Old 02-18-2011, 06:32 PM   #76
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 1954 Chevy / S10
That thing is looking sweet. I like the rear fenders being welded on and the stance is killer.
Good job.
Kabwe is offline   Reply With Quote
Old 02-18-2011, 06:32 PM   #77
Fat Mike
Fat Mike's Avatar
Very cool panel. Like what you did to rear door area. What are those rear lights off?
Fat Mike is offline   Reply With Quote
Old 02-18-2011, 06:41 PM   #78
Da88burban
GM's 4 Life
Da88burban's Avatar
Man your panel is sweet.
Jack
'54 Chevy 3100 "Just a Mess"
'74 Chevy Super 10 468BB "One Fast Rust Bucket"
'86 Pontiac Fiero GT
'88 Chevy burb "Tha Big Turd"
'93 GMC Safari "Bone Crusher"
.................____________
.............../______l___|___\____
;,;,;,;,;,;,;|__(O)_| __l___l__(O) |
Da88burban is offline   Reply With Quote
Old 02-18-2011, 10:06 PM   #79
xpickup
xpickup's Avatar
Thank you all for your comments. The tail lights are for a 1939 Chevy car. They are LED and are very bright. The panel sits on a 1981 Malibu wagon chassis that I stretched. It sets about 5 inches off the ground and is a static drop. Someday I want to bag it. The motor is a 402 BBC with a turbo 350 and a 9" F@#$.
Kabwe, The funny thing with the rear fenders was some dummy(me) cut them off with a plasma cut before finding out that nobody made replacements. Not even in glass at the time(13 years ago). So I figured it was easier to just weld them on.
xpickup is offline   Reply With Quote
Old 02-22-2011, 06:59 PM   #80
Kabwe
Certified Car Nut
Kabwe's Avatar
Well I like it, it gives it a really smooth look.
Old 02-27-2011, 07:12 PM   #81
xpickup
xpickup's Avatar
Well back to the 54 now. Got a new tilt column from Southern Rods along with a column drop and lower column bracket. Just about done with the floor. Need to finish the upper piece of the tranny tunnel yet and weld it all in. Then put the the column in and attach in to the steering box. Then it will finally steer, making moving it around a whole lot easier. Here are some pictures.
Old 03-06-2011, 05:36 PM   #82
xpickup
xpickup's Avatar
Well I have the tranny tunnel all in an put the steering column in. I bought the southern rods 32" tilt column and ended up having to cut it down about 3.5". The column dumped right into the headers and the s10 headers only have a little bit of room the get the steering through. Tomorrow I will order the 2 u joints and the double d shaft. Then finally steering. Moving it around will then go a lot better. Next is the inner wheel wells and the rest of the sheet metal under the hood. Here are some pictures.
Old 03-09-2011, 11:39 AM   #83
xpickup
xpickup's Avatar
Here was a little side project I made for my buddies 1940 Ford pickup (was my first street rod). He bought the Inglese 8 stack injection and these are the intake tubes that go on top. They get K&N filters out in the front of them. I machined them at work and TIG welded them at home. I will get pictures when he puts them on.
Shannon
Old 03-10-2011, 09:45 AM   #84
MrDude_1
Looking great!
in that last pic with the column shortened, i can see how the brake pedal arm sits. looks great... it also looks like theres more room for exhaust then i thought.
is there actually enough room for the exhaust to fit between the brake booster and the trans? i thought it would be too tight there for longtubes, but it appears to have enough room!
MrDude_1 is offline   Reply With Quote
Old 03-10-2011, 06:49 PM   #85
xpickup
xpickup's Avatar
Mr.Dude1 I will look tomorrow and see how much room there is. Shannon
Old 03-10-2011, 10:29 PM   #86
xpickup
xpickup's Avatar
Me being the non computer person , I just figured out how the take pictures from email to save the to the computer and came across some pictures of the 54 truck before I started it. So as you can see it needed a little metal work.
Shannon
Old 03-11-2011, 06:04 PM   #87
xpickup
xpickup's Avatar
Originally Posted by MrDude_1 View Post
Looking great!
Mr.Dude1, I looked down there and I think it will be almost too tight for long tube headers unless you cut the headers and modify them. It is pretty tight between the trans and the brake booster. I am going under the tranny cross member.
Shannon
Old 03-13-2011, 07:56 PM   #88
xpickup
xpickup's Avatar
Well I finally have steering. I doubled up the sheet metal up for the lower mount so it was stronger. I got my joints all in and the steering column was the perfect length now. Pushed it out to clean up under it and do some plasma cutting and could now steer it back in. I am working on the inner wheel wells now. I have the drivers side hanging there and still have the lower back part to make. Trying to make it come down the frame and still have tire clearance.
Old 03-13-2011, 10:08 PM   #89
blitz'd
vintage car junkie
blitz'd's Avatar
That looks great, love the floor and tranny hump.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 03-13-2011, 10:36 PM   #90
troy54gmc
troy54gmc's Avatar
Wow. Xpickup you are one hell of a metal fabricator. very nice.....
troy54gmc is offline   Reply With Quote
Old 03-14-2011, 06:28 AM   #91
xpickup
xpickup's Avatar
blitz'd, troy54gmc, Thank you both. I really do like working with metal. It's never a dread doing it and it is kinda a good stress reliever.
Shannon
Old 03-14-2011, 10:00 AM   #92
MrDude_1
Thanks for looking at it for me. Little disappointing, but atleast I know now.
your truck is coming out great. right now mine looks more like your "old pictures" you just posted..
Old 03-14-2011, 11:48 AM   #93
xpickup
xpickup's Avatar
MrDude1, no problem. I have full length headers on my panel but I have a g body frame instead of the narrower s10 frame. If you don't put the booster under there you probably could use them. Rememder all good things take time. Shannon
Old 03-20-2011, 07:28 PM   #94
xpickup
xpickup's Avatar
Started on the inner wheel wells and these were probably the worst things to fab yet. Still have to fill in front and rear ends and around where the a arms are. The wheel wells match up to the angles on the fire wall pretty well. Here are the pictures.
Old 03-27-2011, 02:01 AM   #95
busarich
nice work man, love the work that you are doing with the bed.
busarich is offline   Reply With Quote
Old 03-28-2011, 02:00 PM   #96
xpickup
xpickup's Avatar
busarich, Thank you . Not much done we are swapped at work. Hopefully I should have both inners fenderwells done this weekend.
Shannon
Old 03-28-2011, 02:27 PM   #97
OrrieG
OrrieG's Avatar
Wish I could swap at work, but the wife would get really mad!
OrrieG is offline   Reply With Quote
Old 03-28-2011, 03:31 PM   #98
xpickup
xpickup's Avatar
OrrieG, Sorry, a little too fast of typing. We are swamped at work!
Old 04-03-2011, 09:21 PM   #99
xpickup
xpickup's Avatar
Worked on the inner wheel wells this weekend. I have the drivers side done(metal work). I have to mount it in the back to the frame. I keep the same theme as the fire wall. The wheel wells match up the angles on the fire wall. Here are the pictures.
Shannon
Old 04-03-2011, 09:27 PM   #100
xpickup
xpickup's Avatar
Here are the passengers side wheel well. Matches the drivers wheel well. I have it all tacked together it just needs welded except for a few small fill in pieces. Here are the pictures.
Shannon
