#76 |
![]() Join Date: May 2012
Re: New here and new to older trucks..
like what you have done so far, you are making good progress....the color is going to be great...like your truck....
#77 |
Thanks Dollor..
Like what you did to your truck too.. Kinda hurry up building.. Eyeing a 72 that just came up.. Posted via Mobile Device |
#78 |
Looks a bit high in the back, those rear shocks were toast, got a set included in the truck so swapped them up, the front has a coil less and new shocks as well..i thought it would be lower..
Need those lowered rear springs bad.... Posted via Mobile Device |
#79 |
those rims are awesome!!! good work on the truck. before it looked like an overboard whit guy who had way to many supplies and time on his hands!
1968 chevy swb stepside black ![]() ![]() METALLICA |
#80 |
Thanks Fordsucks..
Should have forgotten about the truck when the PO showed me the Impala he was "fixing", my guess is the guy works in construction.. If I would not have found the parts truck I guess would have been driving around in a bondo/fiberglass/plaster truck.. Wheels will look much better when I get the proper tires. Posted via Mobile Device |
#81 |
Heres a bit more, just gathering whats around to bolt it in ( re-sprayed the whole truck) and slowly getting it back together
Need to adjust the door from hell and MUST lower the rear asap ![]() Posted via Mobile Device |
#82 |
Spray some black and get that grille, lights and bumper bolted on!!!
#83 |
Not much accomplished today, we re-sprayed the white in the morning, but by noon torrential tropical rains halted most of the work ( Im doing this truck in spare time between the real paying gig)
Still managed to get some progress.. Tried to get the steps on and its a pain, plus got the wrong bolts ( 5/16" and they seem to be 1/4) in one side installed the bracket first but seems like theres no way unless I take the fender off, or bolt the step with the bracket at the same time.. Oh well.. Got a 1913 ford which will take our time from next week on... ![]() Posted via Mobile Device |
#84 |
Undecided if spraying the bumpers white or just let them be.
Just noticed that the bed is tilted, but since its not bolted on yet no worries ![]() Posted via Mobile Device |
#85 |
A bit of progress. More assembly and trying to tie things up
![]() Ill deal with the speaker holes later on, need to get the spacers for the levers..anyone has them? ![]() ![]() Thought it would be lower up front ![]() Posted via Mobile Device |
#86 |
Took some time to tinker with the truck today..
Have been encountering slight delay after delay fitting parts that simply should bolt on. ![]() The grille if off, by at least a quarter inch on the passengers side ( PO had hit it somehow) and had removed from the side brackets, the bumper (from donor) is bent inwards on the passengers side as well, the bumper shows a crease on the same line as the bolt holes so I will need a way to pull it and straighten until is acceptable. Weirdly the radiator started pissing fluid from a pinhole ( that was not there before) we we simply exchanged radiators from the donor truck. On the steps, somehow the do not line up flat with the fenders and I needed to raise the bed the 1/4 inch that the wood boards will add in order to be able to get the step bracket to work with the step Does anyone has the distance from the back of the cab and the bed?? Im going to line up and drill the attatchment holes from bed to cross sills next. Also got to get a couple snapped bolts off ( of course no one told me they had been snapped while removing) so now I gotta take a front and rear fender in order to fix those..Oh well.. Anyway, looking at a 72 tomorrow.. Posted via Mobile Device |
#87 |
Assembly has been halted thanks to the flu..
Still pondering if spraying flat clear to the paint, What do you think? The front bumper is bent a bit inwards on the passengers side and we need to figure out how to fix it. Went to look at a 72, but needs body work on the roof and the guy wants 2 grand, found another 71 with bad trans for $700, so Ill go check it out as soon as I can.. Posted via Mobile Device |
#88 |
Back to the grind..
Front bumpers needs some time to straighten out, so decided to use a good white one, which means I will have to paint the chrome rear.. Ordered the rear lowered springs (4") can't wait to get them.. Been re-assembling little by little and still need to order a few parts here and there, mostly small plastic parts and such. Got some of the dash lights and gauges working as well.. Will get some progress shots tomorrow, nothing important.. Posted via Mobile Device |
#89 |
Seat is done..
![]() Went to the fabric store and got what I tought looked older.. Boltdown and cleanup time ![]() Side shot as of today.. Needs those rear springs badddd!!!! ![]() Posted via Mobile Device |
#90 |
Please delete this double post
#91 |
elchopperfreak: you got it looking good, when you are finished i bet you will be proud....i like it.
#92 |
Thanks Dollor, someone found it more interesting than me..so when its done its gone..
#93 |
can't believe you are letting that one go...but its yours....i would hate to see it go...i like it a lot..well some one is getting a great truck....
#94 | |
( already bought a 72 step to flip, but my dad kept it,so Im working on that next) Missed a chance on a 69 longbed already.. Have some ideas for the next one.. Posted via Mobile Device |
