#76 |
![]() Join Date: Apr 2004
Re: How to: Ruin a perfectly good C10
No thanks, I have one already.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#77 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Great idea on the truck ralley wheel FAQ thread!
#78 |
A guy with a truck
Thought you might like it. I'll just be plagiarizing your posts anyway
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
#79 |
A guy with a truck
Took a little break from 'mechanic-ing' to do some wood work. Decided I liked the look of a wood bed, so I ordered up some rough cut, clear SYP(southern yellow pine) and made a bed floor out of it. This is the wood that these trucks came from the factory with, is durable, reasonably priced, and I won't be afraid to throw crap in the back of the truck like I would with expensive wood. I paid $70 for the stack of lumber and spent a few hours ripping, cutting, and grooving the planks. MUCH better, in my opinion, than spending $3-400 on a pre-made kit.
Here's a few shots of what I started with, and some of the work in progress
#80 |
A guy with a truck
Here's a few more of the 'complete' floor. I had to lay it on top of the steel foor to see what it will look like. I gotta say- it looks sweet!
![]() I used the dimensions from GMCPauls website combined with some from Mar-K, since I'm using their bed strips. All cuts were made with a table saw and a miter saw at the local Air Force base's wood shop. This could have easily been done at home if I'd had the tools, but my garage is full of stuff used to work on cars...
#81 |
looks good. What did you do to address the rear where the tailgate steps up to the raised bed?
#82 | |
A guy with a truck
Good thing the truck is low enough to just drop stuff in over the bedsides
#83 |
Wood floor looks GREAT!
Are you going to stain it?
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
#84 |
VA72C10
![]() Join Date: Mar 2008
very nice! Love the look of a wood bed!!!
Looking for a 67-72 swb or blazer project in or around VA.
#85 |
67cheby
![]() Join Date: Sep 2008
nice work
#86 |
Any plans to space the wood up off the metal floor?
I wondered about water/moisture being trapped between the two.
#87 | |
A guy with a truck
I have a little bit different than the 'normal' resto plans for this one. We'll see what happens, as I'm prone to changing my mind frequently
![]() Thanks, me too! Thanks! Quote:
#88 | |
Is there a P.Tina in the house?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-18-2011 at 01:40 PM. |
#89 | |
A guy with a truck
![]() Posted via Mobile Device Edit: I also hear she's cheap, low-maintenance, and doesn't mind hanging out in the Wal-Mart parking lot...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). Last edited by gringoloco; 03-30-2011 at 12:34 AM. |
#90 |
A guy with a truck
Been playing with the truck a little bit more the last couple of days. I spent way more time than I care to share getting the fan shroud aligned- VERY little clearance around the clutch fan on my serp setup- but now it's done and installed for the last time
Also finished up the underhood wiring, spent a ton of time chasing down a new lower radiator hose (do you guys' LAPSs suck as bad as mine do? <--rhetorical question), and finished up the last few things on the front suspension which included welding up a wallowed-out upper shock mount hole and finished installing my 1.25" sway bar and poly bushings (more leftovers from the Blazer), which makes the front suspension officially DONE except getting it aligned Unfortunately, none of this is really picture worthy...Buuuut, you can't have an update without pics, so I'll stick a few up of my 'new' brake booster and bracket assembly with the new master cylinder installed, which also shows the rad and shroud installed (I know, nothing to look at, but I am happy that stinking shroud is installed ). I went with a '68 3/4 ton booster to reap the benefits of dual diaphragm and still be able to use the '71-'72 1/2 ton disc/drum master cylinder. Most guys when upgrading will use the '71-'72 3/4 ton booster, which will only accept the C20 master cylinder. I also prefer the look of the earlier unit's shorter, straighter bracket. I don't like the 'lean' the later trucks' master cylinders have.Almost forgot, since I snapped the end off of one of my tranny cooler lines while removing the radiator, and the other had a compression fitting already patching it, plus the fact that they were a mangled, PO hand bent mess, I decided to bend up a new set. Used a couple of 6' lengths of 5/16" pre-flared steel line from Advance- like $3 each. What a pain, but MUCH cleaner, better looking, and safer than before. Also, in the process of installing the new brake booster assembly, I dropped the steering column and figured while it was out, I might as well 'shorten' it 3" (Thanks for the write-up, Putter) to give me some elbow room (I'm 6'6")... All in all, the progress feels good, but I think I should have accomplished more given the time spent. Seemed like everything was fighting me the whole way, one problem after another, but that's how it goes sometimes- hopefully the next round will go a little more smoothly and be more pic-worthy
#91 |
Great work as usual.
I bet those tranny lines were fun,...
#92 |
Local Redneck Authority
Those are great pics of the bed, I never realized how simple they are. Should've known I guess. Oh and good job on the shroud too!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#93 |
A320 Pilot/USAF Retired
Nice work, love the bed wood!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#94 | |
A guy with a truck
Yeah, 'fun' is definitely the word
![]() Quote:
Thanks, hope to be installing it soon
#95 |
A guy with a truck
Little bit more progress today... Started by bleeding the brakes to complete yesterday's booster/MC replacement. Wrapped up the last of that messy-ness and moved on to the interior, a MUCH cleaner place to work
![]() Below is what I started with and basically set about gutting the interior from there Upon pulling the carpet, I was pleasantly surprised to find only surface rust and NO rot whatsoever. Plenty of holes from POs drilling for various things, though
#96 |
A guy with a truck
Next, I set about taking care of what little rust I did find lurking. I started by using the shop-vac to remove all of the loose dirt and then attacked it with CLR. This stuff rocks!
![]() It took care of most of the rust and even got back to bare metal in a few places. Whatever didn't come up with the CLR was wire brushed and hit with rust converter and then coated in rust encapsulator. This will hopefully keep it away, for a while at least...
#97 |
![]() Join Date: Dec 2007
Gringo,
Where did you mount the prop valve? I'm guessing on the cross member 73 and later style? |
#98 |
VA72C10
Looking good man! Nice floor on that truck!!!
#99 |
A guy with a truck
I also tore into the dash, spending a bunch of time tearing it apart, removing the heater components in preparation for the Classic Auto Air kit, and re-wiring quite a bit as I went through it. At least with the seat out, I was fairly comfortable lying on my back working under the dash
![]() While I was in there, I replaced the dash cluster circuit. I did it with the cluster in place, as with the recently 'shortened' column, it is impossible to remove the cluster without dropping the column, which I didn't feel like doing two days in a row. Actually wasn't to bad to do the swap behind the dash, just a little tight, but nice to have the other components removed. Check out the old circuit- amazing I hadn't started a fire ![]() Also got around to mocking up the new floor covering (sorry, no pic- but, soon) and the new shifter, as I have always hated the silly Mega-Shifter. This is NOT a '70s Camaro- not that there's anything wrong with that, I just don't prefer the slot mags and air shocks look. If you look back on the earlier pics you'll also see a barefoot pedal to go with the '90s stepside bed- this truck was a true 'custom'- just needed a 'Heartbeat' logo somewhere The Lokar is well made and the perfect height, but will require some more head scratching before it is permanently installed- clearances are tight with the 700r4 in the tunnel...
#100 | |
A guy with a truck
I need this thing road-worthy by mid-June...Thanks! I was happy to find so little cancer lurking under the carpet, as I knew it had been wet before and wasn't sure what to expect.
| Bookmarks |
