Old 03-31-2012, 09:05 PM   #76
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: IFS in my 55 project-start
Motor looks sweet!
ChuckDriver is offline   Reply With Quote
Old 04-01-2012, 09:46 AM   #77
Kim57
Kim57's Avatar
That's looking real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-01-2012, 12:02 PM   #78
_Ogre
_Ogre's Avatar
nice truck vjjack
you'll be amazed at the handling change from the straight axle
did you do the original build?
is there a build thread?
shop air compressor timer
Old 04-01-2012, 04:14 PM   #79
52 Rat
52 Rat's Avatar
The truck, engine and garage looks great!
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 04-01-2012, 06:37 PM   #80
vjjack04
vjjack04's Avatar
Originally Posted by _Ogre View Post
nice truck vjjack
I am hoping the IFS is as good as it looks. It is a Scotts item. I bought the truck, it was an old restored piece. I am putting the front, engine and interior in it. The first page of this is the best build thread I have. Thanks.
vjjack04 is offline   Reply With Quote
Old 04-15-2012, 06:49 PM   #81
vjjack04
vjjack04's Avatar
Ok,
Put the engine in today (I will add pictures later) but the neat, tall, retro valve covers hit the fire wall, by a lot. I took them off to aid putting the engine in...and when I went to put them on, I found that they are too tall. Did mention that I need them tall to clear the roller rockers as well. Now my options are to see if there is another set that clears the rocker but not as tall; modify the fire wall ( really don't want to do that), or I was thinking I could cut the backs of the valve covers (make a notch on each side, and have someone TIG weld them back together.....I will take some pictures and add in a bit.
Old 04-15-2012, 07:02 PM   #82
52 Rat
52 Rat's Avatar
Originally Posted by vjjack04 View Post
Ok,
I have moded aluminum valve cover as you mentioned to clear firewall, ac/heater box etc. Not too bad if you have room around the roller rockers. Good luck.
Old 04-15-2012, 07:18 PM   #83
Rude Dude
Rude Dude's Avatar
I know you already painted the frame why not move the engine 1 inch forward looks like you have the room, tranny mount is easy just maybe drill a couple of extra holes. Also cheaper than having valve covers tig welded
Rude Dude is offline   Reply With Quote
Old 04-15-2012, 08:58 PM   #84
vjjack04
vjjack04's Avatar
Good point, but I am not sure that wont be a hassle either.
I think the valve covers (cal custom) are much taller than needed.
It looks like I can, at about the 2 inch point, slant them back 30ish degrees and get them to work......I'd cut it, get it lined up, then get someone to weld it, grind and polish....but also, I put a pair of stock height steel edelbrock valve covers on it and they fit....I wonder how much is really needed for the roler rockers....?
Old 04-15-2012, 09:31 PM   #85
vjjack04
vjjack04's Avatar
Also, I wonder, or it seems, that the AFR heads have a more built up area where the valve covers mount - the stock height edelbrocks seem like they clear the roller rockers.....Im going to cut one in half to check clearance to see if the rockers hit....it doesn't look like they do....
Old 04-15-2012, 11:05 PM   #86
55Cameo
55Cameo's Avatar
your truck looks really good so far. Really clean motor and love the IFS set-up. I'd love to see it when its done since I'm doing a similar build
55Cameo is offline   Reply With Quote
Old 04-15-2012, 11:26 PM   #87
vjjack04
vjjack04's Avatar
ok, here are some pictures. I am going to do some research on valve covers....I need to see if I can get something that looks retro, but works for roller rockers....
Old 04-16-2012, 04:24 PM   #88
vjjack04
vjjack04's Avatar
I will take pictures as I progress. But if you are down this way from Tucson, you are welcome to see it in person.
Old 04-16-2012, 04:41 PM   #89
55Cameo
55Cameo's Avatar
Thank you sir. I may just take you up on that in the near future
Old 04-16-2012, 05:20 PM   #90
Russell Ashley
Russell Ashley's Avatar
I had the same clearance problem with stock engine mounts and those same after market tall valve covers. Stock Chevy valve covers have slanted ends so I got a set of those and they solved my clearance problem. If they will fit over your rockers it might be something to think about. You can probably find them chromed if that's a requirement but I blasted mine an painted them silver and called it good.
Russell Ashley is offline   Reply With Quote
Old 04-16-2012, 09:35 PM   #91
Rude Dude
Rude Dude's Avatar
Have you set the distributor in yet if valve covers hit I hope you are not using HEI (Big One) , small one will work.
Old 04-16-2012, 10:10 PM   #92
vjjack04
vjjack04's Avatar
Yeah,
I am using the factory distributer with an electronic module in it.
Old 04-17-2012, 10:20 AM   #93
Scottshotrods
Here is one more option for you.We can build you set of off set motor mounts that will look the same as you have now and this will push the motor forward.If you want to do this let us know
Justin
Scottshotrods is offline   Reply With Quote
Old 04-17-2012, 01:13 PM   #94
vjjack04
vjjack04's Avatar
Justin
Justin,
Thanks and good to talk to you on the phone. I know we discussed a new motor mount and that is what I will likely do. But the idea to cut .5 inch out of the existing one and add a "shim" to the back might be worth me re-considering - I don't think it would look that "hacked"....I will let you know.
Old 04-17-2012, 11:06 PM   #95
vjjack04
vjjack04's Avatar
Justin
Justin,
Have decided I need new motor mounts. I sent you and e-mail with pictures.
Thanks.
Old 04-21-2012, 06:03 PM   #96
vjjack04
vjjack04's Avatar
ok, fixed the engine problem (hitting fire wall) -Justin at Scotts sent me some motor mounts that move the motor .5 inch forward....that worked. Stiill had to tap the firewall some to get these tall valve covers to fit....see pictures.
Old 04-21-2012, 08:10 PM   #97
55Cameo
55Cameo's Avatar
Motor looks great sitting between the frame rails there!!!
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851
Old 04-22-2012, 12:57 AM   #98
vjjack04
vjjack04's Avatar
thanks man, still a long way to go....I am looking for different headers with an exit toward the back of the heads/motor, still gotta get the trans cross member done.....and other stuff......but hope to get it on the road in May....
Old 04-22-2012, 02:15 AM   #99
55Cameo
55Cameo's Avatar
That be awesome to have it done so soon.
On the headers I have seen some like your asking. I was thinking of changing mine as well. Maybe this is something close to what your after
http://www.summitracing.com/parts/HED-69528/?rtype=10
or these too
http://www.summitracing.com/parts/ADD-717057/?rtype=10
Don't know if you found any or had some in mind
Old 04-22-2012, 02:31 AM   #100
BC Toy chest
BC Toy chest's Avatar
Truck looks gr8 bro can't wait to see it when it's done.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
