#76 |
![]() Join Date: Apr 2003
Re: 72 cheyenne super parting
kelly`s out on everything.
heavymetalchevy- your up on the heater control. add $10.95 for shipping if your still interested. ttt for the rest |
#77 |
you still have all the a\c stuff?
Pete The worst I ever had was wonderful ![]() 69 SWB work in progress 97 Ranger 6in. lift on 35's 04 325i lady's ride |
#78 |
yes i do
#79 |
#80 |
southern parts, you have a PM.
#81 | |
Just a Member
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
#82 |
is the dash pad still available ? and if so , what is the condition and price? Tony
#83 |
A/C pics for jessewebb & 99-ls1-ss. a/c control with cables, all levers good, diverter is good but top piece to supply center vent has been glued to it , all 3 vents in good condition, S duct is cracked, i`m sure the heater core needs replaced, outer box housing in good condition, has a little rust on the bottom where it mounts to the firewall.
orange cab pics- a/c control has 1 lever broke, diverter and s duct condition unknown, driver side vent ? not going to separate. |
#84 |
ortegamotor- sorry the dash pad is cracked.
#85 |
#86 |
![]() Join Date: Aug 2008
I didn't get the notification that you posted photos. Sorry to take so long to reply. All of them look good. I just don't know which one is right for the swap and small balancer. (It had a lwp nd large balancer when I bought it.)
I also need the two phillip head screws that hold the trim cover under the column on, as well as the ignition trim bezel if it is in good shape, and the rear axle brake lines if they aren't bent up or rusted. |
#87 |
could you post a short list of what has sold?
I am interested in parts, but I don't wanna bug you about stuff you've already sold. And if no one has claimed the door panels I'd like them and I would part with the wood grain inserts as I see several people are wanting just those and I don't like the wood grain.
![]() 1971 Chevy Cheyenne 1972 Chevy Cheyenne 4x4 |
#88 |
wideside72- your balancer should be the same, long or short waterpump. do you have a pic of the front of your engine?
mcnugget- doorpanels are still available, $100 plus shipping the only things sold are glove box door, vent and side windows, misc cables. |
#89 |
Is thr radio still available with the bracket ? If so how much including shipping to zip 32136? Thanks
#90 |
Actually, the balancers for LWP and SWP are different. LWP has the 8" balancer, which is too large for the SWP to fit because it is closer to the engine. I know because I had to buy a new 6 1/2" balancer when I went from LWP to SWP in order to get the WP to fit. I have the timing tab from the LWP set up, it is too far from the smaller balancer and I blieve the timing mark is different.
#91 |
my hollander shows the same balancer #6272222 from 70-76 on trucks. 73 up would be a long waterpump. here`s a pic of the engine i just pulled from this truck. 8" balancer swp.
#92 | |
I guess what I need to know from you is, do you have a timing tab from an engine with a 6 1/2" balancer? |
#93 |
ttt
#94 |
one more time ttt
#95 |
![]() Join Date: Jan 2009
Do you still have the blue a/c vents still?
Kevin 67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c 69 custom/10 swb 350/350 4/6 drop tach,tilt 71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning 96 gmc swb ![]() |
#96 |
![]() Join Date: Apr 2011
Hi looking for a good set of rear wheel tubs dings&scratchs not a big deal just need to have good flanges thanks.
#97 |
becker67- going to keep everything together for now. i may have some others. It will be a couple days before i can check.
reeds 72- the tubs in this truck have some pitting but are still solid. $75 plus shipping. i`ll get pics in a couple days if your interested |
#98 | |
#99 |
Yes i am interested just need the flanges to be good can work with rest all wait for some pics thanks for your time reed
#100 |
Prestige Worldwide
![]() Join Date: Feb 2001
What kind of shape is the lower black/chrome trim in? What do you need for it or do you have any decent "driver condition" pieces laying around?
