#76 |
Re: 58 Fleetside
Last week was a bust due to all the rain and my lack of a roof. My frame is paying the price with surface rust. Finally got the panhard bar and airbag brackets tacked on and made the frame work that my tank, compressors and valves are going to mount too.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
#77 |
Re: 58 Fleetside
Nice work!
GT |
#78 |
Re: 58 Fleetside
looks good. when I was fabbing mine in metal I would hit it with some rattle can primer, figured sanding off the cheap primer was no more work than attacking the surface rust. Just a thought.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#79 |
Re: 58 Fleetside
I didn't have that much forethought. Thinking about clearing out the garage and bringing her home so I can speed up this process and avoid extra work like this.
#80 |
Re: 58 Fleetside
Slow progress. Mocked up the core support and LS radiator, mounted the battery box and gauges. Got most of the fuel cell mounting made minus the straps. I wanted to be able to remove the tank without removing the bed. I re purposed one of the original crossmembers and a spare tire support. Is anybody else running an external fuel pump?
#81 |
Re: 58 Fleetside
Looks like a nice set up.
Kim |
#82 |
Re: 58 Fleetside
Looking sweet. I like the way the whole tank mount is removable and how the pump and regulator are tucked in close to the bottom of the tank, very clean. Im running an internal pump so i can't help you there..
What type of radiator are you using? I have a ls1 camaro rad w/ fans I thinking about using. |
#83 | |
Re: 58 Fleetside
#84 |
Re: 58 Fleetside
I stupid question here. So when people do this lowering thing, is it lowered so the cab sits on the ground with no air in the bags? If not, I'd still be afraid of small rocks or what ever dinging the bottom when lowering it. Or a sudden loss of air while crusing down the hiway. I need some education here.
#85 | |
Re: 58 Fleetside
#86 |
Re: 58 Fleetside
Nifty build ... I'm in on it.
Ratty 46 |
#87 |
Re: 58 Fleetside
Starting fitting the inner fender wells over the "A" arms and cutting the mounts for the bed. Trying to get the odds and ends dealt with.
#88 |
Certified Car Nut
Re: 58 Fleetside
Looking good Tchia65
#89 |
56 - autocross
Re: 58 Fleetside
What kind of motor mounts did you use? Did you use an adapter plate?
#90 |
56 - autocross
Re: 58 Fleetside
Oh, forgot to ask, but what about headers?
#91 | |
Re: 58 Fleetside
Thanks Kabwe. Glad to see your build back up. I just need to get this thing moving, I'm driving it to Rhode Island in April
I found a pair of Corvette manifolds and cut the ends off and welded on a standard header collector but they don't clear my steering and the collector is too close to my lower "A" arm bushing on the drivers side. I waiting on these http://www.summitracing.com/parts/EDL-65763/ They should be here tomorrow, I hope they fit. Since my truck is so low I going to run the dual exhaust down the passenger side above the crossmembers and all my fuel, air, brake lines and wiring down the drivers.
#92 |
Re: 58 Fleetside
Yes I used adapters and standard small block urethane motor mounts. It was either that or build stand offs off the cross member and wanted to keep it simple. I Did have to swap out to an LS1 oil pan though.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon Last edited by Tchia65; 01-12-2011 at 01:02 AM. |
#93 |
Re: 58 Fleetside
My transfer to Virginia is getting too close but I had to take some time away from the truck to remodel my kitchen so I can try to refinance and rent out my house. The Corvette manifolds I had hit the column and the steering shaft so I bought some Edlebrock street rod headers and they hit the double shear for my lower A arms on the passenger side. I figured I had to cut one of them up so I went with the free corvette manifolds, now everything fits, and sending the headers back will pay for my rear tires. Got the radiator modified and mounted, got the raised bed mounts welded on to the frame and the rear shock mounts tacked. Gonna try to make some head way on the exhaust tomorrow. My 16x10 rallys came in and clear the rear disc's and the offset looks like it will work, plus I picked up some baby moons for $30. Should be a lot more progress on this thing in the next two months since I'm supposed to be driving it to Rhode Island in April.
#94 |
A320 Pilot/USAF Retired
Re: 58 Fleetside
Nice work, those 16x10's look familiar!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#95 |
Re: 58 Fleetside
Decided to get a different set of collectors so the exhaust will have to wait a week or so. I cut up some 3/16 plate to 1.5 inch squares, drilled them and tacked on some 1/2 caged nuts for my bed attaching points and welded them into my raised bed mounts. then I pulled the rear end, welded up the brackets solid and primed it. Also got the straps finished and mounted on the fuel cell.
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon Last edited by Tchia65; 02-09-2011 at 02:52 AM. Reason: illiteracy |
#96 |
Re: 58 Fleetside
Fuel cell mount is done, and got my parking brake cable in so we'll see how that goes tomorrow.
#97 |
Re: 58 Fleetside
Very nice.
Kim |
#98 |
Re: 58 Fleetside
Frame got cleaned up and piss canned. Start putting it back together tomorrow. Hopefully I'm on the downhill side now.
#99 |
Certified Car Nut
Re: 58 Fleetside
Looking good my friend, looking real good.
#100 |
Re: 58 Fleetside
Looks like your making good progress on it.
Kim |
| Bookmarks |
