#76 |
VA72C10
![]() Join Date: Mar 2008
Re: My 68 C10 Blowen LS2
sorry bout the issues...but it'll be fun when it's all together
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#77 |
68 C10 LS2,
Any insight on the install process for the LS2 V-8? Did you have to make custom motor mounts, use a custom oilpan, custom headers, or what? I have a '71 C10 that I already installed a TH700-R4 with lock-up converter (did the slide the trans mount back install like you), now I'm thinking about upgrading to an LS engine from a car or truck. Obviously I'll need an electric fuel pump and electric cooling fans as the LS-series engines have no mechanical fan ... but what else am I in for. With a 1967 Camaro RS convertible I built years ago, I upgraded to an LT1 engine with a factory computer ... but had to turn off the VATS (Vehicle Anti Theft Sensor) to make the system jive with the old Camaro. Any funny stuff that you had to do with the computer? |
#78 | |
#79 |
If I wanted to install a new LS engine (such as 2008 or newer) and wanted to eliminate the factory throttle-by-wire setup, what mechanical throttle-body would I use (stock from another year engine, aftermarket or what)?
#80 |
Must have running video of this beast when its fixed. Sorry about your luck.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#81 |
I dont know if you can. All the sensors in the motor are different from 99-02, 03-06/early07, and late07-present.
#82 |
chevy runs deep
sick
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
#83 | |
#84 |
#85 |
Kiwi, why would you want to eliminate the electronic throttle? It makes setting up cruise control real easy, can be tuned how you like it. And the newer throttle bodies are pretty good size.
#86 |
68 C10 LS2 (or anyone who knows),
It has been a busy weekend as I am in the midst of getting a brand new LS3 (426 hp) pulled from a 2010 Camaro SS. I learned that GM sells a "run kit" that includes most everything needed to wire a new LS engine to an older vehicle including a proper computer, wiring harness, and a special gizmo that attaches to an old-school throttle that converts it for use with a drive-by-wire throttle system. I plan on installing the engine in my 1971 C10 but have a few questions: 1. What motor mounts did you use ... and are you happy with them? 2. Did you retain the factory A/C pump from the new engine ... and if so, were there any clearance issues with the stock frame? 3. Did your TH400 bolt up to the back of the new EFI engine without problems? (I already retrofit a TH700-R4 to my truck and I'm hoping that the trans will bolt up to the new LS3 engine without problem.) John |
#87 |
Here is some more LS engine swap info that I have found ...
LS controller kit include the following items: 19166573 Engine Harness 12576410 Mass Air Flow Meter 19166574 Mass Air Flow Meter Mounting Boss 10367117 Accelerator Pedal Assembly 12581966 Oxygen Sensor (Qty 2 Per Kit) 15156588 Oxygen Sensor Mounting Boss (Qty 2 Per Kit) 19171935 Instruction Sheet https://store.gmperformanceparts.com...!--19201327--> +++++++++++++++++++++++++++++++++ Motor mount kit to swap a new LS engine into an older musclecar/truck: http://paceperformance.com/index.asp...OD&ProdID=9072 |
#88 |
Well i finally got the motor running, took it out driving and the tune is WAY OFF!!!! I cant give it more than 1/3 throttle and the gas mileage SUCKS!!! I mean its so bad i drove it 10miles and burned 6 gal of E85 (but it will it 10 psi of boost at 3000rpm). So now where to take it for the tune!?!?!?!
#89 | |
Big Red - Now its a SWB!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#90 |
First time in this thread. Wow, truck looks great, too bad you're having so many issues. Where in MN are you at? I'm by fairfax. I think you're almost best off working your own tune out with EFI Live or HP Tuners. That way it's how you want it, and you can tune it on the street, track, dyno, etc and not have to take it to a guy every time.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#91 | |
needs more $$$
1970 2wd Blazer |
#92 | |
#93 |
I dont know about alcohol or how gas mileage works with that but to run E85 i do know its 30% more fuel than reg gas. Before i was getting about 15-16mpg with the old setup so i would guess that i shouldnt be less than 10mpg.
#94 |
Well here you go guys and gals. Pics of the new motor setup. I still have to make a new intake tube so it stops sucking hot air from the radaitor. Sorry no video's of the motor running since the tune is so far off.
#95 |
![]() Join Date: Apr 2005
Looks sweet! Are you running a boost referenced fuel pressure regulator?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#96 |
#97 |
VA72C10
very nice!!!
#98 |
I just want to thank everyone that has commented on my thread!!!! All of you on this site have given great support to my project. I would have given this whole thing up a while ago and moved on to something different if it wasnt for all of you (so you all owe me the money i have dropped into this thing now!!!!! LOL)!!!!!! Thanks again!!!
#99 |
We're here to help!
#100 |
Well i havent logged in in almost a month, been very busy. So heres the update on the truck. I bought HP tunners and now able to send the tunes via e-mail to my tuner in Vegas. I got a new tune finally yesterday, it runs a 1000x's better but still no where near its full power. I can now give it full throttle and the highest boost level ive seen so far is 16 psi!!! I dont know of any root style blower that hits that high of boost (a least i havent heard of any).
