Old 07-30-2011, 02:30 AM   #76
KroAutomotiveInc
KroAutomotiveInc's Avatar
Re: 1964 gmc 1000
clean agian
safety second!! wait wait first
KroAutomotiveInc is offline   Reply With Quote
Old 07-30-2011, 11:42 PM   #77
KroAutomotiveInc
Re: 1964 gmc 1000
Old 07-31-2011, 12:12 AM   #78
SulphuriousSam
SulphuriousSam's Avatar
Re: 1964 gmc 1000
nice man
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 08-03-2011, 12:56 AM   #79
KroAutomotiveInc
Re: 1964 gmc 1000
tearing into more of the motor tonight took the carb off going to rebuild it im getting a full gasket set so i pulled off the exhaust and intake manifold, pulled out the distributor and took off the push rod covers found a nice mess in there!
Old 08-03-2011, 01:34 AM   #80
KroAutomotiveInc
Re: 1964 gmc 1000
Old 08-03-2011, 01:34 AM   #81
KroAutomotiveInc
Re: 1964 gmc 1000
Old 08-03-2011, 09:51 AM   #82
SulphuriousSam
Re: 1964 gmc 1000
Looks like you have a bit of cleaning to do
How are you holding you plywood bed in BTW? I can't tell from the picture whether you bolted that in or is it just riding on top of the bed supports?
Lookin' good tho'
Old 08-03-2011, 11:29 AM   #83
KroAutomotiveInc
Re: 1964 gmc 1000
i got some self tappers that are about 2 1/2inchs long going into the bed supports
Old 08-04-2011, 02:06 AM   #84
KroAutomotiveInc
Re: 1964 gmc 1000
6 hours later....
Old 08-04-2011, 02:08 AM   #85
KroAutomotiveInc
Re: 1964 gmc 1000
Old 08-04-2011, 02:10 AM   #86
KroAutomotiveInc
Re: 1964 gmc 1000
think im repainting it red and black
Old 08-05-2011, 05:34 AM   #87
KroAutomotiveInc
Re: 1964 gmc 1000
rest of the motor taken down and cleaned then painted
Old 08-05-2011, 02:22 PM   #88
KroAutomotiveInc
Re: 1964 gmc 1000
mmmmmmmmmmmmmmmmmm
Old 08-05-2011, 02:42 PM   #89
SulphuriousSam
Re: 1964 gmc 1000
Hey Kro, what paint/color did you use?
Old 08-06-2011, 12:53 AM   #90
KroAutomotiveInc
Re: 1964 gmc 1000
i used the duplicolor 500 temp stuff its called ing red and semi flat black they had it in gm orange, gm orange red, gm blue, ford red, ford blue all on the shelf at napa i know o'reilly and autozone sells it to!
Old 08-06-2011, 12:59 AM   #91
KroAutomotiveInc
Re: 1964 gmc 1000
got all the gasket services cleaned up and the intake and exhaust manifold back on the oil filter, fuel pump, push rod covers, carb rebuild and back on, distributor, plug wires and some other **** I'm sure lol
Old 08-06-2011, 01:12 AM   #92
KroAutomotiveInc
Re: 1964 gmc 1000
Old 08-06-2011, 10:16 AM   #93
chad64chevy
chad64chevy's Avatar
Re: 1964 gmc 1000
that looks great kro! hopefully it don't leak oil on that new paint cause that would suck!! nice progress you've been doing to the truck too!! keep it up!
chad64chevy is offline   Reply With Quote
Old 08-06-2011, 06:21 PM   #94
SulphuriousSam
Re: 1964 gmc 1000
Yeah Duplicolor is what I bought at the local O'Reilly's as well. I went with Industrial Red and Gloss Black so I guess our engines will have a similiar theme. I sh*t canned the blue/grey idea and went with flashy (like you )I figure it's my truck why can't I just do what I want!
Of course, now it's gonna look like I copied you
Old 08-06-2011, 06:36 PM   #95
KroAutomotiveInc
Re: 1964 gmc 1000
LOL we just got the same idea at the same time! glad you went with what you wanted because it is your truck and if anyone has anything to say tell them to piss off lol and ask them where there truck is because they probly dont have one!
Old 08-06-2011, 06:37 PM   #96
KroAutomotiveInc
Re: 1964 gmc 1000
thanks chad yeah i hope it dosent leak ether i got a gasket set so hopfuly it will stay pretty for a while
Old 08-10-2011, 06:18 PM   #97
KroAutomotiveInc
Re: 1964 gmc 1000
right after tank
before carb
all new gas line
the corner of the thermostat housing is broken and a bolt broken off in the head was able to drill and tap it and put a washer on the bolt to hold the broken corner down.
Old 08-10-2011, 06:20 PM   #98
KroAutomotiveInc
Re: 1964 gmc 1000
kinda blurry but got the studs made for those today looks sweet!
Old 08-10-2011, 06:23 PM   #99
KroAutomotiveInc
Re: 1964 gmc 1000
working on getting oil back in it my plug was leaking and well i finely striped it out lol but going to drill and tap it a size up and i need more coolant then it should be ready to start back up!
Old 08-16-2011, 11:56 PM   #100
KroAutomotiveInc
Re: 1964 gmc 1000
got the front bumper mount set up and tacked still need to weld it up
60-66 chevy trucks, 60-66 gmc trucks, body dropped
