 PM. |
05-29-2010, 01:46 PM | #97 |
Sawzall User
I'll have to measure the camper base and my existing wheel wells to see what room I have for width. I may just tub the truck and modify the camper to fit the tubs. At the rear, I'm going to run 31x12.5R15 on 15x10 wheels. I haven't bought the tires yet, but that's going to be one of the first steps so I can see how wide to the inside I have to go once I swap the diff out for a later 12-bolt with 5 bolt axles.
'67 GMC 910 |
05-29-2010, 02:12 PM | #98 |
trust me go witht the 29" tall tires or they will rub at the top of your wheel wells..unless you move them up too
06-01-2010, 01:15 PM | #99 |
Sawzall User
I might move them up. I was picking those tires as they are tame radial all terrain tread truck tires, and they have matching fronts at 29x9.5 size (Pro-comp). They price out cheaper than using pro-street tires, and have a decent load rating. I have some worn out 31x10.5's I will try out first though. if its too much interference, I will have to go with more expensive smaller non-truck tires. Thanks for the tip!
'67 GMC 910 |
06-01-2010, 05:03 PM | #100 |
well as far as an update to my project I scored a DS fender at the swap meet...I plan to change it out when I do the transplant I have the time but not the cash it seems like thats always the issue.....
