Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-07-2012, 01:45 AM   #76
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: '62 GMC Suburban is on it's way.....
Looks like with a little elbow grease (well, ALOT actually) looks like I WILL be able to have an OG patina finish ....
This rear corner, looks like someone randomly experimented with blue ...
and some tan/brown...
But ultimately....
(notice the drip mark trail coming off the trim ... must of been all the washington rain ??)
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-07-2012, 01:57 AM   #77
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Also, another big thanks to CaptainFab, for coming thru with some 292 perches...even thru in some new fasteners, which I wasnt expecting !!
Thanks Cap !!!
Now, if I could just get my ESP working again, so I can plan on packages coming when the wife is not home ... Would make life so much calmer ..
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-07-2012, 06:12 AM   #78
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Have your packages mailed using my name and tell her your collecting stuff to eventually be shipped to me. Put them on yoiur truck as a test fit for me and paint them so they'll be preserved before going to the rusty North. We then loose contact because I`ve moved and VOILA you get to keep the parts! You can blame me for the entire situation.
Canadians, you just can't trust them!
Old 08-07-2012, 09:47 AM   #79
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 12:28 PM   #80
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Time for a little update ... Little is better than none
My kids, and my buddy worked on it Friday night....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 12:33 PM   #81
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
This will be one of first area I will repair, once it's running:
Man, was it HOT in the garage.....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 12:41 PM   #82
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Currently here:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 12:55 PM   #83
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: '62 GMC Suburban "Rust"oration, Patina Build.....
I managed to sell the OG 4-speed (without shifter) for $100 on CL...
A customer needed a flange made out of 1/2" plate, for a 280Z ... Which gained me another $50 .....
This scored me a Clip off a 78 !! No money outta pocket is sooo nice...
The guy wanted $50 for the crossmember, and $125 for the PS box and pump.....I would of spent some time at P n P hand wrenching a crossmember off, considering the entire suspension would have to be removed, and would still been charged at least $50...
So he gave it all to me for $150
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 01:07 PM   #84
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Moving on to the 292 ....
Removed some externals, and brought them to the shop for some cabinet time...
Looks like this engine was on the verge of an attack...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 01:12 PM   #85
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
NOW FOR SOME BAD NEWS ......
Before I resealed the engine, I went ahead and ran a compression test on it...which resulted in some LOW numbers....
Compression is at about HALF of what it should be.....Well, this will definately slow the engine "detailing" down a bit...
Gonna weld a air fitting to an old spark plug and perform a leak down, but Im sure it will recieve a full overhaul....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 01:38 PM   #86
Corts60
Just here to tinker
Corts60's Avatar
Great looking burb John! That sucks about the compression results.
Old 08-12-2012, 02:01 PM   #87
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Ya.... the engine is the original from my '63 C-10.
Even thought the compression is low, it was pretty close thru all six....Thus it gave it a decent idle.
I never drove the truck because the Powerglide was bad.
So I pulled it out, and it sat untill I decided to use it as a temporary powerplant for the Burb.
Well, now I'm gonna have to build it. Regardless, it'll wind up back in the truck someday.
My buddy hooked me up with this too ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 04:56 PM   #88
coulter
coulter's Avatar
not sure if you have tried or not but u might soak those cylinders in marval mystery oil.. could just have some rings sticking
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 08-12-2012, 09:04 PM   #89
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well, gonna drop oil in cylinders, and recheck....then go from there.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-12-2012, 10:37 PM   #90
Jeff La
If you can get some Kroil to put down the cylinders. Soak them for about an hour, spin the engine over and soak again until the next day. Do this again the second day and on the third day spin it over and then check compression. If it's stuck rings the Kroil will free them up. At least it has for me a few times.
Jeff La is offline   Reply With Quote
Old 08-13-2012, 12:54 AM   #91
Captainfab
60-66 Nut
Good score on the front clip....no spindles or control arms though?
Too bad about the compression on the 292. Hopefully it is just a stuck ring or two, and you can get them freed up.
Too bad you're so far away. I have a neighbor that has a nice running '72 350/TH350 for reasonable.
Old 08-13-2012, 10:58 AM   #92
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey Captain.....
I have the a-arms already....
New bushings in boxes, as well as 88-98 BJ's.
Also, a machinist buddy is making up some collars (as we speak) to weld in the LCA's.
Left over slindles are on the shelf as well from a lowering job.
Just gonna need some loaded calipers, hoses, bearings, and tierods and I should be good to go !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-13-2012, 11:05 PM   #93
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Today I pressure washed the engine, after soaking with Oven Cleaner (works better than degreaser, btw) .... Then pulled it apart.
No sludge what so ever on head or in crankcase/pan.
Lots of carbon, probably when the carb lost its main jet (see C-10 thread)
and was running super rich, which probably washed the cylinder walls.
Anyway, the pistons are ALREADY .060 OVER , so hopefully they are straight...
You can still see the hone marks, and there is no ridge...bearings are near perfect.
So, once I remove the crank (balancer puller is at shop) my machine shop is gonna mic everything, and go from there....Plan is to re-ring at minimum. An engine kit with pistons is relatively cheap, so if I go there, itll be flat tops at least.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-13-2012, 11:30 PM   #94
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-14-2012, 12:18 AM   #95
Captainfab
60-66 Nut
So you're using the '73+ C10 LCA's?
Post some pics when you get them done.
Old 08-14-2012, 02:43 AM   #96
westcoast5
oven cleaner huh will it be ok if I use it while the engine is still in the truck?
Bryan
1966 SWB BBW "SICKT6"
Accuair|Porterbuilt|Bodied|Shaved|Z'd|350 with minor goodies|5 lug|front disc|3.73 rear|CPP power steering/brakes|few more goodies| thanks to C10Clubapparel
westcoast5 is offline   Reply With Quote
Old 08-14-2012, 04:26 AM   #97
padresag
just remember that oven cleaner is lye. if you are worried about anything(corrosive) wash it down with vinegar and then water after.
ron
padresag is offline   Reply With Quote
Old 08-14-2012, 09:28 AM   #98
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yeap, for sure.
Especially on the alum.
I've heard people using it on frames as well too.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-14-2012, 09:30 AM   #99
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yes I am ....
Post pics ..... Do you really need to ask ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-14-2012, 12:45 PM   #100
MikeS.
MikeS.'s Avatar
Originally Posted by ChiefRocka View Post
Yes I am ....
Too funny
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
