Old 12-06-2009, 11:01 AM   #76
68 TT
Still plays with trucks
68 TT's Avatar
Re: 89 1500 parts ????
Originally Posted by Lo78 View Post
I took the inline out today. also welded in all the stake pockets on the bed. I was thinking about the ac unit out of the 89 , will that work in my truck? Thanks steve
It's possible the firewall forward part will fit but I highly doubt any of the under dash or control sections from the 1500 will fit a square body.
Aftermarket under dash assembly used with the factory 1500 compressor, engine mount brackets & condenser would be your best bet.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-06-2009, 02:14 PM   #77
Lo78
Ok thanks 68tt
Lo78 is offline   Reply With Quote
Old 12-06-2009, 08:45 PM   #78
Lo78
hey 68tt my 78 came with factory ac so can i hook the 89 ac unit up to the 78 ac underdash and control sections thanks steve
Old 12-06-2009, 09:30 PM   #79
cjracing15
cjracing15's Avatar
Yes you can. I did it on my 86. You will need the hoses from a 1989-91 suburban with out rear air and if you use your 89 brackets it's a bolt in.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 12-07-2009, 12:33 AM   #80
Lo78
WHATS WRONG WITH WITH THE HOSES FROM THE 89 1500 thanks steve
Old 12-07-2009, 12:33 PM   #81
68 TT
68 TT's Avatar
If I remember right they switched sides of the truck that the compressor was mounted on.
The compressor design is different too so the connector on the back is most likely different.
