Re: maxxy's 81 bagged c10 build
Like gray said above, 6011 will work
And also as stated above you need to keep moisture out of your rods. They make rod ovens to get the moisture out, I don't see why you couldn't use a regular kitchen oven on a low setting to heat them up before you use them. Your welds, from the pics, look cold (not penetrating well). What do you have your welder set at? I think you need to turn it up. Here is some info I found with a quick google search http://www.thefabricator.com/article...-6011-and-7018 It says the 7018 is easier to run and needs to be kept moisture free. Posted via Mobile Device
CHEVY ONLY
^^who I am^^ what I say>
I usually use 6011 as a universal rod, it works good for most anything. Honestly the 7018 is harder to work with. a C pattern is your best bet, or a circle pattern. bump up your amperage and get some scrap steel to practice on, and run bead after bead after bead until you perfect your skills. This is how i started off and how I have taught a few people also. good luck
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
It's been a while since I've updated but I've been busy with high school basketball in full swing. I got a little work done today, I tacked together my front mount crossmember for my wishbone 4 link.
![]() Posted via Mobile Device
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
looks cool, i like how the angles look in the middle. And I hear ya about basketball, its startin to get crazy around my school with it. I never got into that sport, despite me being 6'3", my back is too messed up and im too busy workin on my junk to play anything. haha
Lol well I love the sport, but even if I didn't, the school would probably force me to play, mainly because I'm 6'8". Haha. My 4 link mount/ support/ rear crossmember/ thingy ( I've yet to find an official name) is designed to hold the lower links inside the frame rails, and the whole thing is supposed to bolt right in. And I thought the angles made it a little less boring.
#6 | |
![]() Join Date: Apr 2009
noo kiddin, i was always cramped in my single cab, thats why i got a 4 door this time around lol
It's not my daily driver by any means (ive been working on this for over a year) lol. So when it comes time where I can drive it around, I'm gonna need to come up with some way to get that extra leg room. My DD is a 2000 escalade, mostly blacked out
I had some thin lowback buckets in a swb, those gave me alot more legroom
Got a little done today. I got my lower bars tacked up today.
![]() Heres a close up on the adjustable rod ends. ![]() Here's the upper bars I just have to get the angle set for the wishbone. ![]() Posted via Mobile Device
![]() Join Date: Oct 2006
If you use a 6011 rod, use the 'whip' method. Move forward 1/8" and back 1/16"(doesnt have to be "EXACT" just close. The 6011 is a penetrating rod....7018 is like butter! Good luck!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
I got the wishbone all tacked up this morning.
![]() ![]() Posted via Mobile Device
#13 |
looks great.
#14 |
#15 |
how high is your notch?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#16 |
I hate to jump in with a question about welding when its a build thread but what about a 6013 rod? I seem to weld better with that than the 6011. Maybe I just need to practice more. What you think?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
#17 |
Do Work. Looks like a healthy back half.
Doin Work! Little At A Time.... |
#18 |
any up dates??
#19 |
just curious but where are you going to put the bags,and are your upper bars going to clear the bottom of you bed or are you just going to cut the bed more?sweet deal you got there.
87 short bed.4",6" drop sold 90chev z71 6" lift. with 35"sold 07 4x4 colorado on 31" 1971 chev blazer |
#20 |
I already have bag brackets tacked in place i just dont have pictures, but this is how they look
![]() MILLER TIME: thanks for the compliment I'd probably have to to cut out more bed floor but i plan on eventually raising the bed floor.
#21 |
No updates right now. I've been super busy with school and its playoffs in basketball so super busy. Wish i had more time to work on the truck but i only have a few more weeks left in this season, so better make the most of it.
#22 |
Can anyone verify that these are NOT drop spindles?
#23 |
I'd say not...see how the shaft is closer to the bottom ball joint. if they were dropped the shaft would be up more in the middle of the spindle.
#24 |
Ok cool. See the thing is I want to get a little lower and the best way to do that (without a dropmember or a Z) and get the most drop is with a 3" spindle. And I was just hoping that it didn't have them so I wasn't stuck being so high.
Does a 3" spindle mean I'm going to get a full 3" lower? Posted via Mobile Device
#25 |
One day...
![]() Join Date: Apr 2008
Ya, whatever the drop you want to do is how much it will lower it.
| Bookmarks |
| Tags |
| 1981, bagged, c10, custom, oklahoma |
