Old 01-07-2011, 11:14 PM   #76
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: Lil 307 that could....
Yeah, she runs like a raped ape....just leaving some smoke behind her. I'm almost positive my rings have seen the end of days. Definitely nothing to do with the Vortec swap other than upping the compression on 40 year old rings.
I call it a success, really wish that the bottom end was a bit fresher. So Vortec heads will fit a small bore 283/307 without issue. They can be made to accept a higher lift without machining, although I recommend having them machined if you have them off and disassembled. My calibrated booty says that the seat of your pants gain is well worth it.
screamin_c10 is offline   Reply With Quote
Old 01-08-2011, 12:03 AM   #77
Hubscrub
Cruzin
Hubscrub's Avatar
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-08-2011, 12:08 AM   #78
Kidd-7
Kidd-7's Avatar
X2
Kidd-7 is offline   Reply With Quote
Old 01-08-2011, 01:25 AM   #79
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Sweet deal!!!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 01-30-2011, 05:36 PM   #80
dan76
http://www.summitracing.com/parts/CCA-4716/
Here's a link to the tool needed to machine the valve spring seat at home. You'll also need an arbor to perform this task.
For additional reading, take a look at this link. http://www.carcraft.com/techarticles...ade/index.html
I'm looking at similar methods you used on the 307 and how they'll work on a 305. These engines are cheap and readily available unlike the 307s......Haven't seen one in years at the junkyards.
dan76 is offline   Reply With Quote
Old 01-30-2011, 06:09 PM   #81
screamin_c10
Yes that tool cuts the spring seat and guide diameter for your spring and pos. stop seals, but it does not cut down the guide height to increase clearance between the retainer and guide....
I would use the 4718 though as it cuts the seat to 1.44, the standard size needed to run springs with dampers.
An additional tool (4726) is needed for that...
Both tools and the arbor (4732) run around 105.00 total plus shipping.
I chose to go the route I did because my heads were already installed, making the machining option impossible.
Good luck with it.
Old 11-23-2011, 12:46 AM   #82
Ryan5O
can we get a report on your mpg since the build
USCG "Support Search & Rescue, Get Lost"
Ryan5O is offline   Reply With Quote
Old 11-23-2011, 03:45 AM   #83
screamin_c10
Wish I could Ryan... the old 307 just couldn't handle the increased compression and started pulling oil past the rings.... never quit running and always fired on the first hit and purred like a kitten... I'm gonna miss it
Old 11-23-2011, 09:09 AM   #84
Greywolf200
Originally Posted by screamin_c10 View Post
Well the Vortecs are on the 307, new cam installed, rockers adjusted, intake on, HEI stabbed, chain and sprockets set to 0 TDC, carb and wiring hooked up.
Just need to pop on the timing cover, plugs and wires, w/p and accessories. The ramhorns are in pretty bad shape, still trying to figure out how to get the studs out so I can run them for now. Gonna go to headers and a 2.5 dual system once spring rolls around....
Its gettin' down right cold here, if the weather allows I should be able to crank 'er up next weekend....
Spent a couple hours in the warm shop doing the jeep fan upgrade as well. Came out pretty good if you ask me.
I like that electric fan, what brand/where did you get it?
Thanks,
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 11-23-2011, 09:49 AM   #85
screamin_c10
Thanks,
Its the jeep fan mod....
http://67-72chevytrucks.com/vboard/s...d.php?t=254617
Old 11-23-2011, 09:56 AM   #86
Ryan5O
Man, Im sorry to hear that. Thanks for taking the time to tell us about it.
Old 11-24-2011, 08:24 PM   #87
Kidd-7
Kidd-7's Avatar
So what do you think the death of the 307 was?
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Old 11-26-2011, 01:04 AM   #88
screamin_c10
Age, and abuse... So when we pulled it down there was NO babbit left on any bearings, the crank had deep grooves in the journals, The block had deep grooves in all eight cylinders. Basically rode hard and put away wet. Funny thing is she ran like a champ til the day I pulled her out....BUT, I couldn't justify the expense of all the machine work and parts to put it back together the right way....
Old 11-26-2011, 01:21 PM   #89
Kidd-7
Kidd-7's Avatar
Screeming, thanks for the update, I'm looking to re-build and enhance my 307. If you have any parts your getting ride of keep me in mind. Thanks.
Old 11-27-2011, 01:43 AM   #90
PAWS 72
PAWS 72's Avatar
about 2 months ago i bought a 71 lwb to use some parts for my 72.the 71 had a 307 that had been rebuilt about27 years ago i was going to put back in the 72 because the 72 came with the 307.the 307 tuned up great and held great oil pressure cold but when it gets warm it drops to about 7-8 psi.haven't put gauge on it but i know its low. just wondering what evryones opionion is.have not changed oil yet going to in a couple days.
the reason i asked is the 72 came with 307 3ott father in law bought the truck new,we changed to 400 sb in 1988.just wondering if to put 307 back in for originality or keep 400 since the blocks looks alot alike. kinda like to stay close to original. also when repainting would you use new or real clean original stuff. long story short we done what we wanted with the truck then but since he passed away in 2000 me and the wife has started to redo it to original. thanks guys. still drive and show it every time we get the chance on the weekends
PAWS 72 is offline   Reply With Quote
Old 11-27-2011, 01:47 AM   #91
PAWS 72
PAWS 72's Avatar
by the way screamin the truck looks good.the motor also
Old 11-27-2011, 07:10 AM   #92
trev1
Wow, sorry to hear about the rings givin up the ghost.... Was really int ereste in hearin how the 307 did. We are in the process of building a 350 that is VERY similar. All of which is on a budget... Bought a 350 10-20 4 bolt bored oout to .040 over. Had it line honed, freze plugs etc.... steel crank, flat top pistons, Erson 292 grind cam, 193 heads machined to accomidate bigger lift, performer intake for the vortec style heads. Serpentine set-up mod. Points distributor. Holley 700 DP.
All of this I picked up during the last year and a half. I have $100 in the block, $125 in the heads, $150 in the machine work, $590 in the rest. So for around $1000 we will see what she will do this weekend. Thw machine shop guy was suprised and thought it was a good combo. He suggested the cam said it would do a really good job with the heads. Thought the combo would go over 375hp. Here are some pics.
We are going to fire it off today. We will see.
trev1 is offline   Reply With Quote
Old 11-27-2011, 07:17 AM   #93
screamin_c10
I highly suggest getting a set of true 062 or 096 Vortec heads from Skoggins Dickey, GMPP or the local wrecker. I have 3 sets now and am very impressed with the performance gains that they made on that lil 307.... if she had not been soooo far gone I probably would have built her again for something down the road....
Old 11-28-2011, 02:59 AM   #94
Captainfab
60-66 Nut
I agree. There seems to still be come confusion that just being a center bolt valve cover head makes them Vortec heads. Not so. Those heads are just swirl port TBI heads. The '96-'02 Vortec heads perform much better. The downside, is you will need a different intake. The Vortec intake is bolted to the heads with 8, 5/16" bolts.
Old 11-28-2011, 07:05 AM   #95
screamin_c10
Originally Posted by Captainfab View Post
I agree. There seems to still be come confusion that just being a center bolt valve cover head makes them Vortec heads. Not so....
I agree, you get pretty good at spotting them while on junkyard raids...
Old 11-28-2011, 07:20 AM   #96
screamin_c10
Here is the latest Vortec build, a warmed over L31 my son and I are building for his senior project.... As a matter of fact all the new components I had installed into the lil 307 went into this build....Cam, heads, intake, Timing chain, carb etc.
Old 11-28-2011, 12:00 PM   #97
Bert W
Bert W's Avatar
I hate the 307 played out. I geared up for the same type of build on my 307. I thought my 68 bottom end was in better shape than it turned out to be. I had to scrap that plan and go in another direction.
Bert W is offline   Reply With Quote
Old 11-29-2011, 12:07 AM   #98
Captainfab
60-66 Nut
Nice looking engine you're building with your son. That's good that he has an interest in something like that. What is this engine going in?
I've never really gotten a good look at a Summit brand intake. In these pics it looks like it is of nice quality. What is your hands on opinion of them? I just assumed they were junk like the Professional Products intakes.
Old 11-29-2011, 08:34 AM   #99
screamin_c10
Thanks, I stole the L31 full roller I built from my wife's '67 Chevelle so this is the replacement for it.... It is quite a bit milder then its predecessor.
I am very happy with it, the Summit intakes are made by Weiand and are identical in every aspect, casting, machine work, design..... The pistons are Summit re-branded Silvo-lite hypers by Keith Black. With a true 1.560 compression height they are great for a budget build street motor.
I know what you mean.....I have a Pro Products intake and it took tons of work to get it to fit right... basically I polished a turd.
You should talk to Txfirefighter he was the one that originally informed me about how Summit re-brands products with their name and sells them at a discount....
Old 11-29-2011, 04:21 PM   #100
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I knew it! I had heard somewhere that the summit intakes were weiand, but didn't want to speak up last night because I couldn't confirm it. From what I've researched, most of the summit brand parts are made by respected manufactures. So when I can I buy summit to save a few $$.
By they way the new motor looks great!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
