Old 08-27-2012, 07:52 PM   #76
robozride
Re: 1956 gmc 100
Well...the box is on for the last time and bolted down. Some may think its backwards to do things like this but its the only way i can stay motivated, if i dont see cool progress i lose interest fast. Next on to the doors, they are lined up fairly well but are coming off so i can install the one piece glass and strip them down to refinish. I should have an update in a month or so....lol
robozride is offline   Reply With Quote
Old 08-27-2012, 08:33 PM   #77
arturo7
arturo7's Avatar
Re: 1956 gmc 100
The two tone color scheme will be excellent for leaving the scene of a crime.
"It was a red truck."
"No, it was a blue truck!"
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 08-27-2012, 08:34 PM   #78
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1956 gmc 100
Looking good!
ChuckDriver is offline   Reply With Quote
Old 08-27-2012, 09:58 PM   #79
Kim57
Kim57's Avatar
Re: 1956 gmc 100
Looking good. I like the wheels.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-09-2012, 12:53 PM   #80
robozride
Re: 1956 gmc 100
I got the doors off and stripped the wings, glass and paint. The skins are good other than dings and dents. the bottom insides are rusted in the usual place, i think im going to buy door bottoms and replace them but im undecided on which way to go. Once again i must point out the obvious... Whoever did this truck last was a bondo MASTER! lol.I have the new one piece glass cut and the extra track so i can go ahead with the Blackdiesel method. Im still motivated at this point but every time i look at my coupe i want to switch projects.
Old 09-09-2012, 01:16 PM   #81
Hogsophist
Re: 1956 gmc 100
Nice
Hogsophist is offline   Reply With Quote
Old 09-09-2012, 01:27 PM   #82
Kim57
Kim57's Avatar
Re: 1956 gmc 100
Two projects, I have enough trouble with one.
Keep up the good work.
Kim
My build thread
Old 09-09-2012, 02:47 PM   #83
ChopperCity256
ChopperCity256's Avatar
Re: 1956 gmc 100
yup id like to see more of this..
ChopperCity256 is offline   Reply With Quote
Old 09-09-2012, 03:05 PM   #84
Chevette
Chevette's Avatar
Re: 1956 gmc 100
Lookin' good! Your truck seems to be in very good shape. Good luck with the build.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 09-25-2012, 04:02 PM   #85
robozride
Re: 1956 gmc 100
I finally got around to rebuilding the door hinges. I bought a new pin kit...but of course once i got in there they had drilled them out and replaced the pins with bolts. I went to the next size bigger hardened bolt cut off the threads and redrilled the hinges, added spacers and pianted them. More work than i had planned but not hard and fairly easy.
Old 09-25-2012, 04:04 PM   #86
robozride
Re: 1956 gmc 100
I finished painting the front clip, cleaned up the emblems and installed them. About all i have left is to repair the door= Bottoms, lotsa dents and one piece glass.
Old 09-25-2012, 04:21 PM   #87
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 1956 gmc 100
Originally Posted by robozride View Post
I got the doors off and .... the bottom insides are rusted in the usual place, i think im going to buy door bottoms and replace them but im undecided on which way to go.
Robo,
That door looks great. Did you wend up doing ANYTHING to the inside or outside of the doors where they're rusted?
Mine have the usual crust inside on the very bottom. I've thought about using my el cheapo sand blaster in there and after blowing them clean using a POR-15 or KBS type product in there. What do you think of that approach?
I've only got rust-through in a small area on one door so I've wondered if I could just cut out/replace that area or if I should cut the entire bottom few inches off, then do as I wrote above?
Dan in Pasadena is offline   Reply With Quote
Old 09-25-2012, 05:13 PM   #88
robozride
Re: 1956 gmc 100
no, i think the por15 is a good idea but i would replace any rust areas with new metal. I bought new inner door bottoms and will have to install them when i do the doors.
Old 09-25-2012, 06:48 PM   #89
Kim57
Kim57's Avatar
Re: 1956 gmc 100
Looking good Robo.
Nice fix on the hinges.
Kim
My build thread
Old 09-25-2012, 09:51 PM   #90
Wootdog
Wootdog's Avatar
Re: 1956 gmc 100
Sweet. I like your progress.
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 10-07-2012, 02:25 PM   #91
robozride
Re: 1956 gmc 100
Getting close now! to bad it'll be snowing in a few weeks lol. I have to finish the doors and some odds and ends and thats it. I am going to lower the front an inch or so.. i want a little more rake and my opinion is that theres to much tire showing. I cleaned and painted the GMC emblems but now i dont like the red...i'm thinking of painting them the same graphite color as the wheels? what do you guys think?
Old 10-07-2012, 03:58 PM   #92
chevyboy73
chevyboy73's Avatar
Re: 1956 gmc 100
I'd say the color of the wheels! looks good anyways needs another color on the truck like white stripes! good job and good luck
2011 Silverado ECSB LT
2000 Silverado RCSB 2WD
super bad habit of not owning a vehicle for a long time
chevyboy73 is offline   Reply With Quote
Old 10-07-2012, 04:28 PM   #93
robozride
Re: 1956 gmc 100
Thanks! yes, i plan on having some striping done but im not sure of colors yet.
Maybe some door art not sure.
Old 10-07-2012, 04:33 PM   #94
Red Foreman
Red Foreman's Avatar
Re: 1956 gmc 100
X2 on painting in emblems with the wheel colour. Great job so far, looks good. I'm a bit jealous though, I remember you started your project way after mine.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 10-07-2012, 06:38 PM   #95
Kim57
Kim57's Avatar
Re: 1956 gmc 100
Looks real nice. I like the contrast of the red.
Kim
My build thread
Old 10-10-2012, 07:39 PM   #96
robozride
Re: 1956 gmc 100
I tried the graphite color on the emblems and i think it made them look old. I tried white and i like the contrast so thats what i'm going with.
Old 10-11-2012, 09:31 AM   #97
andrew_k
Re: 1956 gmc 100
Truck looks great, robo!
andrew_k is offline   Reply With Quote
Old 10-11-2012, 04:48 PM   #98
Red Foreman
Re: 1956 gmc 100
Looks like your pretty handy with the brush, you have done it enough times, could I send you my GMC emblems?
My Build 56 GMC
Old 10-13-2012, 09:29 PM   #99
Boyd11
Re: 1956 gmc 100
man looks good
Boyd11 is offline   Reply With Quote
Old 10-13-2012, 09:32 PM   #100
Boyd11
Re: 1956 gmc 100
i ad a 55 big window
