#76 |
Tripple Five Fanatic
Re: Be Gentle. . . I'm an Amateur.
One quick thing I noticed is that you should remove the paint around the material you're going to weld, I use a flap disc or wire wheel to clean then weld but sometimes I tend to forget to do it.
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#77 |
Certified Car Nut
Yeah I assumed he was doing that. Clean rust free metal is what you should weld. I clean both sides when possible.
#78 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice job on those tail lamps! They look excellent for a beginner.
I really like using the small flap wheels on a die grinder for shaping and smoothing steel, wood, body filler, or what ever. You can use them on something else and try to shape it the way you want and then use it for your hard to get places. Here are some online. I get mine at the local body supply warehouse. http://www.thefind.com/hardware/info-1-inch-flap-wheel
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-15-2010 at 07:52 PM. |
#79 | |
In the meantime, I am going to HF tomorrow and see if I can find out what the heck is hanging off the end of that sander pictured above. Clay |
#80 |
Basically it is a die grinder with an attatchment for a mini belt sander on the head of it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#81 |
Registered Chevy Owner
Nice build. Keep it up!
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#82 | |
![]() before i bought my 51, i never went to harbor freight this much before.. now, im there atleast a couple times a month. their cheap but effective cutoff wheels, flap discs, cheap grinders, etc.. have been invaluable in getting my truck project going. |
#83 |
Well, I made my monthly trek to HF this afternoon and found this gizwiz. The air unit and the belt sander are sold as one. If you look it up on the HF website, 97055, they are on back order and priced at $24.99. At my store, there are 4 (four) on the shelf priced at $24.99. Will get my 20% coupon and go back tomorrow. Thought you might like to know. Clay
#84 |
Thanks for all the compliments and advice. I've never heard of 90% of the tools you guys just showed me. I'll look into them later this week. Thanks again.
-MG
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
#85 |
I looked for a pedal rod extension all over town and ended up finding one online but it was like $40. I barely had to go forward. The pedal actually worked perfect right on the edge of the rod.
![]() I was wondering if anyone had any ideas as to why this would be a bad idea? It just seemed to make sense, but I could be overlooking something. I just stacked two washers and welded them together. Then ground them down to make a flat side and welded it to another pair of washers. ![]() It fit really well. Any suggestions as to why this wouldn't be safe? It feels really sturdy to me and it bolted in perfectly. ![]()
#86 | |
![]() Join Date: Nov 2008
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#87 |
Not sure I would do that, being that is the most important part of your whole baby! I would cut the rod, find some tubing that has the same inside diameter. I would make the tubing overlap an 1" on each side, weld it up good and even if 1 weld broke, you could still stop the truck! Just me thinking overkill!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#88 |
chevy runs deep
Nice build
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
#89 |
![]() Join Date: Apr 2008
Great progress for a first timer.
I would agree that you really should look around and find the right part for your braking system. You don't want to find out in a panic stop if your welds hold or not.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#90 |
I'd cut the rod and lengthen it with a piece the same diameter.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#91 |
I'm with bluejeep. You can also put on an exterior sleeve for extra strength. Those washers will flex over time.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 12-23-2010 at 02:07 PM. |
#92 |
Two things I refuse to cut and splice... Brake systems and steering systems.... all others are fair game!
I would seriously consider rethinking the double washer idea... if you had to... lay it out on a piece of 1/4" plate and drill and cut the part out... no joints, no welds... and always overbuild... you have no idea how much stomp pressure you'll put on that in an emergency or fatigue failure over time... Something else to consider... that rod isn't supported and will flex up and down given the opportunity... with a connector such as that, it will rotate up or down as that rod flexes and you won't get the horizontal push on the booster you're looking for. Better safe than sorry! My 2 cents... Ted. PS If you are using the S10 brake booster and the S10 pedal and support... it should bolt right up!
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 Last edited by Thadious; 12-23-2010 at 02:29 PM. |
#93 |
Thanks for all the replies. I wasn't sure about the homemade extension, it looks pretty unanimous to get rid of it. I was more worried about it rotating like Thadious mentioned that the actual welds.
I think I found a double clevis that will do the trick and won't require any welding, that way I know I won't have to worry about it. It's rated at 3900lbs. I'm assuming my dinky welds weren't rated at that. Thanks again for all the quick replies.
#94 |
Along with what Thadious said, what are we missing? I'm assuming the pedal and the booster aren't out of the same truck, is that true? On mine, I noticed that the 95 s10 booster wouldn't work with the 90 pedal, so I used everything off the 90 and it worked as expected.
#95 |
The booster is from the blazer that I got the rear axle out of. The pedal assembly I had to go pull from an 89 s-10, I didn't get the booster out of it. I assumed the blazer booster would be the same.
#96 |
Finished getting my shifter installed. I went with the Lokar Nostalgia Shifter 15". I wish I could go back and tell my geometry teacher that I actually used the pythagorean theorem. . . ha.
![]() I sat it in there just for some pics. ![]() ![]() I welded a lip around the edge so I can just bolt it to the floor and make for easy access in case there is something that goes wrong with the neutral safety switch on the shifter.
#97 |
Nice work.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#98 |
Looks good
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#99 |
Thanks guys.
I've been out of town for about a week and I'm ready to get back to work on the truck. Hopefully I can get the emergency brake in this week.
#100 |
I'm trying to find a spot to mount the s10 e-brake. I don't know if I want it to stay here or if I should get a hand operated handle instead of the s10 foot e-brake.
![]() My cousin came over and we started trying to figure out where we are going to put the computer, battery, etc. ![]() It's about to snow and sleet here so I moved some stuff around so I could park my car in the garage again. I moved the bed onto the frame and snapped a pic just to get an idea of what it would look like. I'll have to move the bed floor up a couple inches before I'm done. I'm definitely glad I lowered the cab another two inches a few weeks ago. ![]()
