Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-13-2011, 01:23 PM   #76
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 67 Frankenstien build
Yeah my roughcountry 4" lift looks like a lot more than 4"s
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-17-2011, 08:40 AM   #77
67gmcstepside
with lift
pre-lift
Very happy with the 2.5 skyjacker lift. Seems just enough and the 33's don't rub! The back u-bolts seem to wide for the leafs but I'll deal with that later.
67gmcstepside is offline   Reply With Quote
Old 10-17-2011, 09:21 PM   #78
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
It looks really good! I like it a lot!
Tony
Old 10-19-2011, 06:35 AM   #79
67gmcstepside
Thanks Tony the best part is no tire rubbing. I need to fix some cowl drainage issue then it's time to install the carpet and finish off the interior. Next will be to replace the old 2 bl with an edelbrock 600 and performer manifold. I am starting to see the end in sight.
Old 12-28-2011, 09:02 AM   #80
67gmcstepside
Well after it's first real test drive I discovered 3rd gear syncro was shot. So out came the tc and the trans. Since I had to pull both I decided to go with a np205 tc this time around. Getting the trans and tc back in solo was a challenge. Dropped the tc cross member an inch and buttoned everything backup. Ordered a new drv shaft from Tom Woods which should arrive today, I hope. I am having the front drv shaft lengthen by mr driveshaft another 3 inches. So I am almost back to where I started 2 months ago. Still need to get an new carb and 4 barrel manifold. Pending tasks
Get exhaust system secured (lmc dual)
Cut new holes in high hump
Install seat belts
Reinstall carpet and seat
Install pass mirror
Find a stereo and install
Convert to cable throttle
Scrape up some money for rear bumper and headline trim.
Pics to follow once my drv shaft comes
Old 12-29-2011, 12:39 AM   #81
mjensen
mjensen's Avatar
Your truck looks awesome!
That sucks about the trans.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-29-2011, 07:27 PM   #82
67gmcstepside
Thanks Jensen.. Well at least I know now that I have a good trans. can't wait for a test drive above 10mph.
Old 01-02-2012, 06:23 PM   #83
Chevymaniac
The lift kit you installed really adds to the look. I don't like tall lifts on trucks, but that's just my prefacence. Your truck is looking great. Are you posting any video when you do the test drive? Pics are good, but video is 100 times better. Keep the updates coming.
Chevymaniac is offline   Reply With Quote
Old 01-02-2012, 07:14 PM   #84
67gmcstepside
Thanks chevymaniac, that's a great idea to video the next test drive. Had it out once to find that my trans 3rd gear sycro was shot. Rebuilt the trans and installed a np205 instead of the original 221. Finished the exhaust this weekend and will post an update soon and will video it's next test run.
Old 01-09-2012, 04:26 PM   #85
67gmcstepside
Had some nice weather in NJ so I got a few things done to the truck. Installed the rest of the exhaust from LMC. Fits now that I have the NP205 in instead of the T221.
Finished the insulation:
Installed the carpet, seat and seatbelts. Getting close. Need to get emergency brake cabling bought and installed, install the front sway bar from CrazyRay when it arrives and order the correct rear bumper. Still searching ebay for a edelbrook 1405/6 and manifold. Many of them out there but trying to keep under 250 for the pair and dont want to have to rebuild.
Old 01-10-2012, 12:00 AM   #86
mjensen
mjensen's Avatar
That's looking great! I can't wait until mine is that close.
Also, thanks again for hooking me up with those T221 parts!!!
Mike
Old 01-10-2012, 09:27 AM   #87
67gmcstepside
Glad I had them available for you jensen. The TC's are going to scrape soon so let me know if I should out aside anything else.
Old 02-27-2012, 03:28 AM   #88
BuildinA68
BuildinA68's Avatar
are your rear springs a multi leaf set or just two springs? i have a 68 k10 i am doing right now too, and i bought the 2.5 skyjacker kit from sumitt with the blocks and now i am haveing second thoughts about buying the rear springs. mine is the just the 2 spring leaf. also swapping out the t221 and 3 speed combo for the sm465 and 205.
Ryan
BuildinA68 is offline   Reply With Quote
Old 02-27-2012, 03:30 AM   #89
BuildinA68
BuildinA68's Avatar
btw the truck looks NICE!! i am going to paint mine similar, but the medium blue for the trucks.
Ryan
