#76 |
Re: Windshield gasket blues: Precision supplies Steele and possibly Soff Seal
Just read through this thread. I keep reading about using "rope cord". I have done several and never broken one (knock on wood). I use para cord and lots of dish soap. The para cord is very very strong and as thin as a cheap shoe lace...works great! *Sorry if this was already posted...
#77 |
Florida Edition
![]() ![]() Join Date: Oct 2010
I checked your installation link and nothing about our windshields. I found out my gasket is Precision and was installed by a pro (I am a project engineer for a large glass company). Here is a pic of your installed product....
At this time this is the only major flaw on my truck. BTW my trim is OEM, any thoughts on this before I have it redone AGAIN?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#78 |
i got a window seal and had it professionally installed to and it leaks three times and still bunches up in corner its like they made the rubber to long ,my old one i took out was the same way leaks bad in the corner if anyone finds a better window seal let me know i dont mind paying more for a better fitting one
#79 | ||
Tech Help
![]() Join Date: Apr 2012
As you know many factors can come into play when an install doesn't fit right. Glass, Trim, Gasket & the install itself. It's important for people to note all these aspects to try to find the right solution. My research & development guy's son has a '68 which they replaced the weatherstrip on about 6 weeks ago. I've asked them to redo it and video the process to see if this will help any. Quote:
I will update this thread once we have the new install video produced. Derek
PRECISION Updates Subscribe --->Installation Videos Follow ------->Instagram Like---------->Facebook |
#80 |
Video would be great. I'll be doing this very soon. New precision gaskets, original trim, and after market glass. What rope do you guys use and where can I get it?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#81 | |
Tech Help
http://precisionrestorationparts.com...-1-4-cord.html
#82 |
Tech Help
We have now done the install for the windshield weatherstrip & chrome and have posted the video on our channel.
http://youtu.be/SOU_0HpS7To If you have any questions about the install feel free to post them. -d
#83 |
C/10 junkie
The video makes it look easy.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#84 |
Now that's service. Thanks for the video.
#85 |
nice
project: "my happy mess" |
#86 |
mine was installed by professionals also and looks like renokeens , im went out and checked and they didnt have the second layer rubber over the pinchweld im using a butter knife and fixing it , , lol
#87 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Question: Was that OEM or reproduced trim used for the install?
Great help. Thank you for making the time to put that together!!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#88 | |
Tech Help
We're fortunate to have Greg on our team who has 20 years experience in the auto glass field. This is his son's truck which is why we were able to get this done. Sadly, auto glass techs (the pros) doesn't guarantee a good install as some don't have the experience necessary with these older rope in type installs, so it's important to find one that comes recommended or that has a good reputation. Derek
#89 |
I'd like to see a shorter version of this made into a sticky? Maybe the video and some tips. We should keep it short and simple.
Can anyone recommend a known experienced installer in the SoCal area, eastern LA or western San Berdo counties preferred? I've called around and can't find anyone that will say they have experience with these old dogs, just that they can do it.
#90 | |
What?
My burb and PU both need windshield gasket work, and everyone around the SW Riverside county area that I have talked to refuse to touch the glass install on these trucks. Very good instructional video BTW!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#91 |
![]() Join Date: Jan 2001
The 67-72 Chevy and GMC trucks were one of two windshields I always installed from the top first. (The other was the old Jeep Wagoneer) The tight upper corners make it very difficult to get even pull on the gasket if you start at the bottom.
#92 | |
Tech Help
-d
#93 |
at 16.13 after talking about the secondary lip ,the hook tool pulls the rubber next to the glass............do not do that at home .leave that trick to the pros. great job n video
#94 |
GEARHEAD
I'm having a different kind of problem. Last year I had a new windshield installed by safelite, with the trim. The installer was experienced and got it in without too much problem, but it was as if the windshield was a bit too narrow. The fit top and bottom seemed good, but it was loose on the sides. The gasket will slide side to side on both sides. He said it might seat in after a while, but they would cover it if it didn't. One other problem was the glass had ripples in it and seemed to be rounded from top to bottom more than the OEM glass, which was pretty flat. Safelite branded glass.
I gave it a year of driving off and on, but it never tightened up and it leaked, so I called them back. He came with another safelite windshield, but figured it would be a waste of time, so they ordered another brand for it and came back a few days later. The glass was smoother, but fit almost the same as the other one. Maybe just a bit tighter, but I can still slip my fingers under the gasket by the windshield frame post. The gasket does not bunch in the corners, it seems to fit the glass well. It just won't fit tight to the side frame posts. Are the installers doing something wrong? Is the glass not wide enough or have enough curve back into the frame? I just don't understand. They tried 2 different gaskets, same results. I didn't do any massaging of the windshield area in my body work. Didn't even replace rockers. I took the old glass out myself and it was a nice tight seal all around. What could be the cause of this?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#95 |
ask for pilkington brand .
#96 |
One of the First
![]() Join Date: Jan 2000
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#97 |
Florida Edition
Update on mine today......after 3-1/2 hours the installer is taking the glass, vinyl and trim back to their shop to WATCH THE VIDEO and see what they can learn
#98 | |
Carpe manana
* same arrangement save for repro trim (both 71-72 AND <70 with correct matching Precision gaskets) did NOT work despite four attempts by three different installers - the trim would not conform to the gasket - beware repro trim
#99 |
67cheby
![]() Join Date: Sep 2008
Thanks for your help ! Just ordered mine now ! Great customer service !
#100 |
Tech Help
Just one last thing that wasn't addressed in the video is bedding compound. We did not use any and have done a water test with no leakage to the weatherstrip. However it can't hurt to add a little to give more confidence for a water tight seal.
Derek
