04-15-2011, 10:11 PM | #76 |
Re: Project...praise the lowered
thanks fellas.its a little slow going lately.mostly small boring tedious jobs.but today i did get most of the front clip in filler.im not a psychic but i see alot of block sanding in my future haha.i should have some pics tomorrow.when i get home.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
04-17-2011, 07:03 PM | #77 |
nothing too exciting in this update.i spent the weekend blocking,and blocking and more blocking.im going to have to say the shaping grill will probably be the most time consuming part of the body work.so many curves and sharp edges but it turned out well.had a buddy come over and help out so that was a bonus.
04-17-2011, 07:17 PM | #78 |
Looks great! You just got to love blocking & blocking & more blocking. But in the end it looks great!
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
04-22-2011, 07:50 PM | #79 |
still blocking.i moved to the roof and the door gap.so far so good.my buddy showed me a great way to spread filler perfect along gaps.use a sign like a garage sale sign and stick it in the gap when your applying filler.it worked great.hers a few more pics.had my better half over today giving a hand.its amazing how well she does with body work.
04-22-2011, 10:29 PM | #80 |
PROJECT 7DEUCE
Looks pretty good..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-23-2011, 04:41 AM | #81 |
Good work!!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
04-23-2011, 11:25 AM | #82 |
looks awsome! going to be a one off for sure.
04-23-2011, 05:12 PM | #83 |
as always thanks guys.and happy Easter weekend.dont have much for pics but today i was.....you guessed it..blocking.should have the roof close to being ready for primer tomorrow.if i do anything exciting in the next few days i will post some pics
04-24-2011, 11:46 PM | #84 |
Pipeliner
good luck. you have a very clean truck on the way.
05-02-2011, 09:37 AM | #85 |
67cheby
WOW...i hadnt checked up on your build in a while.... man looking KILLER !!
05-02-2011, 04:41 PM | #86 |
Your truck looks killer! How hard was removing your drip rail? Any tips you can pass on?? It look great! Keep the pictures coming .
05-02-2011, 06:48 PM | #87 |
good to see you guys are still checking my build out.not much to update lately.still blocking filler but it has come a long way.and i got some goodies.b&m hammer shifter,and paddle switch/double needle gauge combo and some small stuff.i did manage to get some more parts blasted and painted and have the front half of the frame stripped/primed and sprayed with boxliner so the front suspension should be bolted into place real soon.also have a set of trailing arms in the making and just waiting for the rear axle to get blasted so i can make some out side frame mounts and rear bag mounts.i will get some pics real soon for you guys still following it.
05-02-2011, 06:55 PM | #88 |
thanks dude.well if your going to attempt it i would do it with the windshield still in or keep checking the shape by putting the window in once in a while because mine was way off when i tried to set in the windshield the first time.do small sections at a time and if your bringing in the side to match the tops of the doors like i did,do a small test section to see how much of a strip you have to cut out to line it up proper.and again just do a little at a time.all said and done get ready to block bodyfill until your arms fall off.hope this helps in some way.any other questions feel free to ask
05-03-2011, 11:42 PM | #89 |
It'll buff out
Man this truck is sick! I can't wait to see how it looks once its all back together. It makes me want to get out there and start working on my truck.
05-05-2011, 08:43 PM | #90 |
That truck is smoove! Your coefficient of drag will be under 0.30 if you keep this up! Maybe even under 0.25, the drag of the hideous Prius.
05-06-2011, 06:13 PM | #91 |
i cant wait to get it done either.probably wont be done for my wedding day but soon after it should be rollin.
the drag of the prius comment got me laughing my a$$ off.good one on a side note,got the rear end blasted,brackets shaved off and new brackets for the control arms and primer/paint should be the first of the week.this weekend will be more blocking and shaping.stay tuned
05-07-2011, 12:31 AM | #92 |
SIR may i request closeup pick of your well done grill?
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
05-07-2011, 07:54 AM | #93 |
yeah dude for sure.did you want the billet part?or the whole thing?any place you want close ups of?i can get some pics tomorrow when i go over to work on it.
05-08-2011, 01:13 AM | #94 | |
THIS IS BY FAR THE BEST LOOKIN GRILL FOR GMC PICKUPS BYFAR IMO IT SHOULD HAVE BEEN STOCK
05-08-2011, 11:50 AM | #95 |
low n' slo
man, just read the whole build. nice!!! im diggin the cluster swap...turned out sick!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
05-08-2011, 06:33 PM | #96 |
ok man,i went over today before i saw your post.i got a few pics if they dont work for you i will get more.what i did was simple.cut the center cross out,..the 4 missing sections where the cross meets the sides and top i simply welded in pieces i cut from the cross piece.bought a billet grill for a 73-83 then laid it on top of the 67 grill.traced looking down around the headlight buckets and used a cut off wheel to cut it out.then used a press to get the right bend i needed.hope this helps
05-08-2011, 06:39 PM | #97 | |
05-08-2011, 11:56 PM | #98 |
Sweet man! Can't wait to see it all primered up! Keep it up!
05-09-2011, 01:28 PM | #99 | |
Oh yea one more question. How did you get your lady to work on your truck? That is quality!! HAHA Later
05-09-2011, 05:44 PM | #100 | |
haha.shes been helping me with cars,trucks,motorcycles,snowmobiles since day one.lucky catch i guess. as for the drip rails i didnt drill any spot welds.just took out about a 1/2 inch or a little less section then brought the outer edge in to meet the inner.
