Old 12-20-2012, 05:54 PM   #76
BuiltwithIvy
Re: Project Immoral Appearance
a pillers tacked after checking to make sure everything is square, might be hard to tell, but again I used some old nails to help weld the gap up, inner roof is now on inside of cab, outer roof is to the outside, tomorrow will be more fitting and trimming as I go, should have it all tacked up tomorrow
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 12-20-2012, 09:08 PM   #77
aggie91
I'm just glad to be here!
aggie91's Avatar
I know where LIberty Hill is. If I go thru Austin on my way to Fredericksburg I pass right thru there.
Are you going to leave the wedge chop or remove some from the rear also?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-20-2012, 11:46 PM   #78
BuiltwithIvy
im going to leave it wedged, i like the aggressive look it has, ill be here through the 15th of january so just let me know if you plan on passing through
1930 Tudor Sedan
Old 12-22-2012, 09:46 AM   #79
BuiltwithIvy
rear inner and outer skins fit together
1930 Tudor Sedan
Old 12-23-2012, 12:32 PM   #80
BuiltwithIvy
So I am taking a couple day break from the chop due to holidays and extended family in town, but thought I would tell you about how I plan on doing the bed wood. There is a process called hydro-dipping that will let you coat metal/plastic in a pattern of your choice. (http://www.hydro-dip.com/index.htm) I helped build a 41 cadillac a couple years ago where we did the dash, and it turned out amazing. (http://www.sachserodshop.com/current/large/harvey55.jpg) So I decided I am going to take some chunks of aluminum and create "bedwood" from them using steel strips in between that will be painted to match body color. I am going with the redish color I previously sprayed up top, with a black bottom, and a ghosted silver in between the two. I will then do a dark burlwood bed. (http://www.hydro-dip.com/images/Cust...es/WTP-186.jpg). what do you guys think?
1930 Tudor Sedan
Old 12-26-2012, 11:49 PM   #81
BMERDOC
BMERDOC's Avatar
That hydro-dipping stuff looks pretty cool! I'd like to see what it looks like in a bed. Wht did you use for chassis paint?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-27-2012, 01:16 PM   #82
BuiltwithIvy
I used a RustOleum spray paint (http://www.rustoleum.com/CBGProduct.asp?pid=29) works really well and has some great texture to it once it dries out, seems pretty hard too as I haven't really been able to scratch it.
1930 Tudor Sedan
Old 01-07-2013, 11:46 AM   #83
BuiltwithIvy
upper a pillers fitted to roof, and a pillers pie'd to meet the roof line width
1930 Tudor Sedan
Old 01-07-2013, 11:56 AM   #84
BuiltwithIvy
as you can see, there is quite a bit of extra material over lapping the windshield frame, we cut some out of the upper roof to see what needed to be done, and decided to start with the inside, using cleco's, we held the inner roof in place, and marked it for a rough cut, after the cut, we replaced cleco's with small self tapping screws to hold it tight
1930 Tudor Sedan
Old 01-07-2013, 12:00 PM   #85
BuiltwithIvy
with the inner held in place, we moved to the outer, the remaining steel above window frame didn't have quite the right angle, so we heated it up and bent it down with a pair of channel locks, finished the rough cut of the upper roof, and began the cleco process from the middle out, pie cutting the corner to get it to fit properly
1930 Tudor Sedan
Old 01-07-2013, 02:18 PM   #86
BuiltwithIvy
had to cut the corner some more to work it together, replaced some clecos with self tapping screws, ground the extra material down to window frame, tack weld together, stopped for some lunch, then back to work the driver side
1930 Tudor Sedan
Old 01-07-2013, 04:48 PM   #87
BuiltwithIvy
drivers side relief cut, self tapping screws in, tack welded down
1930 Tudor Sedan
Old 01-07-2013, 04:52 PM   #88
BuiltwithIvy
working on finishing the inner roof to windshield frame
1930 Tudor Sedan
Old 01-07-2013, 04:55 PM   #89
BuiltwithIvy
front and side profiles now that it is all tacked together
1930 Tudor Sedan
Old 01-07-2013, 07:28 PM   #90
BuiltwithIvy
beginning to fab new dash into place
1930 Tudor Sedan
Old 01-07-2013, 07:42 PM   #91
gdavis
gdavis's Avatar
I see you got a lot of work done and a lot of work ahead of you. But, If you are like me you are enjoying yourself.
gdavis is offline   Reply With Quote
Old 01-07-2013, 07:47 PM   #92
BuiltwithIvy
oh yeah, I love doing this, unfortunately with school I have only been getting about a month a year to work on it, but its moving along nicely in my opinion. a large majority of the major custom work has been done thankfully, only major things left to do after the dash is to section the hood, and suicide doors
1930 Tudor Sedan
Old 01-08-2013, 11:47 AM   #93
67cheby
67cheby
67cheby's Avatar
WOW..lots of metal work ! Looking Good !
67cheby is offline   Reply With Quote
Old 01-08-2013, 08:04 PM   #94
gdavis
gdavis's Avatar
what are you planing on the dash. r u going to put a special door for the glove box on the r
Old 01-09-2013, 11:28 AM   #95
BuiltwithIvy
I don't have it all planned out exactly yet, kind of a do it as I go and make sure it looks alright, but I do plan on keeping the glove box door and just stretching it to match the new opening.
1930 Tudor Sedan
Old 01-09-2013, 05:25 PM   #96
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
THAT dash is sweet looking.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-09-2013, 07:33 PM   #97
BuiltwithIvy
thank you! gonna work on it more tonight and see if I can start to get it looking more like a "complete" dash
1930 Tudor Sedan
Old 01-10-2013, 12:56 AM   #98
BuiltwithIvy
so went out tonight with the goal of building the middle section of the dash, took some time to tack weld some reinforcements in, starting making the upper middle dash section, didn't like it how I was doing it, so cut it apart to do it a different way, got that tack welded in, and then took a bunch more measurements to realize that when I tacked the reinforcements in, I accidentally bumped one side of the dash up and over, ended up cutting a bunch of the tack welds, and re-tacking it back into place, what a surprise, it looks a lot more square now lol, gotta work on more patches tomorrow, as well as stretching the glove box door. Need to buy some steel conduit to start shaping how the out sections will meet the cab
1930 Tudor Sedan
Old 01-10-2013, 11:48 PM   #99
BuiltwithIvy
most of the center patched up, and starting to map out the transition from dash to door area
1930 Tudor Sedan
Old 01-11-2013, 05:43 PM   #100
BuiltwithIvy
passenger side dash to door fab, not done, but wanted to take a short break
1930 Tudor Sedan
