09-08-2011, 05:46 PM | #76 |
67cheby
Re: SLOSH TUBZ..bolt in inner fenders for 67-72 chevys
can you take a pic of yours with stock hinges when it is layed out and let me see where the tire is compared to the hood hinge , the problem with mine is the tire comes up totally through about 1/2 of the mounting point of the hinge. Of course all of this depends on tire size and how low you are, the nice thing about these is they are fiberglass / very easy to customize if you wanted to add a pocket for your hinge to set in . This first pic i am posting shows the truck before the Porterbuilt Dropmember, just bags and control arms, the second pic shows where the tubs come / compared to where the factory hood hinge bolted up, i will try to get pics tonight of the tire compared to the mounting area without the inner fender in
09-08-2011, 06:08 PM | #77 |
454 MAKES IT ROAR
Dam! I see what you mean now, even on bags and a pocket made to accommodate the hinge you may have scrub issues, and absolutely no way with a DM.
I'm not even at the air stage yet but I really want these instead of the exposed wheel thing under the hood, just didn't want to have to go to the trouble & extra expense of changing the hood hinges. I'm still happy you've come up with these, they're great.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
09-08-2011, 06:46 PM | #78 |
67-72 parts collector,…
Porterbuilt hinges and your problems are solved.
09-08-2011, 07:50 PM | #79 |
I have noticed Porterbuilt has the answers to alot of problems
Rex |
09-08-2011, 08:27 PM | #80 |
09-08-2011, 10:51 PM | #81 |
67cheby
PORTERBUILT ROCKS !! just sayin .....I got a set of SLOSH TUBZ for my truck today, finally the finish is perfect they did a great job on the new molds, gonna get them fitted this weekend pics following !!
09-09-2011, 09:24 AM | #82 |
67cheby
heres the pics
09-09-2011, 11:53 AM | #83 |
they look great
Doug Looking for a 67-72 short bed driver..... |
09-09-2011, 01:30 PM | #84 |
454 MAKES IT ROAR
Quite an acheivment mate....they look fantastic.
09-09-2011, 01:47 PM | #85 |
67cheby
thanks guys !!
09-09-2011, 07:22 PM | #86 |
Are these from a 'new' source or from the original group you've been working with?
09-10-2011, 10:50 AM | #87 |
67cheby
these are from the original source,they rebuilt the molds to correct the finish issues they were having, it will be a couple weeks before the New guy has a chance to look at them and see what he thinks
09-10-2011, 07:52 PM | #88 |
Tot Roddin'
Looking good... now where's those installed pics???
I always have to stir the pot.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-10-2011, 09:21 PM | #89 |
67cheby
tomorrow tomorrow...i will install the tomorrow , you are only one day away !! my musical !!
09-12-2011, 09:18 AM | #90 |
67cheby
monday morning !!
09-12-2011, 09:19 AM | #91 |
67cheby
couple measurement pics
09-12-2011, 09:21 AM | #92 |
67cheby
Putting an order in this week ...Let me know if you are ready !!
09-12-2011, 10:16 AM | #93 |
Any idea on the least amount of backspacing on a 8.5" rim?
Just trying to keep from having rubbing issue, on the outside edge. (maybe set up a criteria for purchase of these tubz) I'm interested in a set picked up, (not shipped). Price?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-12-2011 at 10:23 AM. |
09-12-2011, 10:27 AM | #94 |
67cheby
i honestly dont have a clue..i know that sounds bad, but backspacing has always confused the heck out of me, i can take a pic laying on the ground and looking up to the inside of the outside edge of the fender, is that the area you are concerned with ?? the reason i made these with the hood chanel in is , one they work with my wheels and two i didnt want to cut that lip on the fender ! but if you want to run a differnet offset you can always cut out the fender and hood lip and move this hump in the pic over to the outside a little more
09-12-2011, 10:29 AM | #95 |
67cheby
give me a shout if you have any more questions, Mike 1 479 599 9664
09-12-2011, 08:52 PM | #96 |
Mike , this is the way I keep wheel width and backspacing seperate---the width of a wheel is measured inside the beads--in other words a 10" wide wheel is 10" between the beads but will measure almost 11" if U hook a tape on outside of beads!! Backspace is measured from BACK of hub surface to OUTSIDE of rear lip-I usually lay a straight edge across back of wheel and measure to back of hub for accurate figure for Backspace!!
I have to think ever time I order wheels lol......sent U a pm on tubes......jim |
09-12-2011, 10:39 PM | #97 |
67cheby
took some measurements tonight my front wheels are 20x9's with 6 1/2 inch back space , i also took some pics from underneath the fender shooting up to show clearance , will post them first thing in the morning
09-13-2011, 09:48 AM | #98 |
67cheby
here are the clearance pics
09-13-2011, 09:54 AM | #99 |
67cheby
here are a few pics of my prop valve bracket it flips it sideways underneath the master cylinder, it is from cpp and i think it was $20
09-13-2011, 10:36 AM | #100 |
454 MAKES IT ROAR
Like that prop valve bracket, cpp are another good company always re-inventing things that make life easier when modifiing our trucks.
Have you had a look at the clearence from underneath when the wheels are at full lock?
