#76 |
Re: Where does your exhaust exit?
Anyone make their own x-pipe? Seems like it should be pretty easy to cut an oval out of 2 pieces of 45 degree mandrel pieces from summit or whatever, and weld them together. Since it's short pieces, you would be able to get a tool in there to clean the welds up even. $14 roughly, instead of $100...
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic. |
#77 | |
78K & 79C Jimmys
close enough they would bang each other,once it was pieced it could be tacked and removed cut and welded properly was too many $$ as they wanted to go up and around being 4X4,might work better 4X2 tho
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#78 |
![]() lake |
#79 |
[><]Sofa King Dirty 4x4[><]
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
#80 |
My 86 K20 is a factory dual exhaust so far as I can tell , and it looks to be original and in good shape and no factory catalytic converters I assume its because its a heavy duty 350
#81 |
Just a temporary setup on mine till I can afford Flowmaster 40s, right now I've got stock manifolds and cat, with a good ol Cherry Bomb glasspack and single exhaust exiting in front of the left rear wheel. Sounds nice, looks great, but way too quiet for my tastes. Cant wait for the 40s!!
#82 |
out the tail pipe?
#83 |
Here are my weed burners.
"WIDER IS BETTER" (TRUCKS ONLY) |
#84 |
paper or plastic?
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
#85 | |
paper or plastic?
#86 |
Sick!!!!
#87 |
Old Heap Driver
Cool! no, Hot!, Well, you know what I mean!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#88 |
![]() Join Date: Jan 2008
Here is mine...
![]() 85 SWB 6.0 swap/heads/cam/pistons/headers/4L60E/3.73 posi/one piece windows/working towards air bags 04 Avalanche/9 inch lift/wheels 20x12 with 35 inch tires |
#89 |
Old Heap Driver
#90 |
Thanks! I still have some work to do on them, cause I was thinking about making them tuck more to where the bottom of the tip would be flush with the bottom of the truck.
#91 |
![]() Join Date: Jul 2010
#92 |
![]() headers in to 2.5 True duel's, no cats. Last edited by redneckchevy; 04-07-2011 at 10:35 PM. |
#93 |
I just got around to cutting my old mufflers and tailpipes off, put on two slip-on 2.5 Thrush glasspacks (same as Cherry Bombs) Sounds wicked at idle, pretty good going down the road and not bad at all at highway speed (55 mph, what can I say I've got 4.10s and a 3 speed) I do have a pretty noisy drone at about 35, which is where much of my driving is done, so I'm looking to add some tailpipes. The mufflers right now exit just before the rear axle, but past the front of the rear tires, so I couldn't 90 them out the sides in front of the tires. I also have some sort of bracket in the way keeping me from going straight back on one side, but I might cut it and adjust it to clear. I don't have the tools to bend a pipe around the bracket, so whatever I have to do is going to be made from off the shelf parts. Advance has 18 inch pieces and 45s or 90s, so depending on how far back the 18 inch gets me I may try for the 45. I don't think 18 will get me far enough to turn 90 and come out behind the rear tires.
Reason I came looking for this thread again was to see if I could figure out which would be the best way to do the tailpipes. Straight back would be easiest amd looks good, but I never liked that because of bashing into frozen snowbanks when backing up plowing, and like someone else mentioned having to shut the truck off to hook up a trailer. I like the 45 degree look, and the 90 also. I'm wondering if the side exit may sound even cooler at a lopy idle because you're only hearing half the cylinders at once, making an even lopier sound.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. Last edited by DetroitDan; 05-23-2011 at 01:47 AM. |
#94 | |
![]() Join Date: Oct 2010
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. ![]() Good Fences make good neighbors |
#95 |
Mine currently dump under the bed.
