Old 05-02-2012, 07:32 AM   #76
blfuller123
blfuller123's Avatar
Re: 69 slammed, 22"/24" bbc shaved clean
Its looking great!!! Where did you find those through the frame air fittings?
blfuller123 is offline   Reply With Quote
Old 05-02-2012, 08:45 AM   #77
toocrazy
toocrazy's Avatar
I found them on amazon.com. I looked long and hard for these darn things. Nice quality fittings.
Amazon.com: Legris 3/8" Od Equal Elbow... Amazon.com: Legris 3/8" Od Equal Elbow...
toocrazy is offline   Reply With Quote
Old 05-02-2012, 08:50 AM   #78
toocrazy
toocrazy's Avatar
Yesterday was a great day as the anticipation of recieving the brakes for the C10 was finally satisfied. Kore 3 supplied the 14" front 13.5" rear corvette Z06 rotors and assembly brakets. I have yet to order the Z06 calipers and I am undecided whether to get the black or red with the corvette logos or the silver Grand Sport calipers w/o the logos. I have not resided on an exterior color yet so I did not want to buy the calipers. What do you guys think about the corvette logos on a C10??
Old 05-02-2012, 10:12 AM   #79
67cheby
67cheby
67cheby's Avatar
WOW ! killer brakes
67cheby is offline   Reply With Quote
Old 05-02-2012, 04:21 PM   #80
blfuller123
Those rotors look sweet!!! I think the corvette logos would be killer.
Old 05-02-2012, 08:58 PM   #81
toocrazy
toocrazy's Avatar
Originally Posted by 67cheby View Post
WOW ! killer brakes
thank you. it was a hard decision to make to spend that kind of money on brakes:wash: With the big wheels it seemed almost necessary to have a big rotor on it. The Wilwood's would have been another $1000 over these to go with the 14's. As blfuller123 said I think the Corvette logos would look great. I know there are a few other guys running the KORE 3 setup and I got my idea from them. The things you learn on the forum. I will say those guys are very helpful, very knowledgeable and great to do business with. I wanted a rush order on mine and the extra money was fair and worth it. Beware, a bunch of rotors, nuts, bolts and brackets show up and one must figure out where they all fit.!!
Old 05-02-2012, 09:50 PM   #82
Delmo
Delmo's Avatar
Great build man. Smooooth.
Delmo is offline   Reply With Quote
Old 05-04-2012, 09:36 PM   #83
toocrazy
toocrazy's Avatar
I am just starting to mock up the brake lines. I know this is going to be somewhat of a tedious process. Do you guys mock up your brake lines first, remove, paint, and reinstall or just install brake lines once your frame is done. I have come to realize that although these two big ass boosters are great for getting brake components out from my engine bay and under dash, they are going to involve some plumbing. The Wilwood master cylinders are under the dash so, I have to run two lines back, one to each booster, and then I need to run one line forward to the front brake lines.............3 lines front to back instead of 1(whoops, 4 including vacuum line).........if anyone has any ideas please pipe up. I stuck on a vacuum canister you can see on the far side of the frame.
Here I am trying to figure out my front air and brake lines. The front frame is to be boxed and i want to keep the lines inside the frame. On the brake lines I might try to install a -3 AN bulkhead fitting in the frame to keep it clean. Not sure how it is going to play out though. Any thoughts I am still working on the airlines. I am using 3/8 line which is probably overkill. The 1/4 inch is easy to fish but the 3/8 is a lot tougher to bend. I am really creating a lot of work just to have the frame boxed.
Dual batteries, not sure why one wouldn't work but 2 should work better......right
Hoping to remove differential and trailing arms tomorrow and getting them painted.
Old 05-04-2012, 11:31 PM   #84
67cheby
67cheby
67cheby's Avatar
Great work
Old 05-05-2012, 12:23 AM   #85
c10seconds
c10seconds's Avatar
Nice stuff toocrazy! Do you have a color for the truck picked out yet?
c10seconds is offline   Reply With Quote
Old 05-05-2012, 08:46 PM   #86
toocrazy
toocrazy's Avatar
I did have a color picked out. I was actually stealing the idea from the below picture. I love the lower chrome molding. Unfortunately last week I was checking out the Tootsee build and I see Carter Hickman had a rendering completed for superfly and the build was already in progress..............at least I get to see what it would have looked like Can't build the same truck so right now the theme will be either gloss or matte black with a lipstick red interior. At least for now that is a serious consideration.
Old 05-05-2012, 08:52 PM   #87
crsweet91
crsweet91's Avatar
Great work!
crsweet91 is offline   Reply With Quote
Old 05-06-2012, 02:26 PM   #88
toocrazy
toocrazy's Avatar
Most of yesterday was spent sandblasting parts. This could qualify on the show Dirty Jobs. The 40LB sandblasting tank I got from Harbor Freight works like a charm. I just picked up a 100 gallon 7.5 hp dual cylinder air compressor so air supply which can be the biggest setback in sandblasting keep up with no problem. We just used play sand and filtered it though a screen for our abrasive. Curious what you guys use?? The differential came out looking as new. Sprayed a little "wash primer" on it so it won't rust. In the next few days we will used a bondo to clean up around the welds, painting it, and it will look like new. This will be the first painted part on the truck to be ready.
Old 05-06-2012, 02:52 PM   #89
67cheby
67cheby
67cheby's Avatar
Nice work !
Old 05-06-2012, 03:45 PM   #90
npc1
npc1's Avatar
I have a sand blaster too. It works great when although my little 60 gallon 4.5 hp compressor usually lets me know when its tired of sand blasting for the day. lol. Truck is coming along nicely.
Check out my Build http://67-72chevytrucks.com/vboard/s...d.php?t=517150
npc1 is offline   Reply With Quote
Old 05-06-2012, 10:30 PM   #91
toocrazy
toocrazy's Avatar
You have a pretty good sized compressor yourself. I have a nice 60 gallon compressor like yours. However, a friend of mine had this 7.5 hp 100 gallon compressor at his business. It was almost new and he gave it to me. It has an automatic drain function and an air cooler on the back. It was 3 phase so I had to buy a $500 220v motor to make it work. It pumps out a bunch of air. If you get yourself a storage tank off of your regular compressor it really helps a lot.
Old 05-07-2012, 11:16 PM   #92
npc1
npc1's Avatar
On your brakes Im pretty sure you did the cpp drop spindles but what model Kore 3 brakes did you buy and for the front and rear? And what bolt pattern did you go with?
Old 05-08-2012, 12:05 AM   #93
mcbassin
Still Learning
mcbassin's Avatar
Sanblasting SUCKS! It looks like you have a handle on it though. Dirty jobs is a good name for it.
mcbassin is offline   Reply With Quote
Old 05-08-2012, 10:25 PM   #94
toocrazy
toocrazy's Avatar
Yes, I did the CPP drop spindles. I went with the 14" fronts and the 13.5 rears from Kore 3 and brackets for the Z06 brakes. All real nice quality stuff. I did not get my calipers yet because I can't decide between red, black, or the silver grand sport calipers.
It really is nice to be able to have the power to sandblast the body parts and stuff instead of sending it out.
Old 06-17-2012, 11:32 AM   #95
toocrazy
toocrazy's Avatar
Just a little update. I had most of the mock up of brake, fuel, and air lines installed on the frame. I felt pretty comfortable I had gone as far as I could and we stripped it down. I thought a day of grinding and then paint........WRONG. I bet we have put 50 hours on that dang frame and still not done. Lots of lessons were learned!
Old 06-17-2012, 11:42 AM   #96
72LSK10
72LSK10's Avatar
You have a sick truck in the making and an even sicker garage, very nice.
72LSK10 is offline   Reply With Quote
Old 06-17-2012, 12:40 PM   #97
Tinkermc
your guy is doing a great job. When he finishes you will have a real nice ride
Tinkermc is offline   Reply With Quote
Old 06-17-2012, 12:50 PM   #98
belowme51
belowme51's Avatar
looking good man. Its always easier in your head than it is to do the work....always but pay off is when done and you can enjoy all your hard work and hours spent. Wish you the best of luck with the build as you have a very solid start. im subscribed
belowme51 is offline   Reply With Quote
Old 06-17-2012, 05:23 PM   #99
toocrazy
toocrazy's Avatar
Thanks guys, Bob is definitely the lead man when it comes to bodywork and paint. His wife even came over on Saturday to help sand.
Here is an outside picture of the garage.
Old 06-17-2012, 06:22 PM   #100
truckmanloco
What a great garage and an awesome truck.
truckmanloco is offline   Reply With Quote
