Old 03-15-2010, 08:37 AM   #76
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 572 update
I have one of those wrenchs!!! but I dont need the rubber glove I tough it out without them???
funny how much time the little things take....
Hottrucks is offline   Reply With Quote
Old 03-15-2010, 08:55 PM   #77
handsomerob
handsomerob's Avatar
Re: 572 update
Well sent the truck out to the Welders today and got the Ladder bars finish welded. They had it done in about an hour and a half.
handsomerob is offline   Reply With Quote
Old 03-15-2010, 10:12 PM   #78
highperf4x4
Re: 572 update
That looks great!
highperf4x4 is offline   Reply With Quote
Old 03-18-2010, 07:17 PM   #79
handsomerob
Re: 572 update
well didn't get much done today, but I did modify the shifter linkage. Here are a few pics.
original location:
Modifications:
Finished product:
Old 04-01-2010, 01:26 AM   #80
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: 572 update
What ever happened with this? Is it terrorizing the streets yet?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 04-02-2010, 11:10 AM   #81
handsomerob
Re: 572 update
Sorry for the delay in posting but I've been busy and a little under the weather lately, But I figured I could throw up a few more pics. I had a chance to install the accessories, put in new engine mounts, install the new master/booster, Starter, etc. I installed a Vaccuum pump for the master but don't have a pic, and I also install an electric fuel pump but don't have a pic either.
But here are some pics I do have.
Old 04-02-2010, 11:24 AM   #82
QKENUF4U
QKENUF4U's Avatar
Re: 572 update
gettin close to firen that monster up !!!!
QKENUF4U is offline   Reply With Quote
Old 04-02-2010, 11:59 AM   #83
capev86
Re: 572 update
that is a beautiful truck with no outward cosmetic changes......total sleeper. it says on the options list that it has the custom camper equipment. what pieces did your truck come with (i see small mirrors). if i went to the trouble of putting a huge motor like that in a truck, it would be for SERIOUS towing duty as i would rarely have the chance to use all that power in any other venue. thankfully you have a 3.54 gear and overdrive...i don't want to imagine the amount of high octane gas you will be burning through in that truck. i am putting an 87 octane friendly 406sbc in my 72 burb. do you have the factory tach and vac gauges to go in or are you going with an aftermarket cluster?
capev86 is offline   Reply With Quote
Old 04-02-2010, 05:46 PM   #84
handsomerob
Re: 572 update
Well actually we are switching the gearing to 3.73 with a detroit locker, and we are keeping the factory guages, using a Cable X system to maintain the stock speedo with the Hydramatic (4L85E)
The Driveshaft was just ordered on Friday, going with a single 4" Aluminum driveshaft, I will need to modify the hanger crosser to clear the new shaft, not by much, but slightly modified.
I'll try to get more pics up as things go.
I have a huge order comming from LMC and Summit, I'm still anxiously awaiting my Tranny controller from GM, no ETA on that part yet.
I'll keep you all posted.
Old 04-07-2010, 06:10 PM   #85
handsomerob
Re: 572 update
Well I got some more pieces to the puzzle, here are some pics:
Old 04-07-2010, 09:16 PM   #86
Hottrucks
Hottrucks's Avatar
Re: 572 update
I see you went with an electric fan can you clue us in on that?? I just my mounts today for my swap hope to be chasing you down the road soon too!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 04-07-2010, 09:21 PM   #87
handsomerob
Re: 572 update
The electric fan is actually from LMC, it has a thermostat that can be manually set and has the typical heat probe (torpedo) that goes into the hot side of the rad.
I'm hoping that the one 15" fan offset to the hot side of the rad will be enough to cool this monster.
Old 04-07-2010, 09:23 PM   #88
Hottrucks
Hottrucks's Avatar
Re: 572 update
kool I'm going to need to do something myself keep me posted
Old 04-08-2010, 07:51 PM   #89
handsomerob
Re: 572 update
Well got a few more parts in today, did some more work, here are just a few pics of the new parts.
Old 04-08-2010, 09:00 PM   #90
Hottrucks
Hottrucks's Avatar
Re: 572 update
Yummy!!!!!! I love Eaton!!
Old 04-08-2010, 09:32 PM   #91
handsomerob
Re: 572 update
Yeah big bad Detroit Locker, gotta send out the axle blanks I got to get them machined to fit.
Got all that stuff from Randy's Ring & Pinion
Great service.
Old 04-13-2010, 07:19 PM   #92
handsomerob
Re: 572 update
Well been doin some more work on the '72 and things are going well, here are a few more pics.
Tranny Cooler installed
Locker
Pinion
Fuel Pump and Filter
Vaccuum Pump
Old 04-13-2010, 07:29 PM   #93
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: 572 update
Looking good!
Can't wait to see a video of it firing up!!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-14-2010, 05:43 PM   #94
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: 572 update
Very impressive - gonna be an incredible ride!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-14-2010, 05:54 PM   #95
Quackaddict
"Hooked on Quack"
Re: 572 update
Very Cool.
Where did you get the brake booster and if I can ask how much (if you don't want to say you can pm me as well), mine needs replacing.
Quackaddict is offline   Reply With Quote
Old 04-14-2010, 06:16 PM   #96
handsomerob
Re: 572 update
Originally Posted by Quackaddict View Post
Very Cool.
Booster/Master combo was from LMC and I believe it was like $299.99
Old 04-14-2010, 06:34 PM   #97
handsomerob
Re: 572 update
Well did some more work today, got the metering valve all prettied up. Then I took a look behind the dash . . . it wasn't a pretty sight.
Metering Valve
Cluster Damage
Cluster Repair
Cable X system
Front of cluster
Old 04-14-2010, 09:07 PM   #98
handsomerob
Re: 572 update
Well as you can see I have gotten into the "scarey" part of this project I say "scarey" as most people find electrical a nightmare. I however am well versed and have no issue with this, However, I was wondering if anyone has a wiring schematic for a 72 C20 as over the last 38 years there have been a few hack jobs etc. I want to streamline the wiring down to the necessities. I have a lot more wiries to bring in thanks to the tranny controller etc.
So if anyone has a shematic for a 72 C20 I would be greatful to have a copy.
Thanks in advance.
Old 04-14-2010, 09:51 PM   #99
highperf4x4
Re: 572 update
Edit: Bandwidth Restored.
Old 04-14-2010, 09:53 PM   #100
highperf4x4
Re: 572 update
Let me know when you save those to your hard drive or if they're not what you need so I can remove them from the post.
