Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-27-2012, 03:48 PM   #76
scatesracing
Machinist
scatesracing's Avatar
Re: need help with my suspension 1970 gmc
Are you running drop spindles?
scatesracing is offline   Reply With Quote
Old 09-27-2012, 04:05 PM   #77
bigboybodry
bigboybodry's Avatar
Yes and cpp uppers/lowers control arms.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 09-27-2012, 06:48 PM   #78
scatesracing
Machinist
I picked up a set of 74200 Moroso springs used real cheap. 4.8 dia I hope they will fit... It looks like the will. I’m running a pair of stock spring that have been cut to lower the truck. Compressed they are 7.75 tall and if I remember right they are around 12" tall uncompressed. My truck will not transfer for anything. if it doesn’t dead hook and you have to lift it becomes a pedal fest...This thread has been a ton of help. It all makes sense now. Thanks guys
Old 10-01-2012, 07:03 PM   #79
bigboybodry
Got the new body mounting bushings installed today. Still waiting on the headers and exhaust to get back from airborn coatings they are saying Friday! Man I hope so I'm dying to try it out!
Old 10-01-2012, 09:17 PM   #80
Tnjcurtis
What headers and motor mounts do you have?
Tnjcurtis is offline   Reply With Quote
Old 10-02-2012, 08:19 AM   #81
bigboybodry
solid moroso engine mounts and custom built headers. I hear that some of the members are running a bbc chevelle header. I was running a poly engine mount and super comp hooker headers but after installing the solid engine mounts the headers hung to low draging all the time so I built a custom set of fenderwell headers.
Old 10-05-2012, 04:38 PM   #82
bigboybodry
Got the headers and exhaust back from airborn today
Old 10-16-2012, 06:52 PM   #83
bigboybodry
Ok guys I ran the truck this pass weekend at ctc and it seems to be moving around alot
front to rear side to side any input?
Old 10-17-2012, 05:49 PM   #84
scatesracing
Machinist
Moving around? off the line ... on the big end?
Old 10-18-2012, 08:45 AM   #85
bigboybodry
Front to rear when taking off and rear to front when stopping. A friend of mine was following me and said when I took a turn it looked like the front tire almost come off the ground. It has alot of movement in the suspension.
Old 10-18-2012, 03:04 PM   #86
Super73
Super73's Avatar
So, is it tranfering weight then to the rear under acceleration and then tranfering it to the front under braking? Not sure I follow.
Is it moving weight to the outer front in a corner and lifting the inner rear?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-18-2012, 03:48 PM   #87
bigboybodry
yes
