08-27-2012, 05:53 PM | #76 |
Re: Project Sketchy Deal
looking good!
'72 C10 deluxe long bed, 350 auto project in the works http://67-72chevytrucks.com/vboard/s...d.php?t=513464 Now accepting donations towards the Wade needs hot rod parts fund. all applicable donators will be thanked hospitably with a 12 pack of any alcoholic beverage of their choosing |
08-29-2012, 02:06 AM | #77 |
10/30/19
Thanks for the kind words 72blueshark...
Well I tied up all the loose ends on sketchy and took it for a cruise tonight. Had some issues with the serpentine set up...fan and power steering pump...I really wanted to use it. Perhaps I can put it back on at a later date,so for now it has the v belt stuff on it. Running good. Next thing to fix is a trans leak. Posted via Mobile Device |
08-29-2012, 06:30 AM | #78 |
67-72 parts collector,…
You do realize the serpentine set-up takes a "reverse flow" water pump?
So changing to standard v-belts will require a waterpump change also. Just checking.
08-29-2012, 11:45 AM | #79 | |
10/30/19
Good looking out..I've been known to over look stuff before...like not run 12 volts to the hei dist. Posted via Mobile Device |
08-29-2012, 05:30 PM | #80 |
6>8 Plugless........
Looking good to seeing you and the new truck in a little over a week!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-29-2012, 11:55 PM | #81 |
10/30/19
08-31-2012, 05:36 PM | #82 |
Glad to see you had good luck with the process.
Can you post up some more details on what you had to go through/what forms you had to fill out to get it done without a lawyer? I am also curious on how detailed the inspection is for the assembled vehicle VIN. I would assume that everything would have to be working including wipers, squirters, lights, etc. I am still sandbagging on going through the process with mine. I am slowly getting everything working. |
08-31-2012, 07:24 PM | #83 |
10/30/19
I downloaded all the forms I needed off the net.(Quiet Title Packet) Except one, I got that one from a Kansas Trooper. There was no other inspection,...just vin numbers. There are only two places in Ks. to get a vin and title assigned. Topeka and Olathe... Olathe has a very cool trooper who helped me tons. He is by the book and knows his stuff/job.
I am going to be at the Midwet All Truck Nations next weekend. I can bring copies everything that I used to file. At first I was very reluctant to attempt this and was really against using a lawyer for this. It would have cost me more than $1200 and some wanted more than $1400 I am so glad I went this route. Posted via Mobile Device Last edited by kingsolver72; 08-31-2012 at 07:30 PM. |
08-31-2012, 07:30 PM | #84 |
10/30/19
One other thing I would say is, don't go anywhere but Olathe to do the inspection.
08-31-2012, 07:55 PM | #85 |
It sounds like ready to go for Nats.
I'm not as good as I once was, But I'm as good once as I ever was. |
08-31-2012, 08:25 PM | #86 |
10/30/19
Yeah I've been driving it around town. I may drive it to Olathe tomorrow. Has way more get up and go than other engine...but nothing crazy.
I still want to drop it a bit.. Worried about front end alignment. Although a couple years ago I cut the front springs on the ochre truck and it drives straight as an arrow. I am still amazed. The tires have normal wear too. Posted via Mobile Device |
09-05-2012, 01:37 AM | #87 |
10/30/19
I installed the rear springs last night. I think I only got a 3" drop.now I have to get the front lowered. Pictures later.
09-05-2012, 09:14 PM | #88 |
10/30/19
Pictures...I was hoping for more of a drop in the back. i am digging it though.
09-05-2012, 09:53 PM | #89 |
So lets get this straight, The trooper pulled parts off your truck and you have a title that matches the vin plate on the door. The frame was the only thing swapped out? How in the heck did they ever find out about the frame being swapped??? Sounds to me like I would have invested in a nice stamp set, scrub the stuff and make it right.And Of course I know this is illegal to do but omg this is going a bit to far for the law to pull parts off your truck or atleast thats the way it sounds to me. Now of course if it showed as being stolen then it is what it is I would give it to them them no questions asked. This makes no sence at all.I would think frame swaps are common and not illegal at all. Here in TX we can even get a builders title or some thing to that notation as I've heard. Sorry to hear of such a raw deal hope it works out for the better for ya God Bless....
09-05-2012, 10:17 PM | #90 |
Man of Mini-Talents
I'm digging it too, Scott. Very cool.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
09-05-2012, 10:36 PM | #91 | |
10/30/19
The same trooper put my new vin plate on the door jamb below the original spot. It was a crazy deal but I wanted to do tag it without any worries. I definitely have piece of mind. Was it worth all the hassle? I haven't thought of it that way. I am however growing fonder of it each day that I have worked on it. Thanks for the kind words..it's working well so far. I think God is teaching me to be patient. Maybe. Posted via Mobile Device |
09-05-2012, 10:50 PM | #92 |
10/30/19
Actually as I think more about it. The vin tag that was removed by the trooper,did not have rose bud rivets. They were round and flat...very common type.. It was probably what clued the trooper in that something was amiss.
09-05-2012, 11:14 PM | #93 |
Oh now I understand, so the orginial rose rivets were switched with round head rivets. So the title you have matches the vin tag that the trooper removed from the door jamb? and then they punched you a new one and put it back on the door? doesn't the new vin tag the trooper put on the jamb match the title as well? This is the oddest story I have heard in my life but thanks for posting it sure is a wake up call as to what to look for before buying any vehicle! Things will work out in your favor. God Bless....
09-05-2012, 11:15 PM | #94 |
Oh and by the way that is a hella nice truck you have there!
09-05-2012, 11:45 PM | #95 |
10/30/19
After I got all the legal stuff worked out and was issued a new vin plate I the went to the courthouse with all the paperwork and registered the truck and from there the state of Kansas will issue me a new title with the new assigned vin number on the title.I still have not received the new title in the mail. I ain't sweatin it though.
09-06-2012, 12:13 AM | #96 |
BlahBlahBlah
Sweeeeet! I like the little bit of a rake you have going there. Glad you got all the paper work working for ya.
09-06-2012, 12:50 AM | #97 |
VA72C10
Looks good man!
Looking for a 67-72 swb or blazer project in or around VA. |
09-06-2012, 06:55 AM | #98 |
Looks great to me!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
09-07-2012, 09:18 AM | #99 |
Looks good! A 2" block in the back should get you down where you want to be.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-07-2012, 03:56 PM | #100 |
10/30/19
Thanks again everyone!
Hey Rob, I've got what I think are 3" cpp lowering springs( forgot who I bought them from) and 1.5" blocks. I'm a little concerned about the scrub line. Think I might swap springs with the ochre 72. Posted via Mobile Device |
