#76 |
Re: six lug rims whatcha got?
Newfisher,
I have a set of those slots. They are from a 70's Wagoneer IIRC. The tri-bar and tower are Gorilla brand. I have a set of those on my classic car. Soooooo . . . . I want to know, Where did you get the cone cover? Aluminum or steel or stainless?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#77 |
Pretty Slick! Way to think outside the box.
1948 Chevy 1/2T 1964 Chevy 1/2T stepside short bed 1939 Pontiac coupe Street Rod 2005 GMC 1/2T short bed |
#78 |
The cone covers are from the 80's and are aluminum. You used to be able to order them through the wheel suppliers like Gorrilla Industries. They stopped appearing in the books a few years ago, maybe someone has some old stock? I found these ata buddies place and tried to find a few more sets to do this to the 5 slots, kind of like a modern day version and take a few sets to the swap meet, but I haven't had any luck finding the cones. . . Refrence pic ![]()
GOD BLESS AMERICA! |
#79 |
Mixing old school and modern center caps. Here's an idea.
The Chevy Colorado with a factory steel wheel uses a center cap that presses onto the 6 lug nuts. Here's a pic of a Colorado wheel without the cap and a cap picture I stole off of eBay. It might look weird on a slot, but then again it might look good. I have not tried it to see. Chevy Colorado factory steel wheel
#80 |
New 20s on the front for now, Ill run red rims with caps and rings about half the time, and switch to the newer 20s for an occasional change,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
#81 |
Lugnutz65,
Does the Colorado wheel have the 3.5 dia center hole to fit on the 64-66 trucks?
#82 |
They will bolt right on to the rear axle. I used 2 of them on the rear of a 66 I had to move. The backspacing is a bit more that the factory C10 wheels so it tucks in a bit more. I have not installed them on the front yet. They might have to much backspacing for the front, but maybe they will be ok.
The Colorado wheels I show are easier to find than the 4X4 rally wheels from the Chevy K10. I think they look pretty nice with the center cap installed. I am strongly considering using a set. I have a lot of options saved in storage. Just haven't had a chance to see what they look like installed because my truck is still in pieces.
#83 |
I currently have stock steel wheels on my 64. I just found a cheap set of mid 80's 4x4 rallys which look a lot like those Colorados. I don't know if I will use them, but the price was too good to pass up. Someone will want them if I don't. It's good to know what's out there that might fit. Are the Colorado wheels 15 or 16? 15" tires and rims are getting harder to find these days. Everything seems to be 16 and up.
#84 |
The Colorado wheels are 15". The tire I have on in the photo is a 235/75/15.
#85 |
![]() Join Date: May 2009
15" rallys 3" rings crager type knock offs...Vernski
#86 |
I know you responded a while back, but are those plastic? How do you hold them on? Wouldn't the lug nuts crush the plastic when tightened? I'm assuming they are deep enough to clear the front center hub without removing the center emblem? (can't see the fronts well in pic) Thanks.
#87 |
Hard to see but its in the background;
#88 |
pic of the previous wheels polished and painted cast centers. 2nd pic is some Divco wheels in 6 lug I am after for the 46 burb project.
#89 |
I have 10" blazer rallies on my 66
#90 | |
#91 | |
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
#92 |
18x8
#93 |
I'm gonna runs these wheels 16"x4 or 5 not sure, with some kind of aggressive tread and the wheels will be the color of engine and firewall, I had to grind a little on the inside of wheel and grind some on caliper for these wheels to work, They came off my 48 fleetline.. and some kind of cap...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#94 |
Will the rally rims work with the factory drums?
#95 |
#96 |
I would think that they would bolt right on, others can chime in...
#97 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
#98 |
American Racing Outlaw 1 - 15x8 front 15x10 rear. Added benifit no brake dust issues
65 C10 Short bed, Fleetside, small back window Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=619304 |
#99 |
Discontinued weld racing wheels. 17x8 front, 18x8 rear Got them in '99.
At my worst I'm at my best |
#100 |
Good afternoon. Great looking truck! I also have those Jeep slots, did you have to put longer studs on? What lug nuts are you using? Mine only catch about 3/4 inch of thread. Thanks!
