Old 02-13-2013, 08:23 PM   #76
Tomahawk30
Tomahawk30's Avatar
Re: 1970 C10 SWB - Project "Sprout"
Been a while since I've updated, but I've been fighting starter / timing issues lately. Replaced the solenoid, replaced the starter, still had grinding when I tried to start. Crawled under it yesterday and realized that one of the bolts wasn't snug. Turns out, the inside bolt hold is stripped out. It initially would grab and snug down, but after a couple of starts it would pull free again. So I ordered a helicoil kit to fix that this weekend.
I also picked up a stud for the kickdown cable and a grommet to make the original throttle linkage mate up with the large top hole on the Edelbrock throttle bracket. Works like a charm and it actually accelerates down the road now because it'll pull far enough to open up the secondaries and kick down into 2nd under heavy throttle.
Next up this weekend is replacing all of my plugs because I'm pretty sure they are all fouled from messing with the timing and fuel mixture on this new-ish carb. I also bought the correct plug wires to run down beneath the manifolds to clean it up a bit.
Once I have it roadworthy, I'll work on the little things (one rear taillight isn't working, need some center caps for the wheels, and I have to get rid of that horrid yellow sticker in the back window!!!)
In the meantime, here's an outside picture that shows how it looks under cloudy skies... The color changes a lot depending on light. And it needs a bath.
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline   Reply With Quote
Old 02-13-2013, 10:16 PM   #77
Booya
Booya's Avatar
Looking good....
Booya is offline   Reply With Quote
Old 02-16-2013, 12:24 AM   #78
Tomahawk30
Tomahawk30's Avatar
Installed some new plugs and wires tonight and it made a world of difference. I was finally able to get my timing dialed in where it should be and got a quick taste of what the engine is capable of. And I was more than pleased with the result! Tomorrow I'm hoping to helicoil the starter bolt hole, fix a leaky power steering hose, fix a taillight, and tweak the accelerator pump to hopefully solve a small hesitation I noticed. Getting close....
Old 02-16-2013, 12:35 PM   #79
67cheby
67cheby
67cheby's Avatar
NICE ! Looks great
67cheby is offline   Reply With Quote
Old 02-17-2013, 11:37 PM   #80
Tomahawk30
Tomahawk30's Avatar
Tried to embed a new video I took today, but it doesn't seem to want to work with a flickr hosted video. So here's the link instead. Just a quick walkaround with it running and idling (finally). Still working on getting it dialed in just right to eliminate a small off-idle stumble. And I really need some mufflers. Those Thrush glasspacks are LOUD in the cab!
http://flic.kr/p/dVKYMJ
Old 02-22-2013, 06:30 PM   #81
Tomahawk30
Tomahawk30's Avatar
Finally gave the truck its first maiden voyage on my lunch break today (a whopping 9 miles down the highway). Other than a little off-idle / low throttle stumble that I suspect is a stepup rod/spring in the Edelbrock, it ran like a champ. Speedo is definitely off, and my guesstimate skills need some calibration. Thought I was doing around 55-60, but when I turned on the speedo app on my phone I was actually closer to 67-68! Made me smile to be rolling down the highway comfortably pushing 70 though.
Old 02-22-2013, 06:42 PM   #82
Bomp
Bomp's Avatar
Nice vid.
Truck sounds great.
Bomp is offline   Reply With Quote
Old 02-24-2013, 10:33 PM   #83
Tomahawk30
Tomahawk30's Avatar
Originally Posted by Bomp View Post
Nice vid.
Truck sounds great.
Thanks! It'll sound a lot better with some decent exhaust. It's a pretty noisy driver with those glass packs dumping in front of the rear axle.
Old 04-03-2017, 07:07 PM   #84
JerBear
Do you still have those side tanks?
JerBear is offline   Reply With Quote
Old 04-04-2017, 09:28 AM   #85
Tomahawk30
Tomahawk30's Avatar
Nope, I sold this one almost four years ago now (can't believe it's been that long!). I sold it before we moved out here to Kentucky in 2013 and I think the tanks probably got scrapped.
