03-06-2012, 09:23 PM | #76 | |
Re: The beginning, my 57 LS powered streetrod
Did you use the same mount on both sides?? "CD59RH" and I am wondering if the clearance of the Nova clip is different than the Camaro??
Cause I found this info on the camaro mounts and was wondering which "tall" mount you used?? http://www.camaros.net/forums/showth...=161625&page=2 Quote:
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
03-10-2012, 02:36 AM | #77 |
ZR2RICK, what are you doing for a radiator, or are you that far yet?
03-10-2012, 08:06 AM | #78 |
I used the tall CD59RH/LH frame mounts.
and as far as radiators go ,I have a good stock one but not sure how well it will cool??
Learn to deal with reality, or reality will deal with you. |
03-10-2012, 03:31 PM | #79 |
OK,Thanks....Ok one more question....did you use them on there respective sides?? LH on Left (Driver) and RH on Right (Passenger)...sorry for the silly questions just want to be sure.
Thanks Tim
03-15-2012, 09:25 AM | #80 |
They will work either way, it depends on the position of your engine, I don't recall which way mine are but I swapped them to get them more centered on the crossmember.
03-19-2012, 05:56 PM | #81 |
OK, you guys using LS motors, what in tank pump set up are you using? I have a 69 Mustang tank. I would like to use a stock type unit with the level sender attached.
03-19-2012, 06:31 PM | #82 | |
Tripple Five Fanatic
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
03-19-2012, 08:18 PM | #83 |
Thanks, yea that's kinda what I have been thinking, mine is the smaller tank. what did you do with the stock sender hole ?
03-19-2012, 08:23 PM | #84 | |
Tri5
03-19-2012, 08:59 PM | #85 |
That will work,thanks, can I ask what year/model pump you used?
03-19-2012, 11:03 PM | #86 |
2002 LS1 pump and bucket but I changed the pump to a Walbro 255 pump.
Tri5
03-20-2012, 12:20 AM | #87 |
ZR2RICK
I know it's a late in the thread but from what I know is S10 A Arms interchange with G-Body stuff like 78 - 83 Malibus Montes Regals however the interesting thing is the G Body's frames are narrower by a significant amount - how much not sure. My son has a G Body and we are about to try and put S-10 drop spindles so I`ll let you know.. On the HAMB site there was a thread on how to section and lower your A Arms the way they used to do it in the fifty`s. The guy did a nice job on the thread and work was top notch to. Interesting how how hot rodding goes full circle |
03-20-2012, 09:39 AM | #88 |
Thanks Tri5Nerd, I'll look into that pump, does anyone know if the Silverado /Tahoe pumps measure the same as the Ls1's? Thanks 50/seven for the clip input, I'm still measuring and head scratchin on my front clip width issue but will most likely narrow the clip, as I have the Nova clip rebuilt already, I just need to figure if I'll have to cut the tunnel for engine clearance or possibly cut the motor mounts into the crossmember to keep the engine height where it is.
07-04-2012, 02:14 PM | #89 | |
Also - see if you can cruise some of the newer truck forums and see what kind of HP people are getting on stock fuel systems. All the LS motors run a similar fuel pressure and I'd be shocked if any OEM pump on an LS car / truck was insufficient to feed any other LS engine - up to 400+ HP |
11-29-2012, 10:47 PM | #90 |
Been a while, I'm newly retired (after 35 years)and adjusting to a different life routine, anyway this truck has sat too long so here we go again, still working on the details of narrowing the nova clip, but got a late model GM fuel pump assembly mounted in the 69 mustang tank Iv'e removed all but the 3 longest leaves and have 4" blocks installed and plan on air over leaf bag mounts (homemade)? ,and now I need to build a notch to lower the rear several inches, so what do you bagged 55-59 guys got that can save me a few grey hairs? bag size, notch depth, design, ect.....
12-01-2012, 09:07 AM | #91 |
A320 Pilot/USAF Retired
Welcome back!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-03-2012, 07:45 PM | #92 |
Thanks, feels great to be back at it, got my bed set back on today so I could get the bedsides cut and picked up a pair of trailer fenders for the mini tubs, ( got a new Henrob torch I'm dying to try out!) waiting on the 2" rear wheel spacers, next I will need to figure out ride height so I can start on the step notches, have the front set with 3" between the cross member and floor, but not sure about the back though? also kicking around the idea of either ladder bars or a 4 point w/bags in back ??
12-03-2012, 09:41 PM | #93 |
Sure do like the stance.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
12-04-2012, 08:58 AM | #94 |
Lookn good!!!
12-04-2012, 09:35 AM | #95 |
Looking good. Can't wait for more.
Dino's 3rd annual Pre-ShowGit Down http://67-72chevytrucks.com/vboard/s...12#post5639812 |
12-04-2012, 10:34 AM | #96 |
The stance looks good.
Kim |
12-08-2012, 04:27 PM | #97 |
got the step notches made and tacked in place, need to weld up and add bump stops, also got the 2" wheel spacers I needed.
12-08-2012, 04:40 PM | #98 |
Looking good.
Kim |
12-08-2012, 04:45 PM | #99 |
Why do you need wheel spacers?
12-08-2012, 07:52 PM | #100 |
wheels and tires are to narrow for the rear end I have, may end up with a wider unit down the road.
