#76 |
Re: Bunch of chrome, polished, dress up, upgrade engine components
BUMP
#77 |
Anyone interested in a fully polished SBC tunnel ram intake manifold? We just took one off of a customers motor to swap on a different one. Its in good condition. I'll post up a pic later today.
#78 |
bump^
More stuff being added tomorrow! still have lots left too |
#79 |
67cheby
![]() Join Date: Sep 2008
interested in the long water pump can you post a pic
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 11-10-2010 at 12:48 PM. |
#80 |
Great deals is the B&M trans pan gone?
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! ![]() |
#81 |
B&M Trans pan is gone.
Here are a few more items for sale: Grant Steering wheel with polished aluminum adapter. Adapter fits on 60's-90's chevy cars and trucks I believe. Had it on my 63 c10, but it also fit onto my friends 98 silverado. $60 for wheel, adapter, and grant horn button ![]() Polished aluminum throttle cable bracket. $40 ![]() ![]() NEW! Chrome, 110 amp, GM alternator. 1 wire or 3 wire hook-up. - $105 ![]() ![]() |
#82 |
Do you still have the -Spectre, aluminum fabricated valve covers - $100
#83 |
#84 |
Slow Old Timer
![]() Join Date: Apr 2000
Interested in the Throttle Cable bracket, I'll PM you.
#85 |
67cheby
do you still have the long water pump and the dual pak 480's ?? i would be interested at $400 for both
#86 |
bump.
Long water pump is gone already. Only have short pump. |
#87 |
67cheby
how about the dual pack 480's ?? $350 shipped ??
#88 |
Bump!!! Anyone need last minute xmas presents...for themselves?
![]() I have a few new parts for sale, but my wife says she doesn't know what happened to the camera....so for now all I can do is list what I have. Sorry. -Billet alternator bracket kit with adjustable heim joints and hardware. This is for a SBC with a LWP (long water pump) - $45 -I have some 32 ford parts also in case anyone is building one and is looking for parts. I have a aluminum radiator for a 32, grill shell with stainless insert, and a 4-link setup with stainless bars. -New pair of Procomp Aluminum heads for SBC. 210cc, stainless steel valves, 2.02 intake valves, 1.6 exhaust valves, 64cc chambers. I can do just the heads complete as listed, or I can include screw in studs, guide plates, hardened seats, 190,000 psi head bolts, and hardened push rods with 1.6 ratio roller rockers. -Polished aluminum, RPM air-gap style intake manifold for SBC with Vortec heads. This increases power and torque from 1500 rpm-6500 rpm. Its brand new, we ended up going with a different setup for our vortec heads. - $260 I'll get more stuff listed as I go through our parts bin and our build sheet on the next project since alot is changing with it. |
#89 |
Justified!
What are you looking to get for the Procomp heads? w/everything? shipped to 35806?
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
#90 |
BUMP!!!!!
![]() Lots of stuff left and even more stuff to post! I'll post more items tomrrow. -I have a full set of 8 brass electric valves, used very little, to control front,back, side, to side, air ride setup, all plumbed up together and into a 5 gallon 8-port tank, with a 7-switch box. - $250 for everything! -Billet steering column dress up kit (3 pieces) It has the turn signal lever, I think the tilt wheel lever or its a wiper lever, and I think the hazard button (brand new in the box) - $20 -Chrome and red powerflow fuel filter with mounting bracket and chrome allen head hardware (NEW but no box) - $40 -Spectre Anodized red radiator cap (brand new) - $10 shipped! -BBC or SBC chrome, 80 gph, mechanical fuel pump (brand new in the box) - $45 SHIPPED! -Pair of custom made, Clear red teflon coated stainless steel braided brake lines for later model c10/suburban disc brake swap setup (brand new - never installed) Look killer! - $100 shipped! I'll add more stuff tomorrow along with pics. |
#91 |
pics, might be interested in some of it if you are willing to split it up, what brand and valve size, what brand switch box, and if so how much shipped to 92405? thanks
#92 |
bump
#93 |
bump
#94 |
Bump. I have a bunch of stuff guys. Let me know what you need or what your looking for. I probably have it.
More pics of stuff going up tonight. I have a chevy aluminum radiator with custom fan shroud, and (2) 12" curved blade electric fans mounted on it. The radiator itself is 31"x19"x3" and its fully tig welded aluminum with a billet filler neck. Brand new never installed! - $450 Used set of 17" weld wheels (polished aluminum) with goodyear eagle gt II tires. Fronts are 17x8 with 255/60r17 tires and the rears are 17x9 with 275/60r17 tires. They are dual drilled bolt patterns. one is 5x5 and the other is 5x4.5". Have all 4 center caps as well. probably 70% tread left on tires. - $525 Used set of CPP drop coil springs. 2" drop front coils and 4" rear drop coils - $100 for the set of 4. |
#95 |
![]() Join Date: Feb 2009
interested in the radiator... can you post a picture?
"Love Affair" Build Thread |
#96 |
may be interested in wheels as well... can you post pictures?
#97 |
Here are some pics of the new items. I do have lots more stuff, just dont have the time to take the pics and post them, but if you guys want pics of something in particular, let me know.
I have lots of the parts left from my original post and list, plus even more of the same type of stuff. Stainless overflow tanks. two different sizes. valve covers, chrome alternator, billet ball-milled wire seperators, chrome fuel pumps, finned trans cooler, electric fans, polished water pump, billet valve cover breather, billet air cleaner, throttle cable bracket, long water pump billet bracket with heim joint, polished RPM air gap style intake manifold (made by procomp), 8.8mm plug wires, ARP engine bolts, Procomp aluminum heads complete with roller rockers, guide plates, screw in studs, stainless steel valves, ect. This is all stuff that either customers ordered and never picked up, or there parts that were supposed to go on either my project, a friends project, or a customers project and they ended up backing out, or going a different route. Most of everything is new unless stated. Alot of this stuff has been boxed up on my shelves, or has been wrapped and protected and stored in rubbermaid containers. Here are the wheels: ![]() ![]() ![]() ![]() ![]() Here are pics of the custom aluminum radiator, with shroud and dual 12" electric fans. ![]() ![]() ![]() ![]() Also have these 31" tires for sale as well. They came off of my dad's toyota pickup, and weren't used that long. Tread is at 85-90% on them. ![]() |
#98 |
wanna be 67
Is the steering wheel adapter and horn button for $60 still available. PM me if so. I would hate to
lose this post. Rob Posted via Mobile Device Last edited by 19stepSide72; 02-21-2011 at 12:13 PM. Reason: Added pm note |
#99 |
are the valve covers still available.
#100 |
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
