#76 |
Re: 7K 73-87 tachs
can you put a stock tach in a none tach cluster
without modifying it |
#77 |
Re: 7K 73-87 tachs
It looks like you can install a pickup tach in a standard small truck cluster case. The mounting stands are in the cluster case for mounting the frame of the tach. You would need to cut a hole for the wiring plug to pass thru the back of the case. So it looks like you can use an LMC tach in a regular cluster housing.
The big truck tachs need the matching case, as they are different regarding the fuel gauge. |
#78 | |
![]() Quote:
Posted via Mobile Device |
#79 | |
78K & 79C Jimmys
Re: 7K 73-87 tachs
5658858B? and another i found here,beside the box,close but no blue lines
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#80 | |
78K & 79C Jimmys
Re: 7K 73-87 tachs
the non-Tach won't have the correct paths to run the gas, but should be able to wire it tho and switch a couple of wires to work
#81 | |
Re: 7K 73-87 tachs
I wish I could find a 5k tach with fuel gauge but it's looking like the only way I'm going to get an oem gauge is to do the 4k, which doesn't bother me that much, the time my BBC sees between 4000 and 5200 is going to be nearly non-existent, and with 4000rpm at the end of the sweep, I'll be able to see a more pronounced sweep with the change in RPM. (such as the converter is unlocking when it shouldn't be, etc). I suppose the other option is to go with the aftermarket gauge, but the fact that it's stamped plastic makes my skin crawl.
2010 Basalt Black Porsche Cayenne GTS - Daily driver 1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again. ![]() 1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac |
#82 |
78K & 79C Jimmys
Re: 7K 73-87 tachs
not a fan of plastic either
in fact my black cluster overlay with mine is plastic,and can't tell installed, it's been said here the plastic gauge dosn't look plastic when it's installed i think the dual gauge you have to chop out the lower lights,belts and brake?
#83 | |
Re: 7K 73-87 tachs
I suppose I could also get the LMC steel gauge, and install an auxiliary fuel gauge in one of the spots on my A-pillar. That would allow me to use a gauge with a red LED that shows when nearly empty and would almost surely be much more accurate than the factory fuel gauge... I'd probably need to sacrifice my oil temp or AFR gauge though. ![]()
2010 Basalt Black Porsche Cayenne GTS - Daily driver 1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again. ![]() 1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac Last edited by 1BadAction; 05-09-2013 at 05:16 PM. |
#84 |
78K & 79C Jimmys
Re: 7K 73-87 tachs
could you use the 4x4 light hole wired for brake?
gas should fit but I've only got an 78/79/79/87/88/89 to compare to lol Posted via Mobile Device
#85 |
Re: 7K 73-87 tachs
LMC lists the small fuel gauge as only fitting up to 1980, but the picture shows they are both 81-87 styles.
![]() Items # 5 & 6. Its easier to see in the print catalog. Also, not 100% those would bolt into a standard cluster case, but it does appear the mounts are the same as a clock. So if a clock mounts in any cluster, then so will the LMC fuel gauge. As for wiring, its simple enough to solder 3 wires to the printed circuit traces and run them across the cluster to the fuel gauge. |
#86 | |
Re: 7K 73-87 tachs
