08-05-2012, 03:22 PM | #1 |
Check The Champ, Demonstrator
Re: Airstream Shortification!
Making progress. I cut the bottom of the frame that rivets to the shell and it's similar to the extrusion for the sides and top only it's missing the interior clip for the interior molding. That's a no brainer. I,ll use this piece at the top of the frame.
The door frame I split in two and installed the inner panels to start because I had a sheet of .064 aluminum sheet and it fits in the groove for the interior panel. So I'll have to go get a sheet of .032 for the exterior of the door. Need to figure out how to lengthen the door frame top and bottom. This extrusion is unlike anything lse on the trailer. Wonder if Airstream still uses the same extrusion? |
08-05-2012, 11:12 PM | #2 |
Can you post up what you're using for rivets and your procedure for installing them. I've never played with anything but pop rivets, but I want to someday....
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
08-14-2012, 08:07 AM | #3 |
BlueJeep
I'm using solid rivets from http://www.vintagetrailersupply.com/..._p/vts-826.htm Dad made a rivet buck, thats the long steel shaft with the black handle on it. You push lightly on this when bucking the rivet to mushroom the end. We found this design the easiest to work with. Very comfortable when doing overhead work. Below that, the plier looking thing is a Cleaco tool and below it is a Cleaco. This is a temporary device to hold two or more pieces together before you start to rivet. Buddy who worked on aircraft lent me these. Drill bit is a #20 drill bit. this co-ordinates with the rivets I`m using. Two rivet sets. The shorter one I ordered with the rivets. It proved to be to short working around some of the windows and door, so Dad made a longer one. Both work well. An old Snap-On air gun. The rivet sets go in the end and at low pressure hammers, transfered through the head of the rivet, allows the buck to mushroom the shank of the rivet. We found to pull on the trigger to hammer one shot that takes up all the slack, then a short burst to mushroom the shank. Were no proffesionals, this method works the best for us. Rivet cutter is the tool with the red handles. Use this to shear the shank of the rivets to the length we need depending on how many layers were riveting together. < Getting the rear door frame welded Friday, maybe on the weekend I`ll be able to video the process. More windows...lol Another oval on the lower section of the door and the panoramic sky view on the edge of the roof line. Talked to a glass shop this morning, there going to shorten some other ovals I have to flank both sides of the large passenger side window. |
08-15-2012, 08:26 PM | #4 |
Wow.........VERY impressive. Love it!
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
08-15-2012, 11:48 PM | #5 |
Very cool..Nice work.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
08-25-2012, 03:16 PM | #6 |
Riveted the frame into place and then mocked up the door hinges using threaded rod and nuts.
An aluminum block will fill the void between the hinges and door frame. |
08-25-2012, 03:31 PM | #7 |
I think you are doing a very nice job on your trailer. Just the idea of building a
small trailer from a large one is great!! Just putting all the rivets in and drilling the holes is a big job. I remanufactured a 45 bus in the 90's and used over 8,000 rivets. |
08-25-2012, 03:42 PM | #8 |
Riveting is the easy part. Right now it's finding the time and of course finding someone who is willing to buck for ya. Had my 80 year old Dad again with me today. He wants to be doing something but tires quickly. He had a nice nap after lunch on the company sofa. All's well.
08-25-2012, 03:53 PM | #9 |
Kinda looks like a coroners meat wagon for campers.
08-26-2012, 01:38 PM | #10 |
Yeah... but a really cool meat wagon
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-26-2013, 05:42 PM | #11 |
Canadian Trucker
Any updates on this neat little project?
2020 Silverado Trail Boss - 6.2/10spd |
08-13-2014, 12:38 PM | #12 |
"I feel the need for speed!"... as soon as I am done with my nap. |
08-30-2015, 07:19 PM | #13 |
nice build might have made it a little longer in the rear but still im impressed with how nice this thing goes back together
i realy like that caravanpuller using the winchmotor is a realy good idea as its cheap and has all the controlls and wiring allready on it i have a pretty narrow storage meant for an european car i need to fit a full size pickup in and this looks like the solution if i make sunting like it but with a garagejack lift on top i need to basicly lift the front wheels of the ground with the jack under the crossmember turning it intoo a fifth wheel trailer and push the whole truck intoo the storage without having to get intoo the cab or crawl out the rearwindow
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
