Old 01-09-2014, 03:56 PM   #76
ymerej71
ymerej71's Avatar
Re: Bagged or Lowered on 15" Rally wheels?
Originally Posted by Lambchop76 View Post
What size are the dropped spindles? Perfect stance on this and want my 87 to sit this way. I too have 8" and 10" truck rallies. 295/50s rear and going with a 255/60 front
Lambchop76, I'm not sure on the drop of the spindles because they were already on the truck when I got it. I'm guessing probably 2.5" since that's pretty common drop on these trucks, but there's really no way of knowing for sure.
Although I'm working towards getting my truck closer to the ground; this is a good everyday ride height. My only real clearance issue are the long tubes headers that hang underneath my framerails. Speedbumps catch them everytime! Haha.. Good luck with your build!
ymerej71 is offline   Reply With Quote
Old 01-09-2014, 04:21 PM   #77
Lambchop76
I appreciate the info, one last question. With the 275s up front, do they rub at all?
Lambchop76 is offline   Reply With Quote
Old 01-09-2014, 05:44 PM   #78
ymerej71
ymerej71's Avatar
The 275's are a 28" tall tire and the tops of the tire will rub on the inner fenders when I get caught off guard and hit large dip in the road. They don't rub hard enough to damage the tire but you can see the rub marks on the fenders. Some of the rubbing could probably also be attributed to worn shocks that aren't dampening the suspension travel as they should. If I was getting new tires I'd go an inch or so shorter and it'd be fine, but I already had these and didn't want to spend the money. Generally the clearance isn't an issue, you just have to drive with an awareness of the type road ahead of you... Haha!
Old 01-09-2014, 05:53 PM   #79
Lambchop76
Ok awesome!!! I have a pair of fairly new 255/60s I thought might be too big.
Old 01-15-2014, 08:20 PM   #80
Low_Life86
Low_Life86's Avatar
heres mine its static on stockies
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
Old 01-15-2014, 09:30 PM   #81
ivorton74
ivorton74's Avatar
mine
ivorton74 is offline   Reply With Quote
Old 01-16-2014, 12:03 AM   #82
Toyopro
Toyopro is offline   Reply With Quote
Old 01-16-2014, 10:47 AM   #83
Desert1957
Desert1957's Avatar
Name:  Blue truck..jpg
Desert1957 is offline   Reply With Quote
Old 01-16-2014, 10:08 PM   #84
BP87GMC
BP87GMC's Avatar
Mine
BP87GMC is offline   Reply With Quote
Old 01-16-2014, 10:19 PM   #85
BP87GMC
BP87GMC's Avatar
Don't you wish yours was upside down,lol?
Old 01-22-2014, 12:13 AM   #86
Jlo1986
Jlo1986's Avatar
Here's a couple pics of my '79 GMC...
What size tires?
Jlo1986 is offline   Reply With Quote
Old 01-22-2014, 12:18 AM   #87
Jlo1986
Jlo1986's Avatar
Originally Posted by Malo83 View Post
This is my 83 with a 4/5 drop and 15x8 15x10 rallys
What size tires are you running. Im going to purchase some Rally Wheels, 15x8 front and 15x10 rear. Im think 265 front and 295 rear.Name:  Diegos 1986.jpg
Old 01-22-2014, 12:24 AM   #88
Low_Life86
Low_Life86's Avatar
Originally Posted by Justin36 View Post
What do you have to do to make the 15 inch wheel work in the front? My truck wont even roll with rallies or 15s period
its weird i have 15 inch rallys with 3 inch drop spindles and 3 inch lowering springs and mine fit with about 1/8 inch clearance
Jeremy
Low Life
Old 01-22-2014, 02:11 PM   #89
bdiamond
Mechanicals are nearly done. Almost time to start the body...
bdiamond is offline   Reply With Quote
Old 01-22-2014, 02:37 PM   #90
EddiesLow77
EddiesLow77 is offline   Reply With Quote
Old 01-22-2014, 02:40 PM   #91
EddiesLow77
Old 01-22-2014, 02:43 PM   #92
EddiesLow77
These pic are alright came out kinda small
Old 01-22-2014, 02:54 PM   #93
Lambchop76
What drop and tire sizes are you running?
Old 01-22-2014, 04:56 PM   #94
239Design
Here is my 84 I just picked up and installed a 3/5 drop on. It has the factory rallies with 275-60's with the high hat conversion clips we also installed
239Design is offline   Reply With Quote
Old 01-22-2014, 07:08 PM   #95
EddiesLow77
I cut the coils like a 1 1/2 turn it was crazy low and the back was a flip kit with lowering blocks
Old 01-27-2014, 11:34 AM   #96
BP87GMC
BP87GMC's Avatar
Try a different pic.
Old 01-27-2014, 01:54 PM   #97
Malo83
Cruzzzn' Vet
Malo83's Avatar
Originally Posted by Jlo1986 View Post
What size tires are you running. Im going to purchase some Rally Wheels, 15x8 front and 15x10 rear. Im think 265 front and 295 rear.Attachment 1203995
I'm running 245/60 front and 295/50 rear.
Malo83 is offline   Reply With Quote
Old 06-06-2014, 08:59 AM   #98
BigMike608
BigMike608's Avatar
4.5/5ish drop. front: 15x7 (235/70/15) and rear: 15x8 (275/60/15)
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 06-06-2014, 09:55 AM   #99
mattcrp1
mattcrp1's Avatar
Hey BigMike608, do you have any side shots of your 15x7,15x8 set up? I have a couple of 15x7's and one 15x8 my self and have considered this but could never find a pic of it on a truck. what drop do you have?
thanks,
Matt
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 06-06-2014, 10:04 AM   #100
BigMike608
BigMike608's Avatar
thanks,
Matt
I don't have any additional pics but hopefully I can find some time to take some this weekend for you. My drop specs:
Front:
- 15x7 rallies
- 235/70/15 tires
- McGaughy's 2.5 drop spindles
- Cut 1 coil off factory springs
- Stock shocks
Rear:
- 15x8 rallies
- 275/60/15 tires
- Western Chassis rear shock extenders
- Stock shocks
- specialtyrealty (forum member) 5" drop axle brackets
- c-notch
