Old 04-26-2011, 10:43 AM   #76
low_84_inchaska
low_84_inchaska's Avatar
Re: project shorty 84
exhaust is in...summit turbo mufflers xpipe kit and custom bend outlets.
i welded everything except clamping on the mufflers and bolting onto the collectors.
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 04-26-2011, 09:39 PM   #77
my4by2
my4by2's Avatar
Looking great so far man - keep the pics coming! LS swaps always the way to go!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-26-2011, 11:02 PM   #78
Nobaddaze
Nobaddaze's Avatar
good job, truck looks great. how much adjustment is in the dirty dingo mounts??
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 04-27-2011, 09:41 AM   #79
low_84_inchaska
I am gonna guess i would say almost 3.5-4"....you can check out their website...very nice mounts.
Old 04-27-2011, 09:43 AM   #80
low_84_inchaska
i took it for another drive with the exhaust on...i am not one to beat on cars but i did a roll on and omg this thing is gonna liquify tires if i wanted it too.
next step is pulling it out in the driveway and cleaning that rear frame off and epoxying the frame to make back to black.
then it is blocking time...yayy......
Old 04-27-2011, 10:22 AM   #81
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Wow, I really like that exhaust. Any issues with heating up the fuel tank?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 04-27-2011, 11:08 AM   #82
Nobaddaze
Nobaddaze's Avatar
what did you end up doing for a trans crossmember? Do you have any pics? When you moved the motor back did you have to just drill new holes in the frame or did you modify your crossmember. Sorry if these are stupid questions.
My Build
Old 04-27-2011, 11:39 AM   #83
menace121978
menace121978's Avatar
nice job man!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-27-2011, 01:44 PM   #84
low_84_inchaska
i dont think i will have any issues with it heating the tank, it is far enough away.
the crossmember was custom made, i will get pics of it for you, made out of sq. stock and plating...new holes drilled in frame and bolted on.
Old 04-27-2011, 02:19 PM   #85
harnalien
TruckincrazY
harnalien's Avatar
Originally Posted by low_84_inchaska View Post
alien- the schoenfelds work great...little tight on the drivers side a arm but i have the dingo mounts so i just slid the motor back and the issue was solved.
you will love them did you get the uncoated or coated ones? i got the uncoated and did the eastwood titanium high temp header coating on them.
Good to hear! I ordered mine and should have mine together within the next few weeks. I just got the painted ones. I have the dingo mounts as well and they set the motor back pretty far. You welded the headers to your pipes? I am trying to decide on how to do mine. I have 2.5" exhaust now an the collectors are 3." sounds like you're having fun with it, good job!
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 04-27-2011, 04:10 PM   #86
low_84_inchaska
get some reducers from summit and use band clamps...very good connection
Old 06-04-2011, 05:26 AM   #87
1984 t type
Hey what did you wind up using for the trans linkage ? And will those dirty dingo mounts work with the ac compressor in the factory low mount position ?
1987 Buick Grand National
2018 Road Glide Special
1984 t type is offline   Reply With Quote
Old 07-07-2011, 02:43 PM   #88
low_84_inchaska
got some wheels and tires for my truck...
details as follows.
The wheels are MB motoring 22x9 with Yokohoma Parada Spec X tires mounted on them. Tires are 265/40R-22.
should be pretty cool.
Old 07-07-2011, 02:44 PM   #89
low_84_inchaska
i used the lokar linkage and did a little "bending" just a little to make it shift into all gears but it was almost a direct bolt on, very easy. I didnt have ac so i dont know on the compressor fitment. i assume it would fit.
Old 10-04-2011, 07:49 PM   #90
Ford Assassin
Ford Assassin's Avatar
i got them from schoenfeld..they are called ls truck headers.
I wonder if these would would on a '73-'91 4x4...
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 11-17-2011, 09:10 AM   #91
low_84_inchaska
oh i am sure they would.
Old 11-17-2011, 09:15 AM   #92
low_84_inchaska
sorry for the long long long delay on updates to this post....i finally gave up on the body man crap...not my m.o. A good friend of mine Josh builds cars and offroad trucks and he felt pitty on me and decided to take my truck on at a very discounted friend deal. He preceded to take out all my body filler and re-repaired all my metal work lol..this is his quote "if your going to do body work,,,,dont....call me"
He shaved the door handles, marker lights, locks, tailgate and anything else that could be shaved. Installed door poppers, and a tailgate handle relocation kit. The doors were pretty rough he has spent some time on them. The cab will be ready for paint on thanksgiving weekend. I will get some pics of the cab on here then when i go down there.
The color i picked was Kustom Shop hot rod flatz midnight blue pearl....i couldnt decide on a paint scheme so once i decide we can just scuff this stuff up and paint over it. I changed my mind on the mulsanne blue metallic.
Old 11-17-2011, 09:08 PM   #93
harnalien
TruckincrazY
harnalien's Avatar
Lookin' forward to pics!
Old 12-05-2011, 11:58 AM   #94
low_84_inchaska
checking fitment of 22"s
Old 12-21-2011, 04:33 PM   #95
made2drag
made2drag's Avatar
looking forward to more pics
made2drag is offline   Reply With Quote
Old 01-12-2012, 10:46 AM   #96
low_84_inchaska
cyber grey metallic is the color, i like the color on my ss so i decided to do the truck the same.
the doors are done, the cab should be done soon, and then to wetsanding they go.
Old 01-12-2012, 10:47 AM   #97
low_84_inchaska
i have more that wont upload
Old 09-24-2012, 12:50 PM   #98
greatdane
greatdane's Avatar
Nice work! Do you have any new pics? I am thinking about painting my 84 GMC Cyber Grey....
1993 Silverado C2500 Single Cab LWB
2007 Chevy Silverado 1500 Crew Cab LTZ 4x4
1974 AMC Matador Coupe - The Mat
greatdane is offline   Reply With Quote
Old 02-03-2013, 02:19 AM   #99
85/05Silverado
85/05Silverado's Avatar
Nice build, do your headers hang below the frame rails ?
Hows it goin Eh!
1985 Chevrolet C10 Silverado SWB-395 Stroker 490hp,700R4 12 bolt 3:73 posi,inferno red crystal pearl coat with black ralleystripes,custom leather seats, carbon fiber gauges
2005 silverado 1500 ecsb, Z71, 33x12.5 dick cepek
http://www.cardomain.com/id/Kearney
Stephen
85/05Silverado is offline   Reply With Quote
