Old 09-05-2012, 01:48 AM   #76
lanconcj
lanconcj's Avatar
Re: Attempting the "$50 paint job"
I am attempting this method as well. I am painting a "test" area in the bed with flat black. I have no experience with flat paint. Will I still have to buff the paint when complete? What does buffing do to flat paint? I am used to getting a shine after buffing, but flat paint doesnt shine"?
lanconcj is offline   Reply With Quote
Old 09-05-2012, 10:57 AM   #77
Lowered13
How much paint is it taking you to cover your truck?
Lowered13 is offline   Reply With Quote
Old 09-05-2012, 11:00 AM   #78
tylervalo
I orginally bought 2 quarts, I'm thinking I might need 2 more. The only place I can get this color local didn't sell it in gallons.
tylervalo is offline   Reply With Quote
Old 09-05-2012, 11:02 AM   #79
cory d
cory d's Avatar
that would be sad seeing it like that after ten years. if that happened with my dads 79 crew i would probably break down and cry, no joke ha
cory d is offline   Reply With Quote
Old 09-05-2012, 11:07 AM   #80
tylervalo
Haha it wasn't easy, I only took about 5 pics I wish I would have taken more. I knew they guy that bought it just wanted the motor, there's not telling how it arrived there. My dad swapped the buckets for a bench, I'm sure the motor and axles were swapped along it's journey as well.
It did have 1 emblem left on the dr side fender, I pull it off and gave it to dad.
Old 09-06-2012, 08:34 AM   #81
tylervalo
Coat 6 is on...1/2 way there!!
Going to wet sand tonight and apply coat 7. I'm running into issues getting light streaks in the paint, I don't know if it's from the mineral spirits (the brand I have is white) or reusing the mixing cups. I went last night and got some clear mineral spirits and enough mixing cups to not have to reuse them.
Old 09-06-2012, 09:07 AM   #82
JRANGER
JRANGER's Avatar
looks so shiny.....You didnt use any primer either did you?
JRANGER is offline   Reply With Quote
Old 09-06-2012, 09:11 AM   #83
tylervalo
No, most people said it wasn't needed since the Rustoleum had priming properties.
Old 09-06-2012, 09:13 AM   #84
JRANGER
JRANGER's Avatar
well thats rather awesome
Old 09-06-2012, 08:34 PM   #85
tylervalo
Coat 7 went on VERY wet. It initially was to thin and ran all over the place, I had used the last of the paint so I had to scrape what all I could out of the can to save it.
Old 09-06-2012, 08:40 PM   #86
68Timber
I know the pieces fit
68Timber's Avatar
It looks great and I'm tempted to try this with my CUCV. Can you do this with something other than Rustoleum? There's not many color choices there.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-06-2012, 08:46 PM   #87
tylervalo
I'm not sure, I've heard other mention other brands but Rustoleum seems to be the most popular. There are several colors, stores don't carry many besides white and black. I found mine at a little mom and pop store.
http://www.rustoleum.com/cbgproduct.asp?pid=130
Old 09-06-2012, 09:00 PM   #88
cjlinkster
cjlinkster's Avatar
Yes, you could do the same with any oil based enamel paint. I have used the Tractor supply valspar paint on a couple of projects; it worked great. I also hear that ACE hardware store paint is good.
When I get closer to painting my truck, I am going to look at using PPG ALK-200 enamel. I have read that it can be matched to any of the PPG color codes.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 09-06-2012, 09:42 PM   #89
68Timber
68Timber's Avatar
I appreciate the info and for you sharing this. It looks like a perfect solution for my CUCV, I just need to find an oil based enamel in an olive drab I like.
John
74 Honda Z50 build
Old 09-06-2012, 09:53 PM   #90
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I used TS valspar paint for the first time today and it was total garbage, It had about 2" of sludge at the bottom I had to try to stir but I still couldn't get all of it after 15 minutes of trying. Ive never had that with Rustoleum, not even today with another can of it.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 09-06-2012, 11:17 PM   #91
motornut
78K & 79C Jimmys
motornut's Avatar
It comes tintable,rustoleum
Or for us up here tremclad
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-06-2012, 11:30 PM   #92
ivorton74
ivorton74's Avatar
man ur truck looks startin to look good. i wanted to do that to my 74. but i need body work and a new bed first.im subscribing. i wanna see the finished product.
ivorton74 is offline   Reply With Quote
Old 09-07-2012, 07:39 AM   #93
motornut
78K & 79C Jimmys
motornut's Avatar
http://www.canadiantire.ca/search/search_results.jsp
even water based rust paint??....whats the world coming too...and it's still 39.99
John
Old 09-07-2012, 08:01 AM   #94
Pop's C-10
Pop's C-10's Avatar
Looking good
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 09-07-2012, 08:09 PM   #95
tylervalo
I need advice. Monday I'm leaving town for a week for work, tonight I put the 8th coat on following a 1k wet sand. If I reinstall the interior tomorrow morning (since the inside is done) I can do coats 9 and 10, push it in the garage since all the interior is back in the truck, let it cure while I'm gone then come back Saturday with 2k wet sand and rubbing compound. Sound good?
8th coat:
Uploaded with ImageShack.us
Old 09-07-2012, 08:45 PM   #96
str8axle55
I would think so, more time to cure isn`t a bad thing.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-07-2012, 09:11 PM   #97
slinginrods
slinginrods's Avatar
Looks good! If you wanna save even more buy ace hardware brand oil based paint.this is my recipe for the industrial equipment I build,trailers,farm equip ,etc. we mix a 50/50 of paint and thinner,a small amount of hardener and add a few drops of "Japan dryer". Then spray it out of a 20.00 harbor freight gun.usually two coats.its smooth as silk nice and hard,.im seriously thinking about the semigloss that ace sells on my truck.i rolled the inside of the bed to give it the textured look.i love it easy to touch up. As far as the base /clear vs. single stage automotive paint.most beginners will do the base /clear due to being able to fix any poor technique by wet sanding buffing and or respraying.single stage takes more skill to get a good finish with.they both offer the same protection,actually single stage is less likely to peel than clear over color base due to poor adhesion.its all about the prep and product quality.my kid could spray base clear and I could cut and buff it and you'd swear it was a 5 k paint job.that wont fly with single stage.looks awesome !
slinginrods is offline   Reply With Quote
Old 09-07-2012, 09:42 PM   #98
JRANGER
JRANGER's Avatar
sounds good and looks good
Old 09-08-2012, 12:06 AM   #99
UPNADM
UPNADM's Avatar
I would wet sand it with some 1500 first... Then see how your base looks. I think the jump from 1000 to 2000 is too much.
This is just my opinion...
UPNADM is offline   Reply With Quote
Old 09-08-2012, 12:07 AM   #100
UPNADM
UPNADM's Avatar
Looks very good though!
Good work.
