Old 01-30-2013, 02:11 PM   #76
nlped
nlped's Avatar
Re: '70 GMC SWB Money Hole
Ordered a 15 gallon Jeep Wrangler gas tank and the Wrangler F.I. in-tank sending unit assembly, minus the fuel pump, for the 5.3L swap. I'll put the appropriate Walbro 255 pump in this setup and hopefully I'll be cookin' with gas...pardon the pun
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-30-2013, 02:37 PM   #77
NewType72
NewType72's Avatar
Sounds good to me can't wait to see the new parts
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 02-11-2013, 03:45 PM   #78
nlped
nlped's Avatar
I scored some more pieces for this build. 1968 GMC hood, grille & tailgate. They need some lovin', but I really like the angle of the front of the hood of the earlier hood. (& my hood and grille are in horrible shape ).
Carter
Old 02-11-2013, 03:54 PM   #79
CC69Rat
CC69Rat's Avatar
I think you'll need the 67-68 upper bar to run the hood.. (?) Something like that. I know they're different post 69 but you can change that bar and run the 67-68 hood.
I agree, I like that hood much better too.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-11-2013, 04:26 PM   #80
CC69Rat
CC69Rat's Avatar
Duh , just noticed you have a grille too. Sorry man. Lol
Chad
Old 02-11-2013, 07:09 PM   #81
nlped
nlped's Avatar
No worries... My typing is way faster than my thinking too
Carter
Old 02-11-2013, 07:19 PM   #82
nlped
nlped's Avatar
Here are a few shots... I know the 5.3 looks rough, but I heard it run and go through the gears without issue. It has 83k miles on it and was in my buddies dad's personal truck that got hit/totalled in a parking deck.
Carter
Old 02-11-2013, 07:30 PM   #83
nlped
nlped's Avatar
Started stripping the extra SWB frame of some of the parts that will be replaced. Took out the k-member (I will reuse it, but not until after the sandblasting and paint step0, worked on the trailing arm crossmember, and a few other pieces/parts.
Oh, and a pic of my only helper when the weather is bad...
Carter
Old 02-11-2013, 07:31 PM   #84
shawno72
C/10 junkie
shawno72's Avatar
Everything looks great to me
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-12-2013, 12:06 AM   #85
NewType72
NewType72's Avatar
I'm seeing alot of the fastlane in your near future my friend
- Dylan
(209)-985-7721
Old 03-24-2013, 02:33 PM   #86
nlped
nlped's Avatar
It doesn't look like much, but it has been a LOT of work. I cut every body rivet that was holding any bracket, mount, or bracing out of my "extra" SWB frame so I when I'm done with the trial install of all my suspension, brake and fuel lines, and the gas tank, I'll be able to take it completely apart and sandblast everything, primer and paint ALL surfaces of the frame and such, then reassemble. I cut a crossmember out, and then bolted it back in so the frame would remain square. I am using all Grade 8 hardware in place of the rivets. I am going to build custom crossmembers in place of the core support, shock, and the other two flimsy rear stock crossmembers, but this way I can take one out at a time and fab each depending on needs (like the two rear ones will also be the supports for the Jeep Wrangler gas tank).
I have to go buy more 3/8" bolts, washers & nuts today. I cut like 140 rivets out. It's a process
Oh, and I built my own hidden hitch out of a hitch from a 2008 Dodge Ram that I found at the scrap yard...$5, what a bargain!
Carter
Old 03-24-2013, 03:36 PM   #87
NewType72
NewType72's Avatar
Awesome that's a great idea to have everything blasted individually so that there's no secret rust to destroy your ride later in its life. Great work as well in the hidden hitch
- Dylan
(209)-985-7721
Old 03-30-2013, 11:21 AM   #88
nlped
nlped's Avatar
I am going to work on getting the frame mocked up and get the 5.3/4L60e in this weekend. I also ordered my C-notchs, front & rear tubular crossmembers, and per Chad (69CCRat) I ordered the upper & lower shock mounts from Porterbuilt yesterday. Whoop Whoop!!!
Carter
Old 04-07-2013, 07:39 PM   #89
CC69Rat
CC69Rat's Avatar
Ed, just checking in .. you doing Bham to Charlotte for HRPT ? Did you get your PB stuff yet?
Chad
Old 04-08-2013, 08:55 AM   #90
nlped
nlped's Avatar
Still waiting on the PB pieces. I'm definitely going to do the HRPT.
Carter
Old 04-22-2013, 11:48 AM   #91
nlped
nlped's Avatar
And I'm still waiting (relatively patiently) on my PB pieces, but I did go ahead and order the Cadillac CTS-V oil pan, pick-up and dip stick today. The truck pan hangs down WAY to low for my taste...like 2" below the crossmember. The CPP tubular mounts have the motor to far forward, but I think I have that all figured out, but I need the pan to make sure.
Carter
Old 04-22-2013, 02:50 PM   #92
nlped
nlped's Avatar
Got a wild hair and went ahead and modified the stock K-member and moved the motor back 2 5/8" using the CPP tubular stands, 3" FORWARD adapters, and poly motor mounts. I used the 3" forward adapters so I can still use the stock style A/C compressor in the O.E. LSX location, but moved the stands back to the rear 6 cyl frame holes. I had to make/modify the K-member so that the lower CPP stand would sit flat...nothing a little cutting, welding, grinding and drilling couldn't remedy
Here are a couple of shots as it sits right now. Sure wish my PB stuff would show up today
Carter
Old 04-22-2013, 08:28 PM   #93
nlped
nlped's Avatar
Ugh!!! Heard back from Porterbuilt...still several more weeks until finished. I was told 3 weeks and its already been 3 1/2. I know the quality is top notch and so is the $$$, but the follow through seems lacking...
Carter
Old 04-22-2013, 08:36 PM   #94
CC69Rat
CC69Rat's Avatar
Hang in there buddy... it will be worth the wait. Looks great so far.
Chad
Old 04-22-2013, 08:50 PM   #95
lolife99
67-72 parts collector,…
lolife99's Avatar
Even though Porterbuilt has added personnel to help with production,... it seems demand is even greater than ever.
I ordered some front shock mounts last week and was told 4-6 weeks!
But that is fine by me.
You are adding alot of resale value to your truck using Porterbuilt parts.
Keith
Convert to disc brakes.
Old 04-22-2013, 08:54 PM   #96
CC69Rat
CC69Rat's Avatar
I think it might need the full drop member and forward arms, etc.
Chad
Old 04-22-2013, 09:13 PM   #97
nlped
nlped's Avatar
Lol... No way!!! I've done all this with the intent of building a driver! You made me buy the PB pieces...damn it!
I also ended up buying the TBSS Pacesetter headers today too.
Carter
Old 04-22-2013, 09:15 PM   #98
nlped
nlped's Avatar
I'm really hoping I'm not worrying about resale... I just wanted the quality. I do know his stuff is the best. I'm just like an impatient kid...I want my new toys.
Carter
Old 04-22-2013, 09:21 PM   #99
nlped
nlped's Avatar
I've got to come up with the fuel line stuff, buy new S/S brake hard lines and then figure out the next batch of issues. I'm getting close to needing to tear down the current truck to start fitting the body.
Carter
Old 04-22-2013, 09:26 PM   #100
CC69Rat
CC69Rat's Avatar
Chad
