07-18-2009, 11:14 AM | #76 | ||||
Next project: 1970 K10
Re: Glock's new project: "Fred"
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-18-2009, 01:12 PM | #77 |
Where did you find the tool? It looks like a cool little thing to have.
07-18-2009, 02:17 PM | #78 |
It is from Eastwood, but I got it from their eBay store. It was a little cheaper there at $27.
07-18-2009, 02:41 PM | #79 |
This morning, my son and I went to the shop and tinkered for a bit.
I got the rear end pulled out of the burb. This rear has 3.42's and will work beautifully with the 5.3/4L60E combo. I need to get axle seals and bearings, and a pan gasket. Then when the time comes, I'll swap the backing plates off of Fred onto this rearend. Also got both rear wheel well lower rear pieces of sheet metal cut out. This body is very solid, so these saved my about $80 in patch panels. I'll weld these in this winter while the bed is off doing the engine swap.
07-18-2009, 05:38 PM | #80 |
Just fueled up both tanks. Got 14.7 mpg on the tank that was used to go to Denver and back. Not bad considering about 140 of the 177 miles on that tank were above 75 mph.
The other tank is just back and forth to work (almost 40 miles round trip) and running around town. That tank yielded 15.65 mpg!! I plan on taking the top of the fuel pressure regulator off soon and do the quarter trick; that is, putting a quarter or similar sized washer under the FPR spring. That is usually good for a .5 to 1.0 psi increase.
07-18-2009, 06:16 PM | #81 |
Those are pretty nice mpg!
07-18-2009, 06:20 PM | #82 |
X2 on the milage!!
kind of a question out of left field bob... how do you tune the 5.3 after you get it installed and then after you start modding it?
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
07-18-2009, 06:25 PM | #83 |
Don't mean to butt in here, but you have more options with the computer. There are companies that can do just about whatever you want with these computers. Put it on a chip, plug it in, and boom instant hp gain. I know it won't work as much for you out in CA, but they can also go in and take out all the extra emissions stuff that you don't need, and sensors that you won't use too. This is mainly more off of what I have read so far. I'm still in the research stages of this setup as well. So I'm curious to see someone's swap, and their results.
07-18-2009, 08:23 PM | #84 |
John pretty much nailed it. The tune is all in the computer. Along with removing emissions items, they can adjust for tire size and gear changes, shift points, air/fuel ratios, timing.... more than I can type out.
For mine, I am getting one of my ECM's programmed and tuned by Jesse at Wait4meperformance. Jesse has done many tunes for me and some of my friends in the past and has always done me good. This one will get me on the road and moving. After I have all the bugs worked out of it, I will grab another ECM that I have and take it to one of the local shops that has a chassis dyno and tune the snot out of it. This way I can make a pull on the dyno, we can then change xxxxx in the settings, and make another dyno pull until we squeeze all we can out of it.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-18-2009 at 08:23 PM. |
07-18-2009, 09:13 PM | #85 |
gotcha! now if you dont mind me asking how much is the initial tune?
07-18-2009, 09:23 PM | #86 |
For Jesse to rework the harness and do the tune will be $360. If you rework your own harness and send him your ECM, I think the tune will only be $75 or $85 then.
I have no idea how much the dyno tuning will cost though. For all I know, Jesse's tune may be staying in there for a long time!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-18-2009 at 09:26 PM. |
07-18-2009, 10:32 PM | #87 |
I hear that man! Im thinking of the same concept with my 83. actually a 4.8, 5.3, or a 6.0. really I guess bang for the buck 6.0 would be nasty in these trucks with them being lighter. mileage wouldnt be too bad. but a 5.3 is more readily availiable it seems.. keep on
07-18-2009, 10:39 PM | #88 | |
the dyno tune on the goat was $450 if i remember right. kinda pricey concidering how bad i still get heat soak... sorry for all the ???'s buddy... right in the middle of your thread and all...
07-18-2009, 10:43 PM | #89 |
No worries here, I like getting the info out!
By reworking, I mean to make the engine harness a stand-alone harness. It will have like 4-5 connections that I will need to make to the truck for it to work.
07-18-2009, 10:45 PM | #90 |
bad thread jacker you! lol
07-18-2009, 10:48 PM | #91 |
07-18-2009, 11:12 PM | #92 |
thread jack finished...
unless i can think of another question! oh yea 2 more, so for the fuel lines just use fuel injection hose and clamps, acdelco "in take" pump and sending unit w/ a high pressure switching valve? will i need the corvette fuel filter to regulate the pressure also?
07-18-2009, 11:22 PM | #93 | |||
07-19-2009, 08:05 AM | #94 |
Bob, you are the man! thank you!!!
07-19-2009, 12:17 PM | #95 |
Great info man! Now I'm wishing I would have gone the LSX way on mine this time. Oh well defintately the next truck!!!!
Won't be real soon though. Don't think my wife will be so forgiving on the next one!!! |
07-21-2009, 09:40 PM | #96 |
Can you say..... "like butta??!!"
I got the door alignment tool today. Ran to the shop like a little kid when I got home to try it. Stuck it on the truck, use my long Snap-On 1/2" ratchet, and gave it a good firm pull up. Took it off and..... butta! Take two fingers and give it a fling, and it shuts tight! Saweet!!!!!!!
07-22-2009, 07:51 AM | #97 |
That's pretty cool. I'll have to get me one of those!
When I go to get one what do I look for? Butter Tool, or Butta Tool? Last edited by JohnC; 07-22-2009 at 07:52 AM. |
07-22-2009, 08:05 AM | #98 |
Low & Fast!
That is very cool Bob!! So are you going to sell that tool now. Hint Hint for half price, it has been used.
07-22-2009, 08:13 AM | #99 |
07-22-2009, 08:18 AM | #100 |
Slots go on anything!
Glad that worked, Bob. Now swap the engine already!
