Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-02-2011, 08:15 PM   #76
47thriftmaster
47thriftmaster's Avatar
Re: 72Jimmy 1st attempt at rust removal
It's going to look great, just be patient with the sanding.
47thriftmaster is offline   Reply With Quote
Old 10-03-2011, 12:27 AM   #77
PD1292
PD1292's Avatar
Mabe red would be better
PD1292 is offline   Reply With Quote
Old 10-04-2011, 05:42 PM   #78
fstway
Good work, this is going to some truck, hope the girls like it!
fstway is offline   Reply With Quote
Old 10-04-2011, 11:11 PM   #79
PD1292
PD1292's Avatar
Thanks, soon I am going to have the girls start helping, especially when it comes to wet sanding and putting it back together.
Good to see you got on the board.
I am currently working on the passenger side door. I sand blasted it down to bare metal last night and then patched a piece of metal on the bottom where it was really thin. Ill try to post some pictures. It was actually a truck door that i cut down to make a blazer door. Darn it though I did not notice the blazer doors had an extra part around the latch and threw the old one away.
I guess I will have to find one down the road.
Old 10-04-2011, 11:16 PM   #80
PD1292
PD1292's Avatar
This door is rust free and almost dent free. I did have to weld up some holes where several other types of mirrors were mounted. I know it is a lot of bondo but most of it will be sanded off.
Good to have a sand blaster to get inside the parts like this (last pic)
Old 10-05-2011, 04:52 PM   #81
fstway
Great job it looks really clean, what blast media are you usiing?
Old 10-06-2011, 01:14 AM   #82
PD1292
PD1292's Avatar
The media is just fine sand. cheap!!
If you get board one night, or day. read this build thread. amazing work all the way around. http://67-72chevytrucks.com/vboard/s...d.php?t=426382
Are you working on anything lately, fstway?
Old 01-10-2012, 12:33 AM   #83
PD1292
PD1292's Avatar
Not doing much work on the Jimmy but it is snowing here! Sorry for the guys up North, probably not as big a deal, but around here it is not as common. In fact in just a couple of days it will be back up to the 60s
Kinda weird, this is at 900 at night, it should be very dark but it looks like day time.
Old 01-11-2012, 01:05 PM   #84
thor
thor's Avatar
Snow in Texas? I would think it's about as rare common as snow in Western Washington. Fun to go play in tho!!!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 02-01-2012, 12:27 AM   #85
PD1292
PD1292's Avatar
Not much still going on with the truck, but I did start back on the door. I think this is the last of the bondo I will have to put on it. And I cleaned up the side mirrors. The PO decided to camo these along with the rest of the truck. Not show quality but good for a driver. I also picked out some of the best crome vent windows I have and cleaned them up as well. Still have to install the new rubbers. On to the pics.
Old 02-01-2012, 02:14 PM   #86
Brandoneh
Looks Great! sweet attention to detail.
71 K5 In progress!
Brandoneh is offline   Reply With Quote
Old 02-03-2012, 04:36 AM   #87
PD1292
PD1292's Avatar
I painted the door jams and inside with the Harbor freight special HVLP Spray gun but it spit and sputtered as I did. Then I went to the pawn shop, and look what I found. Score! Sharpe Razor 1.4 tip HVLP. Much more smooth and better flow. Great gun. Now its time to block and prime, block and prime, and on and on.
Old 02-23-2012, 10:20 PM   #88
PD1292
PD1292's Avatar
I decided I needed to blast some parts and did not have a blaster, so I decided to try and make one. This is the start. Why does it always turn out bigger than you plan, or is that just me...
Old 03-08-2012, 10:39 AM   #89
PD1292
PD1292's Avatar
Working forward on the sand blast cabinet, have it almost done. Here are some pictures.
Old 03-08-2012, 10:52 AM   #90
PD1292
PD1292's Avatar
I ordered the seals gloves and other items on line from a Made in the USA company, and the walls are made from 14 ga metal. Probably a bit of overkill but if i was going to do that much work I figure I want it to last.
Old 03-08-2012, 02:25 PM   #91
jonesky2
jonesky2's Avatar
that thing is sweet! have any plans to make one that you would want to share?
jonesky2 is offline   Reply With Quote
Old 03-09-2012, 04:02 PM   #92
PD1292
PD1292's Avatar
Thanks Jonesky2. I do not have any plans for it, I just kind of made it up as I went. I could post some things I would have done differently though and mabe some details on the sizes of the items. It is 3 1/2 feet wide, so I should have just made it 4 feet and not waste the half a foot of metal.
Old 03-09-2012, 04:18 PM   #93
jonesky2
jonesky2's Avatar
all the details you are willing to give would be sweet. I would much rather build one myself than buy one!
Old 07-31-2012, 10:59 PM   #94
PD1292
PD1292's Avatar
I have not posted in a little while. I have been busy doing other things, but have recently started again. I took off the whole front clip so I could fix some rust issues on the radiator support below the battery. I was going to order the part but just made it instead.
Old 07-31-2012, 11:03 PM   #95
PD1292
PD1292's Avatar
I also ordered a battery box, just the bottom part, as you can see the old one was rusted a bit.
Old 07-31-2012, 11:08 PM   #96
PD1292
PD1292's Avatar
I also ordered in a door skin. It was a triplus?, and the quality was very good in my opinion. However they sent me two, I guess just in case i messed up the first one?
Anyway. cut off the old skin, blasted the old interior of the door and then primed and painted the inside. I then fit the new skin seam sealed it and then tapped the edges to a crimp. time consuming but easy fix over all..
Old 07-31-2012, 11:13 PM   #97
PD1292
PD1292's Avatar
This is the test fit 1st pic, and the result after installed..
Old 07-31-2012, 11:18 PM   #98
PD1292
PD1292's Avatar
I have also been putting the blast cabinet to good use, and blasted every part i could think of that i wanted black, that i had off of the truck at the time, then primed and painted them all at once.
Old 08-02-2012, 10:46 AM   #99
bambbrose
Active Member
bambbrose's Avatar
awesome thread. I love the attention to detail. Very too reference, particularly on the rear panel work. Keep the pictures coming!
bambbrose is offline   Reply With Quote
Old 08-07-2012, 09:26 AM   #100
PD1292
PD1292's Avatar
Thanks bambbrose.. More pics coming as requested.
