06-25-2012, 10:53 AM | #76 |
Re: combo Tach/Fuel gauge cluster
Jon, I think the its more noticeable on the tach because they didn't add the 5, 15, 25, 35, 45, 55, 65 font to it.
John 82 Chevy Silverado 350ci/TH350 |
06-25-2012, 07:40 PM | #77 |
Does that have metal backing? its original right, so im assuming so. Im curious on how much that whole process cost you if you dont mind
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
10-13-2012, 01:39 AM | #78 |
Just thought you guys would want to see my factory tach:
Found a clean cluster out of a 85 C70. Swapped the pickup speedo in to retain my mileage, and the pickup oil PSI gauge, and lens. It all works the 86 dash connector circuits all matched up too! Best $40 i've spent in awhile. For those of you who have used the combo tach/fuel gauge, what are you using for a Brake warning lamp? |
10-13-2012, 11:40 PM | #79 |
Very interesting thread......I might have to get one
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
10-13-2012, 11:58 PM | #80 | |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
10-25-2012, 05:34 PM | #81 |
How bout pic lit up. Does it light up?
Posted via Mobile Device |
10-25-2012, 09:39 PM | #82 |
insidious 86 where did you get that tach and speedo? I want that.
10-25-2012, 11:34 PM | #83 |
A little off topic but, I thought it is weird that no one ever mentions removing spedo cable from tranfer case or transmission to give more slack when removing guages. Also a quick tip to anyone removing there guages anytime soon, wet sand and buff the clear guage covers. Its a real simple project and so worth it. You can see above insidious 86 has spider webbing on his clear plastic.
"Hank" 78 k10 6" lift 33's, good wrench 350 sm465 np205 Last edited by Jedipartsguy; 10-25-2012 at 11:59 PM. |
01-31-2013, 11:44 AM | #84 |
Will the Gm sports gauge work with my fuel injected 87? Called to ask but they weren't sure if it would or not.
01-31-2013, 11:53 AM | #85 |
Slots go on anything!
It should.
01-31-2013, 11:56 AM | #86 |
That's what I thought. Was kind of caught off guard when they said they would har to call and verify. Hopefully I will hear back soon.
01-31-2013, 04:19 PM | #87 |
It will work just fine. I put one in my truck but I used it with my 5.3. The tach comes with a wire harness that you run direct to your hei dist.There is a place on your dist to plug it in. It is a plug and play for you. I love mine. There is a thread on here that has some good info on the gm sport tach.
01-31-2013, 04:33 PM | #88 |
Cool. They called back and said I would need to run some type of adapter to run it off my coil pack??? I'm thinking I should be good just running it off the distributor right? I am about to swap in a vortec 383 but I am keeping the factory tbi system. Thoughts on this adapter?
I'm located in Huntsville, AL by the way. Small world. Lol Posted via Mobile Device Last edited by UATahoe; 01-31-2013 at 04:39 PM. |
01-31-2013, 04:38 PM | #89 |
No adapter needed. There is a white wire coming off of the coil that is the tach output. Run the tach signal wire from the tach (mine was brown) to that wire. It should accept a regular female spade connector. Done.
01-31-2013, 04:40 PM | #90 |
Awesome guys! Thanks for the help! Got it ordered.
04-09-2013, 10:01 PM | #91 |
Jon: Do you still like the aftermarket tach with fuel gauge? Does it light up?
Duane Central Louisiana 1985 k10 custom deluxe 1966 gmc 1998 chevy c2500 2003 chevy excab c1500 |
04-10-2013, 08:25 AM | #92 |
Honestly, I sold the truck before it got installed. JKnight has his installed; I think he was pleased with it.
04-10-2013, 08:30 AM | #93 |
I have one installed and I am very happy with it..The only negative thing I would say is that the orange color is a little off..No big deal to me..Otherwise I am very pleased.
04-10-2013, 08:44 AM | #94 | |
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
04-10-2013, 08:51 AM | #95 |
That's how I always do it, unless it has cruise. If it has cruise, I will take it loose under the hood.
04-10-2013, 08:53 AM | #96 | ||
I would say not a 100% perfect match to an original it does far out weigh any other option for our trucks for the low cost of $195. Posted via Mobile Device
04-10-2013, 09:45 AM | #97 |
I agree with JKnight. I have said it more than once that I was way better off going with the gm sports fuel/tach guage rather than spending $250.00 with a factory tack and maybe it worked. Not a factory exact match but it looks great.I put mine in a 91 cluster. Had to have a electronic speedo with my 5.3.Mine looks great.
04-10-2013, 06:05 PM | #98 |
MOTORHEAD!
What is the part you need to run the gmsportssalvage tach with a full msd ignition?
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
04-10-2013, 06:24 PM | #99 |
I think there is only one tach. If you have an output for a tach, it should work.
04-14-2013, 07:02 PM | #100 |
Well, I finally found a tach setup for my truck. Took almost two years from when I started this thread on 6/17/2011 and here it is 4/14/2013. Geesh. Yes I know I put on the white face overlayment but thats the look I was going for. When I get a chance to take some night pictures I will get those up on here as well. The black box up the speedo and tach which is normally used for diesel engines, has a service engine soon side and a blank side. I have never before seen the service engine soon in that box before and I am very curious as to what truck this bezel would have originally been in. I am using the blank side as the brake warning lamp since that area is not being taking up by the fuel gauge. The second pic is to share the original mileage on my truck. All 437,515 miles. The original motor was pulled at 417,000 though it was still running strong it was just a 305 and could not handle what I was planning for the truck but it served the original owner and myself very well. My girlfriend thinks I should make a coffee table out of the original motor. I dont know though.
