01-14-2011, 12:33 AM | #76 |
Re: Tunnel Ram
And would you believe this fits under the hood? The intake is 6.06" from the floor of the intake to carb pad with a 4 hole 2" tall spacer. I dont have the spacer on the motor now but I think I might keep it for future use when I get a blower. I also have a custom air cleaner spacer thats 8" tall when I wanted to go through the hood but I hate to cut the hood for a ram and not a blower!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
01-14-2011, 08:18 AM | #77 |
Re: Tunnel Ram
Good point prostreetC-10 Yes i have checked plugs and they are all the same color and seem to be burning evenly. The Tunnel Ram topic is a touchy one because each application has to be taylored to fit the engine and the duty it will be used for. The biggest problem guys have with tunnel rams is they over carburate!! If you match your cfm with your heads and cam you can really have a nice performance package for the street and have killer looks!
01-14-2011, 10:13 AM | #78 | |
Re: Tunnel Ram
01-14-2011, 10:15 AM | #79 | |
Re: Tunnel Ram
01-14-2011, 11:23 PM | #80 |
Re: Tunnel Ram
i just got a holley 500 serise carb for my 65 gmc original 305 engine can i fit a tunnal ram on if this is possible
01-15-2011, 12:23 AM | #81 |
Re: Tunnel Ram
I honestly could not say for sure. I can only say mine fit because it was one a 65 when i got it.
01-15-2011, 12:31 AM | #82 |
Re: Tunnel Ram
ill look into this some more
01-15-2011, 01:52 AM | #83 |
60-66 Nut
Re: Tunnel Ram
A tunnel ram for a GMC 305 V6 does not exist.
01-15-2011, 09:27 AM | #84 |
Re: Tunnel Ram
01-15-2011, 09:37 AM | #85 |
Re: Tunnel Ram
Yes lake, I'm pretty stoked. Even if it doesn't perform worth a crap with my engine setup, i still love the way it looks. I am sure i will keeping the hood up as much as i can, LOL
01-15-2011, 10:34 AM | #86 |
Resistance is Futile
Re: Tunnel Ram
CVA, there was an article in Hot Rod(?) or something a few years back where they tested a bunch of tunnels with different set-ups and some made better torque in low rpm then the dual plane they used for the baseline. I'll try to find the article for ya.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-15-2011, 11:09 AM | #87 |
Re: Tunnel Ram
Thanks, I would appreciate that.
01-15-2011, 11:43 AM | #88 |
My Carbon Footprint
Re: Tunnel Ram
Today my son is going to go to the sitter for a little bit so I will have some garage time. I'll try and get those parts rounded up. One thing though. Even though they are nice, one off spacers, you might want to think about not running them. They are absolutely not needed and will give you that much more clearance. Those are the reason they guy had to change the linkage. Come to think about it as I type, that linkage might not even work without the spacers depending on what he has done to it. Just by looking at the pics, you should be able to reposition the little arms on the splines a little farther back. If you are going to attemp this, give yourself the best chance for it to work and the spacers are not needed. You certainly don't need to increase the size of the plenum.
01-15-2011, 12:33 PM | #89 |
Re: Tunnel Ram
Gotcha, I will look into taking them off. They do work flawlessly with the spacers. Just looking at it, i can't see much reason why they won't work without them. I am sure i will have to readjust the throws and such. I will definitely take your advice though. Sounds great on the parts. I am gonna pull the worse of the 2 carbs apart and start it soaking today. It looks like it will need to soak for quite a while, LOL.
01-15-2011, 01:42 PM | #90 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: Tunnel Ram
I went the otherway.......
I like the look of what you have going on there looks great but because I wasn't sure if I would have to cut the hood and I didn't want to cut it, I went with a cross ram set up instead. Hits the dyno next week should be intresting I know it's probaly not the best way to get more HP but hey it looks dammmmmmn cool. Congrats on your new purchase it looks awsome nothing says sexy like a couple of holley's under the hood...... |
01-15-2011, 01:56 PM | #91 |
Re: Tunnel Ram
i wanna see the cross ram -to me the TR is my version of Kim Kardashean and the cross ram is scarlet whats her name - both drop dead sexy! hahahaa if you tell me you got an OG Winters GM manifold Im taking my toys and going home! hahaa
01-15-2011, 02:09 PM | #92 |
Re: Tunnel Ram
uhm.....
Well I don't yet...but I have 2 cross rams..A edelbrock cx-8...thats pristine and a 60's Offenhauser....But I do have a 1969 Z/28 intake manifold ( not the cross ram ). Oneday the winters manifold shall be mine.....the one on e bay today complete is 15 grand. |
01-15-2011, 02:17 PM | #93 |
Re: Tunnel Ram
okay I have to ask....
Whats a guy with a Mopar name want a winters cross ram for....chuckles...sorry man but I had to ask. As soon as i get my act together and figure out how to host/post pics I with put a picture up of it. But there is just so much cool stuff on this site that I keep getting side tracked. |
01-15-2011, 02:44 PM | #94 |
Re: Tunnel Ram
im just a fan of all things motor - vintage race even better - i grew up mopar and this 64 is my first chevy - and i gotta say im loving it! still building a 48 dodge p/u chop top on the slow though!
sorry CVA for hijackin! Last edited by blackmopar; 01-15-2011 at 02:44 PM. |
01-15-2011, 04:39 PM | #95 |
Re: Tunnel Ram
01-15-2011, 06:02 PM | #96 |
Re: Tunnel Ram
Amazingly I found the article, CVA!! How time flies, this is Hot Rod magazine, January 2002. It was actually a multi-carb article and did some 3x2's also.
The article is titled 'Multi-carb Shootout' and it goes thru seven different intakes and mentions jettings and so forth. They seem to go for peak HP but mention other info such as drivability and jettings. Thought it mite help you set up your new adventure along with prostreet's advice.
01-15-2011, 06:08 PM | #97 |
Re: Tunnel Ram
CVA do you mind if I try to post my cross ram picture on here ( not that I have ever posted a picture or am sure I know how too )
01-15-2011, 07:21 PM | #98 |
Re: Tunnel Ram
Post away. I love all pics of 4x2 stuff.
01-15-2011, 07:22 PM | #99 | |
Re: Tunnel Ram
01-15-2011, 07:26 PM | #100 |
My Carbon Footprint
Re: Tunnel Ram
Haven't you heard of rehabilitation???
