Old 06-22-2013, 08:00 AM   #76
kgmunro
Re: 63 SWB C10 LT1/4L60E Swap
WOW! Great work on the truck so far! Keep it up!
kgmunro is offline   Reply With Quote
Old 06-22-2013, 05:50 PM   #77
88Lt1wagon
Looks nice, did you keep it from going into the bed, or how does it look from in the bed?
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline   Reply With Quote
Old 06-22-2013, 06:19 PM   #78
Trsmotrhed
Trsmotrhed's Avatar
I had to take it into the bed. I have not worked on that part yet. On my last 66 I used a suburban bed panel and didn't need to enter the bed. I'll build around the setup and post pics. Here's what I have in the bed.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 06-24-2013, 12:51 AM   #79
Captainfab
60-66 Nut
I had to do a little catching up on your build thread. I can't believe what you did with that bedside. You sir are a true metal working craftsman
Old 06-24-2013, 01:29 AM   #80
Trsmotrhed
Trsmotrhed's Avatar
Thanks captainfab, I appreciate your comments especially from the master of Fab. I'm very pleased with how straight they came out. All the block sanding paid off. I'm horrible about detailing out my work. I get going and hard to stop for pics.
63 SWB C10
Old 06-24-2013, 05:00 PM   #81
par4tom
Motor,
Real nice job on this truck! And thanks for putting it on here. Seeing work like yours makes me appreciate how really bad I am at doing a lot of the work I'm doing on mine.
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 06-29-2013, 12:35 AM   #82
Trsmotrhed
Trsmotrhed's Avatar
Made a cover for the fuel lines in the bed.
Test fit in bed side.
My Anal self kicked in and I couldn't stand the bed rail being removed with the suburban tank so butchered it up. After all the work I've done to this tank I should have built my own out of aluminum and been the way I want.
63 SWB C10
Old 06-29-2013, 08:20 PM   #83
Trsmotrhed
Trsmotrhed's Avatar
Finished up the inside gas tank panel.
63 SWB C10
Old 06-29-2013, 08:23 PM   #84
88Lt1wagon
Very nice
-Jason
Old 06-30-2013, 03:16 PM   #85
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thanks for posting those pics of your bed repair.
Nice work.
It gives inspiration to me to work on the fleetside bed I acquired last year.
It needs similar repair.
66 C20 Service Truck:
Old 06-30-2013, 11:45 PM   #86
Trsmotrhed
Trsmotrhed's Avatar
Installed a wiper motor from a 72 C10. Bolted right in and gave me a two speed motor.
63 SWB C10
Old 06-30-2013, 11:50 PM   #87
Trsmotrhed
Trsmotrhed's Avatar
Got bored and made a battery hold down bracket.
Wrapped bottom with rubber.
Works great.
63 SWB C10
Old 09-05-2013, 11:07 PM   #88
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Great Work, Excellent Fab Skills!!! besides I'm sweet on LT1's.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 09-07-2013, 06:43 PM   #89
E911manager
I am so glad I read you post about the steam pipe. I understand you have to vent this. Do you think there will be any problems with venting it into a closed heater pipe? I don't see any big problems with the way you did it and I plan on following your lead.
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 11-16-2013, 11:01 AM   #90
Trsmotrhed
Trsmotrhed's Avatar
Hi, sorry I'm late replying. Busy at work. I haven't had any problems at all with overheating. This is what I have installed now from autometer. Looks much better.
63 SWB C10
Old 11-16-2013, 11:34 AM   #91
E911manager
That is a lot cleaner. I got some stuff from the hardware store and got my vented. Been driving quite a bit and haven't had any issues. I need a overflow bottle now it seems to spit a little water out when I let it idle sitting still for 30 minutes or so. I think it is normal. Just spits a little..
Old 11-16-2013, 12:05 PM   #92
Trsmotrhed
Trsmotrhed's Avatar
Mine was spitting a little fluid also after driving in 100 deg weather. I installed this catch can from summit and works great.
63 SWB C10
Old 11-16-2013, 12:18 PM   #93
E911manager
That is similar to the one I am looking at. I am glad to hear that this may fix my problem.
Old 11-23-2013, 10:16 PM   #94
Trsmotrhed
Trsmotrhed's Avatar
Haven't done much lately, busy at work. Did manage to find the time to install a new aluminum tranny pan today.
63 SWB C10
Old 12-25-2013, 01:58 PM   #95
Trsmotrhed
Trsmotrhed's Avatar
Ordered a whole bunch of patch panels from Top Banana. Santa's big brown truck delivered them the other day so off to repairing the rust. I got inner and outer rocker panels, toe kick panel, cab corner, fender braces and patch panels.
I started on the fender. The PO had installed a patch panel and did a really bad job, installed crooked, and of course it was the same size as the new panel. So cut right where he tried to weld it. He ground so much the metal is paper thin and blowing thru when I weld in a few spots, so more patching.
63 SWB C10
Old 12-25-2013, 02:02 PM   #96
Trsmotrhed
Trsmotrhed's Avatar
Had problems with my mobile photobucket app and had to delete it and reinstall. Guess that messed up the photo's on my build thread. I'll see if I can fix it when I have time.
63 SWB C10
Old 12-28-2013, 12:14 PM   #97
Trsmotrhed
Trsmotrhed's Avatar
Finished the patch panel install on drivers fender. I'll strip the old paint and epoxy primer the fender.
63 SWB C10
Old 12-29-2013, 02:09 PM   #98
Trsmotrhed
Trsmotrhed's Avatar
Got the fender all stripped. Found some rust at the front of fender. Repaired that and put POR15 on back side of fender.
POR15 on inside of fender.
All ready now. I'll wait to epoxy prime when I finish the passenger fender and paint together.
63 SWB C10
Old 12-29-2013, 10:56 PM   #99
chad64chevy
chad64chevy's Avatar
patch panel looks really great, you sir have some skills
chad64chevy is offline   Reply With Quote
Old 12-30-2013, 12:46 AM   #100
Trsmotrhed
Trsmotrhed's Avatar
Thank you. Just looked at your build. Looking good. Really like the engine.
63 SWB C10
