01-08-2012, 10:58 PM | #76 |
PROJECT 7DEUCE
Re: layed out 67 swb project M.A.C.
Good to see you back on the site...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-08-2012, 11:09 PM | #77 |
wow!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-09-2012, 03:43 AM | #78 |
man...my mind has been blown!!! this truck is so disgusting!!! am i adding enough exclamation points to get my point across!!!??? hopefully i'll run into you at a show on the left coast one of these days. i'd love to park next to your rig. maybe i'll roll up to the oregon dunes this summer and hit you up.
Here's the build: http://67-72chevytrucks.com/vboard/s...d.php?t=486707 late mason |
01-09-2012, 02:45 PM | #79 |
work of Art my friend.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own. SqueegeeMan |
01-09-2012, 03:18 PM | #80 |
Frequent Flyer
Killer Truck!
01-09-2012, 08:40 PM | #81 |
Love the interior. Flows very well.....
01-10-2012, 02:20 AM | #82 | |
01-10-2012, 02:27 AM | #83 | |
01-10-2012, 02:40 AM | #84 |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
01-10-2012, 10:26 AM | #85 |
Wow...freaking Wow. Awesome Build !!
Eric 1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509 2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq 2016 Camaro SS - Satin Pearl Nero wrap My 2010 Camaro SS Magazine feature (SOLD) http://www.superchevy.com/features/g...of-perfection/ |
01-10-2012, 06:45 PM | #86 |
67-72 parts collector,…
Freaking BEAUTIFUL truck!
01-10-2012, 11:15 PM | #87 |
well Ive been working on disassembling some of the driver terrain. Ive got the transmission out and being worked on as well as the rear end out to have built. Going to have a lot better package deal when its all said and done...
01-11-2012, 01:54 AM | #88 |
Way cool would love to come check it out in person some time. I'm in Albany and Eugene quite often.
01-22-2012, 10:24 PM | #89 |
Ive been working on the inside of the bed this last week amongst the other things I have been doing. Here are some pics of my inner fender project. In order to raise them up to my desired height I had to notch them to fit the contour of the inside of the bed.
01-22-2012, 10:26 PM | #90 |
Notice I used nut inserts on the inside of the bed to fasten the fender. Ive also had the shocks revalved and stiffened way up trying to eliminate such violent wheel hop while Im boiling the tires
01-22-2012, 11:30 PM | #91 |
Looks great!
What are your plans for a bed floor?
01-22-2012, 11:48 PM | #92 |
I will eventually have a raised wooden floor that has a hinging center section to display the back half and access the fuel cell. A local cabinet builder owes me a floor after I painted a couple things for him I just have to build the frame work for it first.
01-23-2012, 12:09 AM | #93 |
Very cool truck - excellent fabrication, and really dig the way you tied all the colors together.
01-23-2012, 01:01 AM | #94 |
WOW......... uh ..... WOW
that is an awesome truck and you and your roommate have some serious skill ! Can you explain a little bit of this steering linkage, Where did you get the joints and that thing that holds it to the frame above the c-arm. was there any other mods to make the steering work or was that it? also did I read that right you are running a small rubber strip as a body mount instead of moving the body mount brackets down on the frame? do you have a pic of your mounts? I might get a long frame and do something similar instead of hacking up my short frame. thanks for your time. again WOW that is some awesome fab and paint work!!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
01-23-2012, 01:11 AM | #95 |
Those are steering U joints you can buy them from any aftermarket part supplier or race car part source. theyre a little spendy (about $50 each). The arm that holds them is a heim joint that has the same inside diameter as the outside diameter of the steering shaft. The heim is simply attached to the frame with some 1" tubing. Thats the only modification necessary for the steering when you z the frame as I did. If I was to do it again I would definitely do a dropmember or at least not z the frame so much. It becomes a big hassle with engine, exhaust etc. The only other mod that comes in to play in the steering area is if you have a column shifter. youll have to modify your linkage or do a lokar cable setup. Thanks I appreciate the props on the build!
01-23-2012, 01:12 AM | #96 |
Almost forgot, what size steel stock did your roomie use for the back half ? im guessing 2x3x.125 DOM ??. Thanks,
Ive seen the "frame is a tank" before and thats a cool mod and definately saves on room not having to stuff air tanks under the bed. You guys did a very nice job on that as well.
01-23-2012, 01:13 AM | #97 |
o and also on the frame mount situation. Definitely move the factory mounts if you can. What I did hasn't proved to be the best plan I ever had. Good luck!
01-23-2012, 01:24 AM | #98 |
The square tubing in the back is 3/16" wall seamed tubing. it might be a little over kill but 160 psi is scary. And ya its a great space saver and truly a wow factor. everyone that sees it and hears that the frame holds air is blown away for some reason. Its kind of a pain to execute but its doable.
09-01-2012, 07:19 PM | #99 |
Well once again its been awhile since I've been on the board but Ive stayed busy on my truck and made some awesome improvements and have been out enjoying it this summer. Burning rubber and checkin out local shows and cruise ins. Hope you all like what you see!
Ive done a new rear end. 33 spline dutchman axles, full spool with 3.73 gears. new diff cover. All new stainless brake lines and improved routing. Rear inner fenders. Remote trans cooler located under fuel cell with AN lines. Re built th350 with continental converter, manual reverse valve body. And last but certainly not least is a 412" small block with a hilborn stack injection from the 60's. All AN plumbing, belt driven fuel pump and fender well headers that were custom made. I also just added electric cut outs for un capping the beast. Its a haul ass unit and really looks unique now! |
09-01-2012, 07:36 PM | #100 |
67cheby
Awesome !
Posted via Mobile Device |
